Strange Printing Defect! Please Help,
@alexander-mundy
I agree wth alexander.
I had a similar problem with my old flex3drive.
I had to change the cabledrive and the bearings. -
@alexander-mundy I have contacted the guys at zesty earlier today and await their reply.
Config below:
; Configuration file for S.H.I.E.L.D. Printer (by James Lawes)
;Date Mofidied: 03-2-19; Communication and General
M83 ; ...but relative extruder movesM667 S1 ; Switch to CoreXY mode
M111 S0 ; Debugging off
G21 ; Work in millimetres
M555 P2 ; Set firmware compatibility to look like Marlin; WIFI
M550 PSHIELD ; Set machine name
M540 P0x60:0x01:0x94:0x0C:0x54:0x28 ; set MAC address
M552 S1 ; Enable network and acquire dynamic address via DHCP
M554 P192.168.1.1 ; Set gateway; *** PanelDue Touch Display
M575 P1 B57600 S1 ; Assign serial channel #1 (P1)
; Set baud to 57.6k and only accept commands
; valid with checksum (parameter S1); Drives
M569 P0 S0 ; X Motor runs forwards
M569 P1 S0 ; Y Motor runs forwards
M569 P2 S1 ; Z Motor runs forwards
M569 P4 S1 ; E Motor runs forwards; Movement
M906 X800 Y800 Z800 E600 I60 ; Set motor currents (mA) and motor idle factor in per cent (tweaked for motor temps)
M201 X4000 Y4000 Z12 E240 ; Set accelerations (mm/s^2)
M203 X8000 Y8000 Z240 E2750 ; Set maximum speeds (mm/min)
M566 X400 Y400 Z20 E30 ; Set maximum instantaneous speed changes (mm/min)
M84 S30 ; Set idle timeout; Stepping
M350 X64 Y64 Z16 E16 I1 ; Configure microstepping with interpolation
M92 X320 Y320 Z400 E2820 ; Set steps per mm; Pressure Advance
;M572 D0 S0.7; Axis Limits
M208 X-15 Y-10 Z0 S1 ; Set axis minima
M208 X315 Y290 Z300 S0 ; Set axis maxima; Endstops
M574 X1 Y2 S1 ; Define active high microswitches; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z1.6 ; Set Z probe trigger value, offset and trigger height
M557 X40:280 Y40:280 S55 ; Define mesh grid; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S110 ; Set temperature limit for heater 0 to 120C
M305 P1 X501 R4700 ; Configure PT1000 for heater 1
M307 H1 A505.6 C174.5 D6.6 S1.00 V24.3 B0
M143 H1 S290 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S1 I0 F500 H1 T40 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S0 I0 F100 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F1 ; Define Tool 0
M572 D0 S0.03M564 H0
M501T0
@syko_symatic I had prints (pla) looking the same but it was not all over the complete height. For me it was the first ~10 layers.
It was caused by a too low temperature+to high fan speed. I had to print this pla at 225° with lower fan speed and the "texture" disappeared completely. -
I returned my nimble for the same situation. This printer printed perfectly before the nimble and perfectly afterwards, and it was calibrated according to their instructions. There was nothing wrong except that nimble. I will say they were helpful and good to work with, but I will also say this post above shifting blame to the users other components does rub me the wrong way.
@syko_symatic said in Strange Printing Defect! Please Help,:
; Pressure Advance
;M572 D0 S0.7Very low extruder jerk and very high pressure advance can lead to some odd side effects. I'm not super familiar with the nimble, but I realize they recommend low jerk due to the worm gear drive?
If you're running firmware 2.03 You could try enabling the new jerk policy setting with M566 P1 and see if it makes a difference. It's a long shot, but worth a try.
Looking at the pictures though it definitely seems like some sort of extruder eccentricity.
@phaedrux extruder eccentricity? Never heard that term before? Could you give me a quick run down on it?
@syko_symatic A gear or something in the path that transfers the rotation of the motor to the gear that pushes the filament is out of true. So instead of consistent motion there is pulsing, or vibration, or extra drag/friction. Some mechanical action causing the pattern you see.
Have you tried printing larger objects yet? Circles? Diagonals?
@phaedrux diagonals, yes, circles no.
With the nimble what could actually cause that eccentricity?
I imagine that would be the tolerance stacking they mentioned in that copy and paste above.
Doesn't look like an eccentric gear or loose bearings/case/hob shaft due to the tight spacing. I had an undersized hobb shaft and the effect was more spread out. Looks more to me like cable/stepper side problem. What is your minimum cable radius? Can you detect any slapping of the cable against the sheath? Re lube, I use 20K diff lube and it works fine. Others I have heard using 10K to 100K.
Oh, another thing to check is that the end of the cable is all the way down inside the worm gear.
@phaedrux said in Strange Printing Defect! Please Help,:
Honestly the low jerk / acceleration was the biggest hurdle for me. I almost gave up but I hunted for low inertia / fast steppers. I found that 3.6 degree parallel disc magnet steppers from Portescap (P430 258 005 01 with the coils wired parallel) allow for some serious extruder acceleration and jerk. As a test I have tried up to 100mm/s retraction without any problem even with the 30 to 1 gearing. Be sitting down if you look that stepper up though. Fortunately I got them used for less than 10% new price.
Spoke quickly to Brian from Zesty Tech over email. He suggested a few things which have improved the quality but still not quite there 100%. May be having a call with him tomorrow.
One thing I have mentioned to him though, the worm gear seems much looser in the bearing on one end, I am not sure if this is intentional but may be an issue?
If anyone can suggest anything to improve this result further I am all ears....
This post is deleted! -
@damianm reducing the extruder acceleration to 1000 did wonders to be honest. I will have to check a few other slicer settings and esteps to see if I can improve on the finish I am currently getting.
It's good but now as good as I got from it on my previous printer.
@syko_symatic That looks like it might be related to the loose fit at one end of the worm to me. It is similar to what I got when a bearing was getting worn out.
Jammed some paper in between the looser end on the worm gear and the bearing and it seems to have helped. I have ordered a new nimble (as they have a slightly improved version now) so maybe I need to get a replacement worm gear? I will have to measure it first and see if it was manufactured incorrectly.
@Syko_Symatic Thank You!
