Artillery Genius end stops unreliable
I installed Duet 2 WiFi in Genius and I have a problem with original endstops.
Sometimes they works sometime not and motors are grinding belt.
Any one have any idea?For now I'm using stall detection but I want to use original Z end stop instead of BLTouch and this is more dangerous to printer.
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 11 2020 22:01:44 GMT+0200 (czas środkowoeuropejski letni) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Genius" ; set printer name ;M918 P1 E4 F2000000 ; configure direct-connect display ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S1 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes backwards M569 P4 S0 ; physical drive 4 goes backwards M584 X0 Y1 Z2:4 E3 ; set drive mapping M350 X32 Y32 Z16:16 E16 I1 ; configure microstepping with interpolation M92 X158.86 Y159.26 Z1600.00:1600.0 E445.0 ; set steps per mm M566 X2000.00 Y1800.00 Z24.00 E240.00 ; set maximum instantaneous speed changes (mm/min) M203 X10000.00 Y10000.00 Z180.00 E220.00 ; set maximum speeds (mm/min) ;M203 X200.00 Y200.00 Z20.00 E40.00 ; guide mm/s M201 X500.00 Y400.00 Z100.00 E100.00 ; set accelerations (mm/s^2) M204 P1000.00 T2000.00 ; from guide mm/s^2 M906 X1000 Y1200 Z1200:1200 E980 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; dual Z M671 X-25:255 Y110:110 S2 ; Z axis distance 280 ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X228 Y231 Z255 S0 ; set axis maxima ; Endstops M574 X1 S3 ;P"!xstop" ; configure sensorless endstop for low end on X M915 P0 S2 ; sensorless sensitivity S param M574 Y1 S3 ; P"!ystop" M915 P1 S2 ; sensorless sensitivity S param ;M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin zstop M591 D0 P1 C"^e0stop" S1 ; filament runout sensor ; Z-Probe ;M574 Z1 S2 ; set endstops controlled by probe ;M558 P9 H5 F100 T6000 ; set Z probe type to bltouch and the dive height + speeds ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X30:225 Y5:190 S19 ; define mesh grid M558 P9 C"^zprobe.in" H5 F120 T3000 ; BLTouch connected to Z probe IN pin M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector ;************************ G31 P25 X28.2 Y-35.3 Z1.9464 ; z-probe trigger ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S80 ; set temperature limit for heater 0 to 80C M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S275 ; set temperature limit for heater 1 to 275C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1:0 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ;PID M307 H0 A446.1 C424.2 D2.6 S1.00 V24.3 B0 M307 H1 A733.4 C200.3 D5.2 S1.00 V24.3 B0 M302 S180 R20 ; Allow extrusion starting from 120°C and retractions already from 110°C M572 D0 S0.035 ; pressure adv ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue T0 ; select first tool G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0
Can you post the results of M122 please?
What kind of enstops are they? Photo? How do you have them wired? Photo?
Do they correctly report their state in M119?
Post your homing files as well.
Hey bro, doing the same Upgrade, so would be a plessure if u could help me with my Conversation!
How did u connect the Endstops to the duet ? The genius needs 5V not 3.3V Voltage for the Endstopsensor. If u didnt pay attention to this maybe try to wire the endstops like this : [https://www.youtube.com/watch?v=UZGYZ3XXTTU&t=493s](link url) -
@d0minik96 In fact, those
GL-8H
inductive sensors are rated for 12 to 24VDC but they still works for voltage at around 4V.
I powered mine at 12V and used a level shifter to get the sensor output at 3.3V.
I wasn't confident about the sensor reliability at such low voltage as 5V (even the diag LED almost not lit !). -
@Falcounet Uff, i did not think about the signal that goes back to the board. but looks like it can handle the 5V. But it's a good point to consider!
This post is deleted!
