DueUI Release 1.0.0-beta3 is now available
https://github.com/gtjoseph/DueUI/releasesPolling updates
- Refactored polling to be more friendly to the Duet by not sending requests for multiple response levels in quick succession.
- Updated the default intervals to 1000ms for level 1, 0 (disabled) for level 2 and 5000ms for level 3.
Fix Print Progress bar and paths in ncftp_push.sh
- The print progress bar was using the wrong method to set the current percentage.
- ncftp_push.sh needed to have the source path updated.
Enable localStorage in WebView
- The Android app's WebView settings didn't enable localStorage which is now needed to store DueUI settings since we stopped using cookies.
You can test this release before installing it by visiting:
http://dueui.org/test/index.htmlNOTE: You do NOT need to reinstall the Android app for new releases unless specifically instructed. The app automatically picks up any changes you make to your DueUI installation.
DueUI 1.0.0-beta4 is available for testing.
https://github.com/gtjoseph/DueUI/releases/tag/1.0.0-beta4
http://dueui.org/Added a Heightmap Heatmap display
A new widget "heightmap" has been added that grabs /sys/heightmap.csv
from the Duet and creates a simple 2D heat map and statistics. -
dueui_config_default.json was updated with a new "HeightMap" page
inserted between Movement and Console.I'm somewhat embarassed by the implementation but it does work
and it doesn't require any new third-party libraries.
Fixed issue where GCode responses weren't being shown
GCode responses for long running commands (like bed levelling)
are now being displayed correctly. -
The "get_reply" parameter of the "gcode" action is now ignored
since all gcode replies are automatically displayed.
Here's a sample of the HeightMap:
@gtj0 said in DueUI 1.0.0-beta4 is available for testing:
Nice, but there is a speeling error
@stephen6309 said in DueUI 1.0.0-beta4 is available for testing:
It was an April Fool's joke.
So if we choose the option of having the software on the DueUI website, it will automagically be updated as changes are pushed out?!
Thanks for your work on this, as a chronic early adopter I look forward to taking a run at it!
Pat
@bearcattd said in DueUI 1.0.0-beta4 is available for testing:
Pat
Yep. A new version will be up tomorrow in fact.
DueUI 1.0.0 is released!
http://dueui.orgMenubar Improvements
You can now add a "button_defaults" parameter to the "menubar"
widget to set things like common styles."menubar": { "id": "dueui_menubar", "type": "panel", "enabled": true, "button_defaults": { "style": { "margin-right": "5px" } }
You can now add a "menubar_button" parameter to "tab_panel"
panels to set custom styles for a menubar button."id": "dueui_panel_main", "type": "tab_panel", "enabled": true, "menu_button": { "value": "Main", "style": { "background-color": "yellow" } }
Fix handling of "macro" action
The macro action was double-prepending macro names with "/macros"
Now the "macro" action can take EITHER a "file" or "macro"
parameter. If "file", you must supply the full path to the
macro file such as "/macros/mymacro". If "macro", you must
supply a file name relative to the "/macros" directory such as
"mymacro" which will automatically be converted to "/macros/mymacro".
Added "message" parameter to gcode action
- You can now add a "message" parameter to a gcode action
to display a message in the console window when the action
is executed.
Fix heightmap auto-refresh
- The heightmap widget was listening to the wrong event to
detect when a mesh probe was completed.
Add new "cgi" and "http" actions
You can now use "cgi" as an action to run one of the built-in
Duet CGI programs like rr_delete, rr_move, etc. -
You can now use "http" as an action to execute any HTTP GET
you like.
Examples: "actions": [ {"type": "cgi", "cgi": "rr_delete", "params": "name=/sys/heightmap.csv", "message": "Heightmap deleted"}, {"type": "http", "uri": "http://any.url.com?someparam=ZZZ"} ]
Fix autocomplete results showing all entries
Send M115 after connecting to get firmware info
Correct the description of the 'Simulate GCode' settings button
Fix typo in heightmap legend low character and spacing in stats
@gtj0 looking really good in the screen shots. Tried to load it from the http://dueui.org/ but CORB is not allowing connection.
VM21:1 Cross-Origin Read Blocking (CORB) blocked cross-origin response http://192.168.4.20//rr_connect?password=reprap with MIME type text/html. See https://www.chromestatus.com/feature/5629709824032768 for more details.
looks to be a feature of Chromium rather than an issue with DueUI, just wondered if i was missing something obvious?
@t3p3tony said in DueUI 1.0.0 is released!:
Hmmm. I tried Chrome, Chromium, Firefox and Vivaldi all without issue. Is it possible that the build of RRF you're running isn't sending the
Access-Control-Allow-Origin: *
HTTP header? -
@gtj0 thats indeed very possible! I am DWC 1.22.6 & 2.03beta3 on that particular printer - what are you using?
