Duet wifi, bltouch not working
@Veti firmware 2.0
@Phaedrux yes i removed it here is a copy
; Heater model parameters
M307 H0 A154.0 C477.6 D0.6 S1.00 V12.1 B0
M307 H1 A371.8 C185.4 D4.2 S1.00 V12.3 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0 -
@sleepless said in Duet wifi, bltouch not working:
i added the deploy and retract scripts however I am still having issues
Editing 0:/sys/ deployprobe.g
M280 P3 S10 I1Editing 0:/sys/ retractprobe.g
M280 P3 S90 I1You're telling the firmware you're using heater pin 3 here, but you have freed up heater pin 7 in your config.
What pin are you actually plugged into?
M280 P should match that pin number.
her are some pics of the board
you are aware that you have a clone board?
i didnt realize that.
I just checked and found out it turns out my buddy replaced the board in the robo with this one and is planning to put the original in a cr10-s -
So it looks like you are connected to the heater 3 pin.
So you need to change your config.g to free up pin 3 with
M307 H3 A-1 C-1 D-1
And then in your config-override make sure you don't have an entry for M307 H3.
Then your deploy and retract macros should work. Test with M401 and M402
unfortunately its still not responding. the light is on and it triggers up and down when i power the machine on however for some reason m401 and m402 are doing nothing
@sleepless
check the cable. the extension cable of the bltouch are known to cause problems sometimes. -
checked the wires and everything is fine no open lines
This is a real head scratcher -
Can you repost your config files as they currently stand?
; generated by RepRapFirmware Configuration Tool on Sun Oct 28 2018 16:32:40 GMT-0700 (Pacific Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 PRobo3d_R1+ ; Set machine name
M551 Psafety13 ; Set password
M552 S1 ; Enable network
M587 S"elvis" P"honeynut" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M350 X32 Y32 Z32 I0 ; Configure microstepping without interpolation
M350 E16 I1; Configure microstepping with interpolation
M92 X160 Y160 Z1600 E415 ; Set steps per mm
M203 X30000 Y30000 Z300 E1500 ; Set maximum speeds (mm/min)
M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X15 Y15 Z0 S1 ; Set axis minima
M208 X230 Y254 Z200 S0 ; Set axis maxima; Endstops
M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
M574 Z1 S2 ; Define Z to use Probe. Home to Min; Z-Probe ;
M307 H3 A-1 C-1 D-1
M558 P9 F100 H5 R0.2 T6000 A5 B1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
G31 P9 X30 Y12 Z2 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
M557 X15:240 Y15:230 S30 ; Define mesh grid; Heaters
M307 H0 A134.3 C404.8 D0.4 B0
M143 H0 S110 ; Set temperature limit for heater 0 to 110C
M143 H1 S300 ; Set temperature limit for heater 1 to 300C
M501 ;
M107 P0 S0.6 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
G31 P9
That should be P25 for the trigger sensitivity. Not sure if that will make a huge difference.
You say M401 and M402 aren't working, but it is doing the self-test when you turn it on.
What is in your deployprobe.g and retractprobe.g macros in the sys folder?
retractprobe.g
M280 P3 S90 I1deployprobe.g
M280 P3 S10 I1correct m401 and m402 do not work
ok i changed the p9 to p25 and now m401 and m402 work
Thanks alot for your help
that makes no sense. the P parameter is the sensitivity for triggering. it has no effect on the M401 and M402 commands
well if it makes you feel any better even though m401 and m402 commands work when i home z it doesnt trigger
There's a break in your white wire at some point.
ill take your work for it but when i test it with a multimeter it seems to be solid.
Can you create a brand-new very short wiring harness to test with?
