Inconsistent Extrusion?
In that case, have you tried with M566 P0?
@phaedrux Yeah, it was main setting at the beginning.
Which slicer are you using?
@phaedrux Idea Maker. But I was trying also Cura and S3D. Every slicer produced similar problems.
Hi again!
The parts have come yesterday and I have rebuilded and recalibrated my extruder. Also, I have switched to relative extrusion and x128 microstepping which I think helped a bit. Here are the results:
As You can see its much better and almost perfect. Almost, because now new lines have appeared. From my research I know that it's related to stepper settings. Changing TBL and TOFF had impact on this pattern. The question is does somebody made this lines disappear on TMC2660? I know that on prusa printers they can modify stepper waveform to make it disappear, but is there a fix for us, Duet users? I'm already on 0.9 deg motor with titan Aero.
@petrzmax said in Inconsistent Extrusion?:
Hi again!
I would try increasing or decreasing the stepper current a bit and see if that helps. You could also try to play a bit with the voltage regulator on your power supply , that changes the magnetic fields to be less ... interfering maybe and maybe gets rid of it.
Can you explain what you did when when you rebuilt the extruder? I´m chasing similar inconsistent extrusion problems to what you had before.