That's exactly what I'm using. @gtj0 scratches head.
If you have a few minutes to troubleshoot, could you right click and "Inspect", then select the "Network" tab, then refresh. If you then click on the request. You should see something like the following...
Do the response headers have the
@gtj0 I don't think the request is getting as far as the Duet to get a response:
DuetUi tries but i think my browser is saying no!
@t3p3tony OK, I've enabled CORS on the google storage bucket so let's see what that does.
Give it a shot when you get a chance. -
@gtj0 said in DueUI 1.0.0 is released!:
Give it a shot when you get a chance.@T3P3Tony Did you ever get a chance to test after I set up the CORS stuff on the storage bucket?
DueUI 1.1.0 is released!
https://github.com/gtjoseph/DueUI/releases/tag/1.1.0
http://dueui.orgUpdate version for Android App
- There are no functional changes to the app itself.
Make reconnecting to the Duet more resilient
- Decrease poll timeouts to ensure timely detection of disconnects.
- Increase number of reconnection attempts before fatal failure.
- Increase time between retry attempts.
- Refresh on successful reconnect.
- Fix connection listener event names.
Added "Reset Fault" and "Tune" to header widget menu.
- You can now reset a heater fault and start tuning on a heater
using the currently set active temperature directly from the
heater widget's drop down. Actually, you always could do this
if you specified your own "state_commands" on a heater widget
but they're there by default now.
Remove references to old 'dueui-' classes
New File List Widget
- The original file grid widget was just plain ugly and not very
easy to use. Although it remains for backwards compatibility,
the new file_list widget looks and works better. See the example
in the dueui_config_default.json file for more info.
Add ability to remove default classes
- If you have a widget that you need to remove a default class from
you can now use "-classname" in any "classes" widget attribute.
For example if you have "button" widget but you don't want it to
look like a button and want to add some other class, you can
say "classes": "-btn someotherclass" to remove the default
bootstrap btn class then add your own.
WARNING: You MAY have to update some of your widget definitions
to keep some custom classes. For instance, if you previously set
"classes": "btn btn-secondary" on a button widget, you may need
to change it to "-btn-primary btn-secondary" to remove the
default "btn-primary" class.
Fix file/macro lists not fully populating
- When there are lots of files in the /macros or /gcodes
directories and the Duet can't allocate enough memory to
return them all in one reply, it returns a "next" parameter
to indicate that the client should make another request
to get the remainder. We were ignoring the "next" parameter
so the lists were short. We now check the "next" parameter
and continue retrieving files until there are no more to
retrieve.
Minor UI tweaks
- Add DueUI version info to log and settings panel.
- Slight refactor of gcode echo to log.
Thanks for this. Attached is a screenshot of my first draft of a single page version for a 22 in monitor. This is the shot from a windows 10 machine that has moved the elements around a bit compared to the active version. (Both in Firefox). The "production" version is running on another PC running Arch Linux with xampp with 2 virtual servers - one for each of my 2 printers.
I have an idea to also have a minimalist version running on the Duet using an Android Tablet as the client. As long as this doesn't overload the Duet as I also will need the DWC running in the background for other functions.
I have included 2 baby stepping sections which I thought to be useful for me. I wrote 2 widgets added to dueui_widgets.js. The stepping widget works (wonderful for a person that knows no javascript) but the widget for displaying the babystep "position" requires your assistance (see next post). ie display "M290 " z output.
The issues:
... The sense endstops widget doesn't work and this is of course critical.
... The Extruder temp control won't turn the heater off.
... I haven't yet worked out how to style the heater widget as the temperatures are very close to the up/down arrows.
... How do I style the console log to have a larger default height?So far I haven't used it other than preliminary testing until the sense endstop is fixed.
A babystep widget that works.
A babystep_position widget (a display of complete ignorance).
0_1562725404394_baystep_position.txt
The json code.
There is an lpc1768 processor port of duet reprap firmware over on the reprap forum.
https://reprap.org/forum/read.php?147,810214,page=1
For some boards they are limited to the old 0.x dwc
Are there any special requirements for interfacing with the board and serving up web pages with this interface compared with dwc 2.0? -
@garis I have the sense endstop working now by modifying the widget and the corresponding lines in the json file and also a separate jog widget for E. So far so good and I can now use it.
@4lathe said in DueUI 1.1.0 is released!:
Are there any special requirements for interfacing with the board and serving up web pages with this interface compared with dwc 2.0?There shouldn't be. We use the same basic commands.
