Ooznest Workbee Duet3D as printer
Ooznest CNC kit uses Duet3D. Anyone use CNC kit like Workbee 1515 with Duet3D as a 3D printer?
@jzagaja @Ryan-Lock may be able to comment! There is no reason it would not work - but the hardware is optimised to machining not 3d printing.
@jzagaja There is nothing stopping you from doing it as the Duet can control a 3D Printer. But i always advise to have a separate CNC Machine and 3D Printer. The mechanical hardware isn't designed for a 3D Printer. And 3D Printers need to be clean, CNC Machines are far from anything clean
7h7 makes multitool printers. Previously they used Smoothieware, now Duet.
What are possible heating element voltage and power for DIY pellet extruders?
