[not yet solved] Tevo Little Monster DuetWifi errors
Keep trying to solve all the issues:
1)Now, After calibration the head stay on one side close to the bed.
If i send a G28 for home all axis just the Z turn to home , the other 2 move just a little .
G28 Error: G0/G1: insufficient axes homed
In the WCC >>>Machine control>>> the home x and Home y are orange and I have to home twice for making finally home the other two axis.
I have seen this : https://forum.duet3d.com/topic/4782/error-after-upgrade-to-1-21/2
but i cant understand if this is the right direction to investigate..
2)When I restart the printer the wifi give an error in the console of the touchscreen :
Error : M587: Failed to add SSID to remembered list HTTP is enabled on port 80 FTP is disabled TELNETBUT after the calibration the wifi start to work properly.
Is not a big deal, is just for understand... -
Unfortunately I cant print a thing.
All the file printed stay on printing continuously on the 1st layer.
The gear of the extruder consume the filament in the same place because the filament cant be extruded.
It seems that the printer is unable to rise on the Z axis during the print
The extruder seems to work properly. I can extrude and retract the filament. But when I print the head stay on the first layer0_1537552075875_Tevo_LM_Duet_Adapter_v1.gcode
I know you've gone through a few guides but it kind of sounds like your motors aren't responding as expected.
Can you take a look at this delta setup guide and compare it to what you have?
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
Sure! I'll check your link and I will report here...
Is my first printer and is all new. I'm glad to learn new stuffs .
Could be as you suppose. All the guides are made for different motors from the original ones.
I changed just this:
M92 X80 Y80 Z80 E425 ; Set steps per mm , that were settled on x160 y160 z160 for the 0.9 motors. -
Phaedrux ,
I have read all the document you have linked. And for what i can see the data should be coherent.
The section where with the G91 command (for allow to move independent axis) to check if the motor work properly , is executed without errors. The motors seems work all fine.
If i move down the x axis G1 S2 X-10 it go down and vice-versa if I move up the x with G1 S2 X10 it go up. the other two axis go fine.I don't know if is a Slicer problem. Im using Simplify3D with settings i used with the original Tevo . I just changed the firmware section for add the RepRap configuration be loaded.
Then....
in the homedelta.g there is this line:
; Move all towers to the high end stopping at the endstops (first pass)
G1 X505 Y505 Z505 F1800 S1
and in the config.g there is this one:
M665 R155 L397.19 B155 H525 ; Set delta radius, diagonal rod length, printable radius and homed height
The 505 above should be far height than that?
In the kossel example with an height of 240mm volume the G1 command is settled on 320. If my printer have an height of volume of 525 how much i should add to 505?; homedelta.g
; called to home all towers on a delta printer
; generated by RepRapFirmware Configuration Tool on Mon May 22 2017 22:56:20 GMT-0400 (Eastern Daylight Time); Use relative positioning
G91; Move all towers to the high end stopping at the endstops (first pass)
G1 X505 Y505 Z505 F1800 S1; Go down a few mm
G1 X-5 Y-5 Z-5 F1800 S2; Move all towers up once more (second pass)
G1 X10 Y10 Z10 F360 S1; Move down a few mm so that the nozzle can be centred
G1 Z-5 F6000; Switch back to absolute positioning and go to the centre
G90
G1 X0 Y0 F6000 -
Nothing to do , also Cura (last version) produce the same thing.
The printer dont rise during printing on the Z axis. Stay on the same level all the time and the gear of the extruder consume the filament in same place blocking further extrusions.Suggestions?
tnx
It's just odd that the motors will move properly when commanded manually but not when printing. Can you verify the motor current while printing? Send M906 and then M913 without parameters in the console and it will report what the current is set to along with any percentage scaling. Maybe there is a rogue current reduction command happening somewhere.
M906
Motor current (mA) - X:1800, Y:1800, Z:1800, E:1800:1800:1800:1800:1800:1800:1800:1800:1800, idle factor 30%
M913
Motor current % of normal - X:100, Y:100, Z:100, E100
100
100
100:100
I tried different voltages for the 4 motors. Are all identical and the default should be 1.8.
I tried also 1200 and 1000. Nothing change.
I tried also the firmware 2.0 but didnt work either. Exactly same attitude as the 2.01.
The probe is settled well ,it perform a good calibration without errors reporting the graph of the surface. Of course not rising the z axis during the print generate a mess of plastic under the extruder.Im starting to feel a little sad...
There is something that can inhibit the Z axis rising during the printing?
@giostark can you post the code file you are trying to print
0_1537811866488_stab.gcode
0_1537812126970_Tevo_LM_Duet_Adapter_v1.gcode
Maybe those files and setting are not perfect but the first (stab) with the original motherboard was printed several time.
Im able to perform a "good" calibration without errors. For this reason I dont think is something related to the hardware. I settled the zprobe and the first layer is printed well. the second one come printed on the 1st and so on generating a mess of plastic.
This post is deleted! -
Well I notice 2 things from your gcode file. First, you don't have a G28 in there to home the printer, so if it isnt already homed when you start the print it may cause problems. Second, your Z moves are all negative.
My actual config.g:
Config.g
; Configuration file for Duet WiFi (firmware version 1.20 or newer)
; generated by RepRapFirmware Configuration Tool on Sat Jul 07 2018 15:37:48 GMT-0700 (Pacific Daylight Time); General preferences
G21 ; Work in millimetres
;M555 P2 ; Set firmware compatibility to look like Marlin;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
M665 R157 L397.1073 B175 H523 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them; Network
M550 PTEVO Little Monster ; Set machine name
M552 S1
G4 P1000
M587 S"----------" P"-----------"
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Drives original ones with 1.8 degree
M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
M906 X1800 Y1800 Z1800 E1800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops
M557 R130 S20 ; Define mesh grid; Z-Probe
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H5 F100 T2000 A5 R0.1 ; P9 for BLTouch, dive height 5mm, probe at 100mm/min, travel 6000mm/min, up to 5 probes, pause 0.1s
G31 X0 Y20 Z0 P25 ; Set Z probe trigger value, offset and trigger height
M557 R150 S45 ; Define mesh grid; Heaters
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H0 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings
M591 D0 C3 P2 E6.0; Filament Sensor - Add the following to config file anywhere before the M501 command
M591 D0 P1 C4 R20 ; configure extruder drive 0 to use E1 endstop (C4) with 20% tolerance
M591 D0 ; display filament sensor parameters for extruder drive 0; Miscellaneous
M501 ; Load saved parameters from non-volatile memory; deployprobe.g
; called to deploy a physical Z probe
;M280 P3 S160 I1
M280 P3 S10 I1; retractprobe.g
; called to retract a physical Z probe
M280 P3 S90 I1 -
Now every time I start a print I put the head in home by hand. Ill fix it.
Sorry , what you mean negative? and where? How should I set them properly ? -
@phaedrux the file I have checked have no Z Moves at all in fact the only Z character is at the start to zero the extruder no wonder everything is printed on top of each other it is as if the layer height has been set to 0
I was looking at the stab.gcode.
@phaedrux said in [help] Tevo Little Monster + DuetWiFi + DuetTouch7" errors:
Ah...ok
So what do you would insert as start script? -
@dougal1957 said in [help] Tevo Little Monster + DuetWiFi + DuetTouch7" errors:
Ok im facing with all my ignorance...so do you mean the same as Phaedrux?
@giostark at the minimum just g28
Can you post some screen shots of your slicer configuration?
I'll look at that next mine was the tevo_lm one
