Giant Delta printer Slow Homing issue.
Also, in your video it looks like you have the DWC web files in your /system folder. They should not be there. (The CSS, FONTS, JS folders for example, and the html.gz files, etc.) Those files all belong in the /www folder on the SD card.
I think there may have been a few mistakes made during a firmware update.
@sozkan said in Giant Delta printer Slow Homing issue.:
Can you please provide the results of M122 and M98 P"config.g" ?
@Phaedrux it could be. Thank you for your attention. I am still on the learning curve.
You can see an example of the correct file structure here.
https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
Note that your /sys folder will also contain some .bin files for the firmware in addition to the listed .g config files.
It may be easiest to put the SD card into a PC to edit the file structure.
@Phaedrux said in Giant Delta printer Slow Homing issue.:
I realize now, you want me to send a command to the machine right? I can do it by tomorrow.
Yes, M122 will give us some diagnostic information including verifying what firmware version is installed. And M98 P"config.g" will execute the config.g file as a macro and echo back any error messages which are otherwise missed during power on. This would help eliminate any other syntax errors in config.g.
This may not resolve your noisy motors, but it will at least ensure we're working with a correctly functioning setup.
M569 P1 P2 P3 are fine if those cause the motors to move those are the correct ones. It's just targeting those driver numbers.
@Phaedrux
I will definitely do and share the result by tomorrow.But I am sure there is no imperfection on hardware and wiring. Because motors are accurately working on illegal code, but creating horrible sound and incorrectly working on legal code. That's means I have done something working during the firmware upgrade?
Because it is the latest stable update recently I messed up.
And yes, reduce acceleration and jerk. That should help a bit.
The motors are going to be loud. They are large and mounted to metal, but hopefully the adjusted timing and acceleration will make it a bit more bearable.
It's not illegal code if it works.
It`s some how stable on motor step control, but with those settings, I cannot control Enable or disable the motor features as well as the direction due to the illegal numbering. Because event Mr. admin "dc42" suggests for the external motor drives the stepper breakout board legal codes P5,6,7,8. Somehow these legal settings only working enable and direction settings and unstable step signals for the motor.
Since it is not functioning other variables except stepping, also according to the Firmware developer it is illegal
Until I found a stable solution, I will continue with this achieved a motor enable issue by hardware and mechanical brake gearbox and right direction setup on external motor driver. I believe it might run G-codes sufficiently if there is no hidden failure.
M98 P"config.g"
I have just done your advise:
result :
10/23/2020, 4:31:32 PM M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta1 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917DA-G4MS8-6JTD4-3S86J-19SHA
Used output buffers: 3 of 24 (21 max)
Static ram: 23916
Dynamic ram: 98532 of which 120 recycled
Exception stack ram used: 544
Never used ram: 7960
Tasks: NETWORK(ready,125) HEAT(blocked,138) MAIN(running,328) IDLE(ready,20)
Owned mutexes: WiFi(NETWORK)
Last reset 00:03:52 ago, cause: power up
Last software reset at 2020-10-22 20:24, reason: User, GCodes spinning, available RAM 8036, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0x028
MCU temperature: min 30.7, current 32.4, max 32.6
Supply voltage: min 24.2, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 276494, standstill, SG min/max not available
Driver 1: position 276494, standstill, SG min/max not available
Driver 2: position 276494, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2020-10-23 16:31:31
Cache data hit count 407671411
Slowest loop: 65.60ms; fastest: 0.15ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.0ms, write time 28.7ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 19, completed moves: 19, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 217.22ms; fastest: 0.09ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
Failed messages: pending 0, notready 0, noresp 2
WiFi firmware version 1.23
WiFi MAC address 80:7d:3a:3f:f6:73
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 22848
WiFi IP address 192.168.43.196
WiFi signal strength -67dBm, reconnections 0, sleep mode modem
Clock register ffffffff
10/23/2020, 4:30:44 PM Error: Temperature reading fault on heater 1: sensor open circuit
Error: Temperature reading fault on heater 2: sensor open circuit
10/23/2020, 4:30:42 PM M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Driver 6 does not support x0 microstepping with interpolation
Driver 7 does not support x0 microstepping with interpolation
Driver 8 does not support x0 microstepping with interpolation
Driver 5 does not support x0 microstepping with interpolation
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 258C
- WiFi -
I would say in your current situation of commissioning and tuning you should stick with firmware 3.1.1
Upload this zip file as is, don't extract it, to the system tab in the web interface.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
Driver 5 does not support x0 microstepping with interpolationM350 X0 Y0 Z0 E0 I1
I think you're going to need to specify a microstepping value. 0 won't work. Try 1.
I will definitely try your advice soon. I was formating file structure, I can't connect web interface anymore now. I have backed up fully the SD card. Reverted back but still not connecting.
Your SD card needs a file structure like this: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
The web interface files need be placed in the /www folder and come from here: https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
I normally install the beta update using the web interface. The CSS and www folders appeared in the sys folder after that.
Did you upload the full zip file without extracting it first?
You must not extract the zip file.
yes I did in the past with zip in beta version upgrade. But this case I cannot connect web interface. Panedue console says it connected to the IP : 192.168.1.200 but on my hotspot network it shows unknow IP connection. I have uploaded the firmware files in the SD card that you sent me now and reinstall firmware using the PaneDue interface with "M997 S0 to install the firmware" and "M997 S1 to install the WiFi module firmware" so successfully updated. After I send M115 to confirm the new firmware version it is still beta version remain and not connected.
