Possible Reprap Configurator Bug
It seems like I can't continue after adding heated bed in Reprap configurator, both happened in Chrome and Firefox latest version. It works when I unchecked heated bed.
Possible bug? or I did something quite not right here? @chrishamm
Thanks,
Cookie -
Did you do anything particular? I cannot reproduce this problem.
@cookie I just cleared the site's cache after my latest updates. Please try to reload the page, enter your config again and confirm that the problem still exists.
@chrishamm I already found that the problem occurs only when I loaded an existing configuration, which was previously saved with heated bed 'unchecked'.
Also, I've noticed that the Semitec 104-GT2 value is confusing. The preconfigured in RFF is β: 4388 K while the Wiki stated it is 4725 K here.
Thanks,
Cookie -
Thanks, I'll fix the beta value again - looks like I undid a fix I made a while ago. 4725K should be correct with that C value and 4388K seems OK without the C value.
Can you upload your config.json so I can try to reproduce the bug on the heaters page? I tried to reproduce the problem you reported but it worked for me.
Edit: The Semitec thermistor values are fixed again.
