Print Times - Layer & Filament Not Working
Is there something that needs setup to get the remaining time to work for filament and layer? The only one currently working for me is the file progress. I use Cura with Marlin code.
@tjb1 can you post the gcode file that is doing this? Is it all your files or just that one?
Why not use reprap gcode flavour?
@phaedrux said in Print Times - Layer & Filament Not Working:
I just started using Cura. I did find a post here that was 2 years old mentioning the filament timing not working on Cura and it was going to be added in 2.4? I believe. The print last night was spiralize/vase mode so maybe it couldn't get an accurate enough layer time to work. I will post a gcode file tonight but currently it is all of them.
I actually noticed the same thing, but with Simplify3D. It used to work, and I don't think I changed any relevant settings in S3D, but layer and filament have stopped working, somewhere between firmwares 1.2x and 2.x.
I am on 2.x and they are working with Cura 3.4 and slic3r but I temember reading somewhere that Duet takes the info from the gcode so it might be something in the slicer setup.
I sliced some things with Simplify3D last night and all 3 times were working.
@yonkiman said in Print Times - Layer & Filament Not Working:
If you're using S3D 4.0.0, upgrade to 4.0.1. There's a bug in the earlier version that can append a few megabytes of null characters to the end of the gcode.
See this post for more info: https://forum.duet3d.com/topic/5572/it-s-out-reprapfirmware-2-0-and-1-21-1-released/80
@garyd9 That's very interesting and I do have the garbage at the end of my S3D-generated gcode.
Downloaded S3D 4.0.1 and verified that all three print time estimates are working again. Thanks!
