Error: M997: "Duet2CombinedIAP.bin" not found
Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found
upload it as well.
you can find it at the same place where you downloaded the new firmware
This happens when upgrading to 3.2 from 3.1.1
@Veti said in Error: M997: "Duet2CombinedIAP.bin" not found:
upload it as well.
I can not find it... Maybe blind
did you flash via bossa to 3.1.1?
i.e you never went to 3.0?
its here
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0 -
its here
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0Bossa flash yes. NO 3.0
@Veti Thanks!
If you still have access to DWC the best way to update is to upload the complete release zip file
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zipThat way you get the firmware, DWC files, etc etc all together. Just upload the zip file itself to the system tab in DWC.
