BLTouch Smart 1.0 with Duet Maestro...
Trying to setup my Duet Maestro to finally use my BLtouch Smart 1.0. Trying to get the config correct and running into troubles. I have repeatedly gone through the step by and even tried the config tool. It doesn't seem to get me all the way their. The BlTouch will retract and deploy but my value in thebrowser for Zprobe don't change... Does anyone have a sample config Essentially using a modded / extended linear rail based Ender 3 Pro (320 x 320 x 440 )with makerbot endstops.
The M280 Commands will deploy the pin.
The M280 P0 S10 extends the pin
The M280 P0 S90 retracts it
No value change in Zprobe section of webview.
Using V3 of Reprap Firmware btw -
This post is deleted! -
@jaymcd0626 said in BLTouch Smart 1.0 with Duet Maestro...:
you wont be able to see a change. it is a very short change and returns to 0 immediately.
you need to test it with G30 and push the pin back in by hand. -
Thanks I got it working I believe. It triggers and stops Z. Now I just need to be able to verify the Z offset.
