3.2-RC2 - Timeout while waiting for transfer ready pin
during the update I had the same issue I had on Beta 4.1
This time I did the following:
- Downloaded a new image of DuetPI put it on a new SD card, enabled SSH and configured WiFi, booted and confirmed normal operation of the Duet stack.
- Updated the kernel and user land to the latest version (apt update/upgrade) and confirmed normal operation once more.
- Switched to the unstable Duet repo and executed the update (apt update & upgrade).. Like with Beta 4.1, the control server was unable to connect to the Duet3.
I am using a RPI4, 4GB
root@duet3:/opt/dsf/bin# ./DuetControlServer -l debug Duet Control Server v3.2.0-rc2 Written by Christian Hammacher for Duet3D Licensed under the terms of the GNU Public License Version 3 [info] Settings loaded [info] Environment initialized [fatal] Could not connect to Duet (Timeout while waiting for transfer ready pin) [debug] System.OperationCanceledException: Timeout while waiting for transfer ready pin at DuetControlServer.SPI.DataTransfer.WaitForTransfer(Boolean inTransfer) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 1086 at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 1148 at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean connecting) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 162 at DuetControlServer.SPI.DataTransfer.Init() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 104 at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 113 root@duet3:/opt/dsf/bin#
This time i was able to run the g-codes requested when I reported the error for Beta 4.2.
M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-12-24
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-RC2 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode) Board ID: 08DGM-9T66A-G63SJ-6J9F2-3S86Q-TA0BA Used output buffers: 1 of 40 (1 max) === RTOS === Static ram: 149788 Dynamic ram: 91516 of which 396 recycled Never used RAM 117132, free system stack 160 words Tasks: NETWORK(ready,547) HEAT(blocked,353) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,53) MAIN(running,1345) IDLE(ready,19) Owned mutexes: USB(MAIN) === Platform === Last reset 00:05:23 ago, cause: reset button Last software reset details not available Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 21.7, current 24.3, max 24.5 Supply voltage: min 23.9, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0 Driver 0: position 0, standstill, reads 53913, writes 11 timeouts 0, SG min/max 0/0 Driver 1: position 0, standstill, reads 53913, writes 11 timeouts 0, SG min/max 0/0 Driver 2: position 0, standstill, reads 53913, writes 11 timeouts 0, SG min/max 0/0 Driver 3: position 0, standstill, reads 53913, writes 11 timeouts 0, SG min/max 0/0 Driver 4: position 0, standstill, reads 53913, writes 11 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 53914, writes 11 timeouts 0, SG min/max 0/0 Date/time: 1970-01-01 00:00:00 Slowest loop: 2.59ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.1ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with „M122“ in state(s) 0 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.16ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages queued 0, send timeouts 1614, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47 ok
I had to downgrade to 3.1.1 in order to restore normal operation.
Please make sure there is no SD card in the Duet when you use it in SBC mode.
Okay, that worked, thanks!
