Printing Clay at the Resolution of Plastics
@jhonf441 Hello again, I maybe made that sound more complex than it is, here goes again:
In my slicing program under filament diameter I use a value of 50mm.
Also in the slicing program, I set the nozzle diameter for the printer to 1mm.The slicing program knows from these settings just the right rate of speed at which to advance the plunger through the syringe, because I have an extruder e-step value that is accurate. If I send a command to extrude 10mm the plunger moves downward 10mm.
Many other tweaks can be made, such as "flow multiplier" in the slicer, or realtime extruder motor adjustments in the Duet web interface for fine tuning.
The speed of the auger in my tool can be adjusted independently as well in the Duet web interface. However, the auger isn't really pulling the clay through the feed tube, just helping avoid lag or oozing.
I hope that makes more sense.
