G28 Z Error
Have homex, homey and homeall working perfectly, and homez works but delivers a G28Z error.
When I individually home x and y, then z, the z will home but the error message pops. Searched and tried some different parameters, but just can't figure this out.
I did not uncomment the last lines of Z probing because G30 does "lift Z" as it finishes.homey is same format as homex:
; homex.g
; called to home the X axis
G91 ; relative positioning
G1 Z3 F1800 S2 ; lift Z relative to current position
M913 X70 ; current to 70%
G1 S1 X305 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 X-5 F6000 ; go back a few mm
G1 S1 X305 F360 ; move slowly to X axis endstop once more (second pass)
M913 X100 ; current to 100%
G1 Z-3 F1800 S2 ; lower Z again
G90 ; absolute positioning
G1 X290; homeall.g
; called to home all axes
M913 X70 Y70 Z60 ; reduce stepper currents
G1 S1 X305 Y305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X-5 Y-5 F1800 ; go back a few mm
G1 S1 X305 Y305 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 X150 Y150 F6000 ; go to first bed probe point and home Z
M913 X100 Y100 Z100 ; increase current to 100%
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning.; homez.g
; called to home the Z axis
G1 Z3 F1800 S2 ; lower bed relative to current position
G4 P1000 ; ensure time for bed drop
M913 Z60 ; reduce current to 60%
G1 X150 Y150 F6000 ; go to first probe pointG30 ; home Z by probing the bed
M913 Z100 ; increase current to 100%; Uncomment the following lines to lift Z after probing
;G1 S2 Z3 F1800 ; lift Z relative to current position
;G90 ; absolute positioning -
What is the error?
Does it still happen if you remove the G4 P1000 pause? That shouldn't be necessary, it should wait for the Z move to complete before moving on to the XY move.
The error message...pink box... just reads "G28 Z Error: Bad command"
Is there more info somewhere else?
I'll remove the pause.
Thanks. -
@danl said in G28 Z Error:
.; homez.g
Just noticed that there is a period before the semicolon. Does that exist in your macro file as well?
yep...just looked. Geez, this stuff is touchy.
I'll drop the G4 and the period and test in about 5 minutes.
Thanks. Wow...really great catch. -
Solved....whoa...just one little dot.
Thank you.
