Firmware retraction retract/unretract independant feedrates
I did, briefly, with mixed results. The default setting of .1 seconds works splendidy on my Ord Bot, but I wasn't able to find a value that worked well with my Kossel so I ended up leaving it disabled.
I tested this on my Kossel last night and it worked perfectly. Thank you! Once it's released for the "legacy" Duets, I'll be using this on my Ord Bot as well.
1.16 beta 6 preview is at https://dl.dropboxusercontent.com/u/19369680/DuetWiFiFirmware.bin. Please note, the pin numbers used by M42 have changed in this release, see https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins.
Update:
See David's post here: https://www.duet3d.com/forum/thread.php?pid=3931#p3931
