heater fault when print starts
it was printing fine and then just drop temp
@Government_Bacon said in heater fault when print starts:
e3d v6
Is the thermistor cartridge and heater cartridge secured firmly? Have you removed them to check them?
@Phaedrux yes the thermistor is brand new and the heater is good and both are mounted good
i am useing this settup -
whats the resistance of the heater cartrige?
@Veti 91.5 printer says its at 26 c
91.5
then there is a problem with your heater cartridge
see normal resistances
https://matterhackers.dozuki.com/Wiki/E3D_Heater_Cartridge_Resistance -
@Veti sorry i checked the thermistor not the heater cartage. i ended up taking it a part and found out the heater cartage lead broke so i replaced it and it still dose the same thing. i checked the new one and its is at 5.4 and i checked the wires. testing now. tested it and it still drops i also did a auto tune for the new cartage
ok i have found my problem. i went through checking all of my wires and found one that i was getting it and miss reading from the hot end and it has a part of the wire severed in side if the wire covering. so i got it fixed and now it is working good.
