Duet2 WiFi Firmware on Raise 3d E2 ?
I think you're outside the realm of what we can help you with here. I'm not familiar with the Raise3D printer or what it's doing.
@Phaedrux I think the bufer is full right? Where would it be enlarged with a duet wifi?
they are acknowledgement of g code received.
so something is sending g code to the duet.
@Veti Yes, the display board sends the gcode to the motion board
you will have to figure that one out yourself.
also can you post the result of M122
(>>) === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DLM-996RU-N8PS4-7J1D8-3SJ6N-1B9BR<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 25536<LF>Dynamic ram: 99000 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 6280<LF>Tasks: HEAT(blocked,1232) MAIN(running,3828) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:40 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6224 bytes (slot 0)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 18.7, current 23.2, max 23.4<LF>Supply voltage: min 0.0, current 0.6, max 0.9, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: ok, SG[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
please change the EOL settings so that the entire settings are printed
(>>) === Diagnostics === (0.000) (>>) RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later (0.000) (>>) Board ID: 08DGM-9T6BU-FG3SS-6J9FD-3S46R-TVSHD (0.000) (>>) Used output buffers: 1 of 20 (3 max) (0.000) (>>) === RTOS === (0.000) (>>) Static ram: 25536 (0.000) (>>) Dynamic ram: 99012 of which 0 recycled (0.000) (>>) Exception stack ram used: 448 (0.000) (>>) Never used ram: 6076 (0.000) (>>) Tasks: HEAT(blocked,1216) MAIN(running,3772) IDLE(ready,200) (0.000) (>>) Owned mutexes: (0.000) (>>) === Platform === (0.000) (>>) Last reset 00:03:38 ago, cause: power up (0.000) (>>) Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6212 bytes (slot 3) (0.000) (>>) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d (0.000) (>>) Error status: 0 (0.000) (>>) Free file entries: 10 (0.000) (>>) SD card 0 detected, interface speed: 20.0MBytes/sec (0.000) (>>) SD card longest block write time: 5.0ms, max retries 0 (0.000) (>>) MCU temperature: min 26.8, current 32.7, max 33.0 (0.000) (>>) Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes (0.000) (>>) Driver 0: standstill, SG min/max 0/348 (0.000) (>>) Driver 1: standstill, SG min/max 0/139 (0.000) (>>) Driver 2: standstill, SG min/max 16/358 (0.000) (>>) Driver 3: standstill, SG min/max not available (0.000) (>>) Driver 4: standstill, SG min/max not available (0.000) (>>) Driver 5: standstill, SG min/max not available (0.000) (>>) Date/time: 1970-01-01 00:00:00 (0.000) (>>) Cache data hit count 413358567 (0.000) (>>) Slowest loop: 10.00ms; fastest: 0.08ms (0.000) (>>) I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0 (0.000) (>>) === Move === (0.000) (>>) Hiccups: 293, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 237, MaxWait: 129054ms, Underruns: 0, 0 (0.000) (>>) Scheduled moves: 12, completed moves: 12 (0.000) (>>) Bed compensation in use: none (0.000) (>>) Bed probe heights: 0.000 0.000 0.000 0.000 0.000 (0.000) (>>) === Heat === (0.000) (>>) Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 (0.000) (>>) Heater 1 is on, I-accum = 0.0 (0.000) (>>) === GCodes === (0.000) (>>) Segments left: 0 (0.000) (>>) Stack records: 2 allocated, 0 in use (0.000) (>>) Movement lock held by null (0.000) (>>) http is idle in state(s) 0 (0.000) (>>) telnet is idle in state(s) 0 (0.000) (>>) file is idle in state(s) 0 (0.000) (>>) serial is ready with "M122" in state(s) 0 (0.000) (>>) aux is idle in state(s) 0 (0.000) (>>) daemon is idle in state(s) 0 (0.000) (>>) queue is idle in state(s) 0 (0.000) (>>) autopause is idle in state(s) 0 (0.000) (>>) Code queue is empty. (0.000) (>>) === Network === (0.000) (>>) Slowest loop: 0.00ms; fastest: 4581298.50ms (0.000) (>>) Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) (0.000) (>>) HTTP sessions: 0 of 8 (0.000) (>>) - WiFi - (0.000) (>>) Network state is disabled (0.000) (>>) WiFi module is disabled (0.000) (>>) Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485 (0.000) (>>) Socket states: 0 0 0 0 0 0 0 0 (0.000) (>>) === Filament sensors === (0.000) (>>) Extruder 0 sensor: ok (0.000) (>>) Extruder 1 sensor: ok (0.000)
