Piezo as Z Endstop & as Z-Probe config
Which M561 do you mean? I have that in there because I wanted to make sure I cleared out baby-stepping in the case I forgot to clear it.
Perhaps this is the source of my issue? How do you clear baby-steps?
here is my heightmap from different views-
So the z motors don't move at all if you move to that dipped area?
typically, i stay away from that area if i can.
i will scale the stl you linked and print it over the whole bed.
i have a print finishing now- it might be a couple of hours before i can post results.
thanks again for your tutelage.
the compensation does work as expected. i have been trying to straighten the bed little by little by taking it off and giving it a good, strategic hammer blow or two.
sinneD
@sinned6915 nothing wrong with a little percussive maintenance now and then.
"percussive maintenance"
Lovely!
