Duet3/RPi 3.2B3.2: Toolboard Error: Response timeout
First time I've run into this. I just received the following error while performing mesh bed leveling on a Duet 3/RPi and toolboard. Hopefully something was caught in the M122 results that will be helpful.
I see a lot of lost messages being reported on the toolboard.. can't say I've seen this before.
Error: Response timeout: CAN addr 20, req type 6037, RID=1349
M122:
=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-beta3.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6J1DD-3SJ6S-TB62H Used output buffers: 8 of 40 (18 max) === RTOS === Static ram: 122236 Dynamic ram: 139580 of which 64 recycled Never used RAM 130312, free system stack 128 words Tasks: Linux(ready,67) HEAT(blocked,186) CanReceiv(blocked,869) CanSender(blocked,339) CanClock(blocked,352) TMC(blocked,18) MAIN(running,669) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:27:42 ago, cause: software Last software reset at 2020-11-22 09:56, reason: User, GCodes spinning, available RAM 130312, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xffffffff Task Linu Error status: 0x00 MCU temperature: min 38.9, current 40.6, max 40.8 Supply voltage: min 1.4, current 24.2, max 24.2, under voltage events: 1, over voltage events: 0, power good: yes 12V rail voltage: min 0.2, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 30480, standstill, reads 40419, writes 44 timeouts 0, SG min/max 0/335 Driver 1: position 0, standstill, reads 40442, writes 22 timeouts 0, SG min/max 0/0 Driver 2: position 1000, standstill, reads 40420, writes 44 timeouts 0, SG min/max 0/321 Driver 3: position 0, standstill, reads 40415, writes 50 timeouts 0, SG min/max 0/613 Driver 4: position 0, standstill, reads 40444, writes 22 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 40417, writes 50 timeouts 0, SG min/max 0/801 Date/time: 2020-11-22 10:24:39 Slowest loop: 1250.40ms; fastest: 0.08ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 370, MaxWait: 643231ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 678, completed moves 678, StepErrors 0, LaErrors 0, Underruns [0, 0, 5], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages sent 8206, send timeouts 8206, longest wait 2ms for type 6049, free CAN buffers 47 === SBC interface === State: 0, failed transfers: 0 Last transfer: 18ms ago RX/TX seq numbers: 52188/52190 SPI underruns 0, overruns 0 Number of disconnects: 1, IAP RAM available 0x20a30 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0-beta3 Trigger: Finishing macro config.g, started by system > Next stack level Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 31.55
M122 B20
Diagnostics for board 20: Duet TOOL1LC firmware version 3.2-beta3.2 (2020-11-13) Bootloader ID: SAMC21 bootloader version 2.1 (2020-11-03b2) Never used RAM 4244, free system stack 72 words HEAT 43 CanAsync 84 CanRecv 82 TMC 53 MAIN 333 AIN 64 Last reset 00:27:33 ago, cause: power up Last software reset data not available Driver 0: position 0, 830.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcount 12, reads 40193, writes 12, timeouts 0, DMA errors 0, failedOp 0xff Moves scheduled 0, completed 0, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.2V MCU temperature: min 53.3C, current 59.8C, max 61.3C Ticks since heat task active 56, ADC conversions started 1646714, completed 1646712, timed out 0 Last sensors broadcast 0x00000002 found 1 59 ticks ago, loop time 0 Free CAN buffers: 36, messages lost 16494, duplicates 0, oos 0, busOff 0
Is that mcu temp on the B20 report represent the temps on the toolboard? I wonder if there’s throttling that comes into play that may cause the issue.
I’m surprised to see this, but have never analyzed it before.. this may just be its operating temperature. The toolboard is in a heated chamber, but it was not heated when running the G29. In fact, I had the chamber heated to 70c right after this for a 4 hour print without any issue..
