    Dc42 ir probe on the way
    3.2k
    • Torroundefined
      Torro
      Some question about that ir probe.
      CoreXY, e3d v6 lite (New heater Block)
      1. My try for config.g
      Endstops
      M574 X1 Y1 S0
      Z-Probe
      M574 Z1 S2
      M558 P1 H5 F120 T6000
      G31 P500 X0 Y-xx Zxx (have to measure)
      M557 X10:230 Y10:210 S20
      Is this correct?
      1. What about the x/y offset @ g31 and M557, do i have to calculate it?so when y offset is - 20, y min has to be 30 @M557 or is that calculated by duet and my nozzle is at Y30 when M557 wants to probe at Y10?
      2. What is M376? I don't get it. Google translate didn't helped. Do i need that? What is it good for?
      Thanks!
        Phaedrux Moderator @Torro
        @torro said in Dc42 ir probe on the way:
        That's right. If you have it set so that the M557 has probe points that lay outside the reachable area it will skip them, but you can better maximize the grid layout by doing a little math yourself.
        M376 allows you to set how far you want bed compensation to continue up the print vertically. So if on the first layer you need 0.2 of adjustment, and you set the taper height to 5mm, it will reduce the amount of adjustment every layer until 5mm where it would stop adjusting. Depending on how your bed is unflat you may want to have some taper, or you may not want it at all. If it's the bed surface that has a slight dip, you can taper off and be fine, but if the unflatness of the bed is actually due to sag in the gantry you would want to have no taper so that the sag is corrected for the entire print. I hope that makes sense.
        • Torroundefined
          Torro
          Ok, got it. Thanks a lot!
          • Torroundefined
            Torro
            Hi there,
            I just installed the mini IR probe. Mounting and cables was no problem.
            Now, i have a problem to set the trigger height.
            I followed those manuals:
            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
            https://miscsolutions.wordpress.com/mini-height-sensor-board/
            home Z -> M564 S0 -> moving slowly -Z until paper is gripped -> G92 Z0 -> move Z10 -> G30 S-1
            i get a trigger height of 0.46 to 0.48mm. i put this in the G31 command as seen here:
            Endstops
            M574 X1 Y1 S0
            Z-Probe
            M574 Z1 S2
            G31 P500 X0 Y50 Z-0.45
            The problem is, that after homing, i have again an offset of -0.45mm.
            home Z, paper is loose, Z-0.45 per baby stepping paper fixed by the nozzle.
            Should i try a G92 Z0.45 in the homeZ/homeall.g files?
              @torro A negative trigger value would usually only apply to contact nozzle probes that actually touch the bed to trigger.
              Try G31 Z0.45.
              You should be homing Z with a G30 movement in your homeall.g. Do not use a G92 Z0.45 The G30 will determine your height.
              • Torroundefined
                Torro
                seems to work thanks a lot!
                now, i have to figure out, where i need to change that (macros etc...)
                one last question (for today... 😉 )
                after G30, the bed moves to Z5.45
                why? i think i know, where .45mm comes from, but who adds 5mm more?
                  @torro Post your homing files.
                  The extra 5 is probably your dive height from M558. After probing it returns to this height. The 0.45 is your trigger height, because that's the distance from the bed when it triggered.
                  To verify your height from the bed, send the nozzle slowly to Z0 at the same XY position the G30 was done. The nozzle should stop just touching the bed.
                  If the nozzle is too high or too low, adjust the Z height in small increments until it's just touching. Now you can use that value to fine tune your G31 Z offset.
                  • Torroundefined
                    Torro
                    this is homeall.g
                    G91 ; relative positioning
                    G1 S1 X-300 Y-300 F5000 ; move quickly to X or Y endstop and stop there (first pass)
                    G1 S1 X-206 ; home X axis
                    G1 S1 Y-300 ; home Y axis
                    G1 S1 X-206 F360 ; move slowly to X axis endstop once more (second pass)
                    G1 S1 Y-206 ; then move slowly to Y axis endstop
                    G1 S1 Z-300 F3000 ; move Z down stopping at the endstop
                    G1 Z4 F200 ; move slowly 4mm in the +Z direction
                    G30 X120 Y110
                    G90 ; absolute positioning
                    • Torroundefined
                      Torro
                      i have problems to get the compensation to work.
                      i created the heightmap
                      added a G92 S1 to the start script of s3d
                      M106 P0 S0 ; Stop Part Cooling Fan
                      G28 ; home all axes
                      G29 S1 ; load heightmap
                      G91 ; relative mode
                      G1 E52 F400 ; Fill Nozzle
                      G90 ; absolute Mode
                      M572 D0 S0.1 ; Pressure advance
                      and get this result:
                      you can see that it´s somehow similar. i have no idea what to do next.
                      config.g:
                      M92 X80.00 Y80.00 Z160 E420.00 ; Set steps per mm
                      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X20000.00 Y20000.00 Z4000.00 E4000.00 ; Set maximum speeds (mm/min)
                      M201 X1000.00 Y1000.00 Z1000.00 E10000.00 ; Set accelerations (mm/s^2)
                      M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S300 ; Set idle timeout
                      M208 X0 Y-1 Z0 S1 ; Set axis minima
                      M208 X240 Y222 Z278 S0 ; Set axis maxima
                      M574 X1 Y1 S0 ; Set active high endstops
                      M574 Z1 S2
                      M558 P1 H5 F120 T6000 A3
                      G31 P500 X0 Y50 Z0.4
                      M557 X20:220 Y70:220 S20
                      homeall.g
                      G30 X120 Y110 <- That´s NOT working it probes at X/Y min
                      • aidarundefined
                        aidar
                        You better send probe to X120 Y110 by G1, so
                        G1 X120 Y110
                        G30
                        Torroundefined 1 Reply Last reply Reply Quote 0
                        • Torroundefined
                          Torro @aidar
                          @aidar said in Dc42 ir probe on the way:
                          G1 X120 Y110
                          G30
                          done & works! thanks
                          i took the G29 S1 out of the start script. before starting the print, i activated the mesh per DWC "compensation&calibration". so it says "compensation in use:mesh"
                          i printed a cube with 180x180mm and observed the z motors. they stand still.
                          • Torroundefined
                            Torro
                            tried this start script:
                            G28 ; home all axes
                            G29
                            G91 ; relative mode
                            G90 ; absolute Mode
                            same problem, the first layer looks like on the picture above.
                            DWC says "mesh in use"
                            • aidarundefined
                              aidar
                              Well, seems we have to start from basic: what version of firmware you use?
                              • Torroundefined
                                Torro
                                Duet Web Control 2.0.0-RC3
                                Electronics: Duet WiFi 1.02 or later
                                Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.02(RTOS) (2018-12-24b1)
                                Duet WiFi Server Version: 1.22
                                  What does a print look like with mesh disabled?
                                  • Torroundefined
                                    Torro
                                    5 minutes please
                                    • Torroundefined
                                      Torro
                                      it´s the same. left side (Ymin) so close, that there is no layer, right side (Ymax) so far away, that the layer doesn´t stick to the bed
                                        Try reducing the Z acceleration from 1000 to 100. I wonder if it's trying to compensate but trying to move too quickly and not moving at all due to binding.
                                        Does the Z axis move properly otherwise?
                                        • Torroundefined
                                          Torro
                                          Z axis works fine.
                                          tested with acceleration 100, same behavior
                                          • aidarundefined
                                            aidar
                                            Have you tryied manual bed leveling?
                                            https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
