AM8 config issues - cannot home any axis
I just got my Duet Wifi setup as a CoreXY and its doing the EXACT same thing! I can open Pronterface or Simplify 3D and move the axes in any direction, but when I home any of them it moves Z up and down and X or Y moves only a few millimeters...what is the issue?
And if I try to home Z it just goes up and down once or twice...
Ok. Z motors run ok now that they are not in series anymore.
Homign does not work at all though. Homing X and Y moves Z axis still.
Homing Z axis runs the axis down into the switch that does not work and it keeps on running intothe switch - the switch actually died broke this.0_1545766351395_config.g -
thats why dc posted the link. use the m119 command to test each endstop manually first.
@veti
Yeah makes sense. But can you see faults in the config.g?
I am far from anything workable. The hotend throws out a fault. The fans have no power (allways on fans as well - 12V fans, 12V PSU).
No endstops. A moving Z axis when tryign to home X or Y. I don't even know where to start really.I never had trouble with marlin but this leaves me puzzled.
So, unless you have also changed the lead screw then your steps/mm for Z are 10x too high. They should be set to 400.
Also your steps/mm for X and Y are too low if you did not replace the pulleys by 20T versions. Original Anet A8 has 16T resulting in 100 steps/mm.
Then there is no endstop for Z configured at all. And the one for Y is set to active high where default Anet wiring of the endstop is active low.
The original Anet motors run on Z in series - that's how I had mine running for months also with the original 12V PSU.
M574 Y1 S1 ; Set active high endstops
M574 X1 S3 ; Set endstops controlled by motor load detectionNormally the a8 switches are NO if i remember correctly. You configured NC for Y.
X is stall detection and not via switch. Is that correct?Check the wiring on the fans. if you swapped them the wrong way the fuse might be blown.
See https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
. If you connect the fan the wrong way round, you may damage the fan, the Duet, or both. -
Thanks a lo. I will look into it. The Endstops were the wrong way round. Fault number one solved as well.
Sorry for my stupid questions. I am new to this. I thought the basic config of RFF config tool will get me somewhere. I found no basic values to start with for the anet.X stall detection is because one switch died. I just fixed it though - back to endstop.
@thoemse The easiest way to get the correct values is the use Marlin's appropriate
Configuration.h
andConfiguration_adv.h
. These have all the working values in there.But this reminds me again that I wanted to create a template for Anet A8 in RRF Configurator. But that will probably only happen at the beginning of next year.
@wilriker
Changed steps. Thank you.Edit: Fantastic. Making progress. All endstops working. Axis are homing.
Now On to the hotend and the no power on fans issue. I shall read up on it first though. I went at this a bit to unprepared.Thanky ou very much btw. I am starting to get the hang of it.
Fixed the fan. I got an issue with z homing. It tries to home on top but I got a min Z endstop.
Considering it lifts z correctly before homing X and Y I think the Z axis direction should be correct.I've added the z homing file.
I am sorry for all the questions.0_1545818773565_homez.g
@thoemse said in AM8 config issues - cannot home any axis:
What happens if you issue the following commands?
G91 G0 Z5 H2 G90
It should move up 5mm. If it moves down then the direction is reversed.
Warning: this will try to move 5mm ignoring endstops.
Your
homez.g
looks good althoughG1 Z5 F6000 S2 ; lift Z relative to current position
is unnecessary and
;G90 ; absolute positioning
should rather not be commented out to avoid issues with anything expecting absolute positioning.
Thank you. I will try that.
I can't use thos commands. Insufficient axis homed. Only works after homing I guess? I managed to fix it now. All axis homing against endstop fine. -
Closing in to get it running. Axis Home. Endstops work. Fans work. Bed heats.
Only the hotend keeps bugging me.It's a 3d Freunde e3d Full Metal Hotend.
I get the error: Heater 1 fault (T0) - 2000°C
I tried the original E3D thermistor values. I tried the values that work for the 3D Freunde Hotend in Marlin (B 3950) but all I get is a heater fault.
The thermistor and heater are wired to E0.
Heatbed works fine. Pid tuning it right now.
before you try to heat the hotend see if the thermistor reads room temperature and changes by externaly heating it (hand body temperature)
Thermistor always shows 2000 C.
check that you have connected it to the correct plug, then measure the resistance of the thermistor using an ohm meter.
@veti
Thanks. Yep the Thermistor is dead out of the box. Plugged in a different one and it reads room temp.
I got some teething issues on this one.
Thanks. -
cut the cable at the crimp contact, and measure again. it might just be a bad crimp job.
Apparently the thermistor was screwed in too hard. The set screw put too much pressure on the wiring. It works now.
Pid tuning the hotend now. Weeee!
Sure had some hurdles on the way on this one but the DuetWifi really grows on me. I love the webinterface and the fact I can modify the config via interface - that's brilliant.
