Duet 3 mini 5+ need help with wiring and config
Try again after a reboot, and post your entire config.g please.
now it worked. M558 P9 still give same error though
"m558
Z Probe 0: type 9, input pin io3.in, output pin nil, dive height 350.0mm, probe speed 350mm/min, travel speed 4800mm/min, recovery time 0.00 sec, heaters suspended, max taps 1, max diff 0.03"G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Hevo" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 D2 ; physical drive 0.0 goes forwards M569 P0.1 S1 D2 ; physical drive 0.1 goes forwards M569 P0.2 S1 D2 ; physical drive 0.2 goes forwards M569 P0.3 S1 D2 ; physical drive 0.3 goes forwards M569 P0.4 S1 D2 ; physical drive 0.4 goes forwards M584 X0.0 Y0.1 Z0.2:0.3 E0.4 ; set drive mapping M350 E16 I0 ; configure microstepping without interpolation M350 X16 Y16 Z8 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z1600.00 E407.00 ; set steps per mm M566 X380.00 Y380.00 Z20.00 E4000.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z500.00 E4000.00 ; set maximum speeds (mm/min) M201 X1200.00 Y1200.00 Z300.00 E5000.00 ; set accelerations (mm/s^2) M906 X900 Y900 Z1200 E450 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z-0.5 S1 ; set axis minima M208 X330 Y343 Z450 S0 ; set axis maxima M671 X-45:380 Y170:170 S1 ; leadscrew positions ; Endstops M574 X1 S3 ; configure sensorless endstop for high end on X M574 Y2 S3 ; configure sensorless endstop for high end on Y M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"io3.out" ; create servo pin 0 for BLTouch M558 P9 C"^io3.in" H350 F350 T4800 B1 ; set Z probe type to bltouch and the dive height + speeds + heater off while probing G31 P500 X25 Y-20 Z0.85 ; set Z probe trigger value, offset and trigger height M557 X25:310 Y25:310 P6 ; define mesh grid + Probe points ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S0.70 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S350 ; set temperature limit for heater 1 to 350C ; Fans M950 F0 C"out5" Q50 ; create fan 0 on pin out5 and set its frequency M106 P0 C"Hotend fan " S0 H1 T50 ; set fan 0 name and value. Thermostatic control is turned on M950 F1 C"out6" Q1000 ; create fan 1 on pin out6 and set its frequency M106 P1 C"Blower" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
Forget the M558 P9
Please fix the dive height M558 H5
Other than that it's down to the white trigger signal wire on io_3.in
@Phaedrux guess it decided to break it self then during me changing the card. I have continuity all the way to under the connector on the blTouch it self down to the end of the connector going into the card.
I will however before i order a new one make a short harness and try it on the bench. -
@Phaedrux it is working now. When i wired this up ages ago i connected ground further up so i only had to use one wire in the connector. I now reran one ground more. In the end i had 3 ground wires. that is why i had continuity on white.
Only reason i figured it out was cause i had the stick from the multimeter on the ground at the mother board and hit the white wire by mistake.
