Heater faults with numerous different heaters and thermistors
@foden last one tonight. Fan at 100% with hot end rotated 90%. I think he issue was fan related but not quite what we thought. Will test tomorrow with the same setup i have now, but think the fan was firing up too fast for the thermister/heater to cope. As i have the fan running now at 100% and the temp is holding perfectly
How did you have the fan set when running a PID tune?
@phaedrux I think the fans where off, hot end and bed, when i was running autotune, which i see, now, would be another contributing factor
Will re-run autotine with fan on and see what happens
@foden Update - bed fan would be off when i was running the hot end autotune. Hot end fan comes on automatically at 45C
@foden Sooo, when previously running the H/E autotune without the bed fan i got a heater too powerful and dropped the power value. After Phedrux query i re-ran the autotune with the fan at 85% and on full power I did not get the over power warning. I had no idea the bed fan would have such an impact on the H/E. I don't have that issue with my Maker Select IIIP (almost completely rebuilt running on RAMPS 1.4)
I now need to design a shorter, or stronger fan duct that won't droop and make contact with the print. Trying a very short one just for now
Thanks again for all that read my ramblings and helped out!
If you can, print your duct in ASA or polycarbonate. Quite a bit more heat resistant.
@phaedrux Thanks Phaedrux, haven't printed with either of those - will take a look
@foden ASA is close to ABS. Polycarbonate is another beast altogether.
@phaedrux As seems to be the way with all things 3d, find a fix for one issue and another pops-up. Just noticed my x carriage has a lovely crack in it :o(
Have to reprint and dismantle to get it replaced - sigh - oh well.....
Building a 3D printer is a never ending gift of projects.
@phaedrux LMAO - so true, so true my friend. I've learnt so many skills and other things I didn't know I needed to have that I can't believe I got this far in life without them
Thanks again everyone, my DuetWifi and HEVO are back in sync. Have put back my BLTouch to replace the Orion as it was ticking me off, once i get some better prints I mat put it back.
BLTouch is now dialed in and I just need to tweak the prints to stop extraneous links between parts - another self inflected issue I'm sure.
Not replacing the cracked carriage until it fails completely - it's a royal PITA replacing it and setting up again IMHO
Have made note to self that whenever I monkey around with the hotend and/or carriage I run an autotune, fan on fill, before i do anything else ;o)
