3D printin issues on a core XY equiped with a duet wifi
@Veti No. I've PID tunned it for a max temp of 100 C
@campeancalin PID doesn't set a max temperature, the M143 does.
@campeancalin
Looking at the pictures, either you are over-extruding or your first layer is too low (which means you are trying to fit too much material in too little space). That causes material to push up higher than it should, and if the nozzle runs into those lumps it tends to cause layer shifts.And if you don't have one already, get a filament drier, CF filled filaments absorb moisture like crazy and need to be dried. If you look closely you might be able to see the filament bubbling as it comes out of the nozzle. Drying the filament for at least 24 hours will make a huge difference to both print quality and material strength.
How many walls are you using? Are you using concentric infill?
It's typical to use only a few walls and solid or rectilinear infill for the rest. Using too many walls can lead to over extrusion building up.
