Timelapse video through execonmcode!
@oozeBot said in Timelapse video through execonmcode!:
@the_dragonlord I don't know that you need to start from a clean install, but it might be useful to try this on a second SD card and keep your working version intact. Once you get execonmcode installed and understand how to add services, etc, this will all make better sense. Post a reply to wilriker in the other thread for installation questions, etc..
ok, thanks
just the last question: should the Raspy be connected via USB to the board or it just need to be connetced to the same LAN?
@the_dragonlord This is a question for the other thread, but I believe execonmcode will only work when using the RPi as the controller in a non-standalone configuration.. I don't see how else it could communicate.
ok, I ask in the other thread. Thanks a lot....I hope to become able enough to use your service on my printer!
