Laser Filament Monitor - test results
And a second print with the cone-housing. Again slightly worse than the straight square open-window version.
I printed @T3P3Tony's housing with divergence today but when I tried to mount it I noticed that it does not fit. Has there been a rearrangement on the PCB at some point in time? Because the window for the sensor is much to far down. I took a photo with mounting holes aligned because they fit:
Left is Tony's design, right is my cone-shaped based on @dc42's version on Thingiverse.
@wilriker said in Laser Filament Monitor - test results:
Can I get a patent on this term - or better word-spaghetti?
@wilriker that is very odd - maybe i uploaded the wrong version i need to check this when i get a chance!
So, while porting @T3P3Tony's changes to get a diverging light path into my "fork" of @dc42's OpenSCAD file I went back to the original housing and now with the cleaned sensor this gave the best results so far. min/avg/max where about 2% above the average for all of these values.
I modified my Spreadsheet to include some color coding now. Green means greater or equal to the average in that column, red means below average.
The print that had this very good measurements was the new housing with diverging light path so I am going to switch housings again tonight.
@t3p3tony said in Laser Filament Monitor - test results:
I just checked the documentation page and the screenshots you exported from OpenSCAD on this page also show the sensor window being offset from the mounting holes.
Last test with black PLA is done and entered into my Spreadsheet. This was done with the diverging housing and it was a tiny bit below the quality of the default housing.
I now loaded grey PLA and also recalibrated my steps/mm (they were to low). I did not do this with the black PLA but I think this would only introduce a relative shift because all tests with black PLA were performed with the same steps/mm. I still have the diverging housing mounted and will use it to set a baseline for the grey PLA.
Added some results for the grey PLA now to my Spreadsheet. AVG and MAX values are somewhat consistent (among all results for grey PLA) though still wider spread than with black PLA. The MIN values however have an enormous range.
I will switch back to the straight housing tonight and see how this influences the results.
Hey, sorry, work has been busy for me, so I've only now had a chance to get back to printing. I'm still finishing off a run of parts I need that are in Spannerhands Yellow translucent PETG, which is a far cry from the Black PLA requested! Here are the sensor readings for that anyway:
M591 D1 Duet3D laser filament monitor on endstop input 4, disabled, allowed movement 30% to 100%, check every 3.0mm, current position 9.0, brightness 82, shutter 13, measured minimum -22%, average 30%, maximum 92% over 8353.5mm
Once these are printed, I'll get the black PLA running
@keyz182 You should print with whatever you just print. Only the sensor housing is supposed to printed in black PLA.
@wilriker As usual, I've misread something then! I really should pay more attention
Hey all, been a bit since I was here. Getting ready for our local MakerFaire but had the SD card on the Duet die today so I ended up with a pre-filament sensor backup config and had to come get the filament sensor running again.
Tony, wanted to share the results I do have, I haven't updated (completed all the columns) but it's a living document and will get updated from time to time. Hardest part is remembering to do a M591 before hitting print again. Doh. Feel bad I keep forgetting it. Hmm, maybe I need a sticky not on the PanelDue.
Anyways results doc is here:
https://docs.google.com/spreadsheets/d/1yy3DLxXhCFD81EiPyyuIEZaPnIgQgkvuVNcFQiZ7ceU/edit?usp=sharingTinkerz
@tinkerz said in Laser Filament Monitor - test results:
I put it in my end codes, so I cannot forget it.
I have a suggestion for the
M591
command. I did look at adding it myself, but having issues getting the firmware to build.The suggestion is two-part:
- Add a parameter to set the filament name going through the sensor
- Add a parameter to append data to a CSV file, using the set name as the first col.
That way, we can add start and end GCode in our slicer start+end code per filament. Start code would have the settings for that filament with the name, end gcode would then add data to the CSV file. That way, data gets built up over time without thinking about it.
@wilriker In your end codes you say, then where does the response show up? Is it on the console page of the WebUI or console of the PanelDue (output is limited to 100 chars so the real data gets cut off doing it here).
Thanks,
Tinkerz -
@wilriker disregard, wrote a quick gcode file and figured it out, comes out on the WebUI. Perfect. Adding to end scripts. Now we just need logging.
Tinkerz
I switched housing again to the cone-shaped interior one on Thursday night and printed something on Friday. At the end of the print the statistics looked awfully low and I was already blaming the housing. When I inspected the prints, though, it turned out the sensor was right. I had massive under-extrusions especially on one layer because my filament spool had fallen off the rolling spool holder and the friction was too high for the extruder to pull where lots of filament where required quickly.
So, now I decided to enable the sensor for the current filament though I am still testing. Let's see how often my prints will be paused.
P.S.: A third option for the sensor would be nice. Currently there is just
- ignore issues (but collect statistics) and
- pause the print on issue detected
I would like to see a third option where issues would just send a warning but the print still continues.
Hi All!
First, sorry it has taken me so long to join in on this thread! Life has been keeping me away from printing lately.
I am testing the monitor on a SeeMeCNC Artemis. As such, I designed a mount for it that attaches it directly to the EZRstruder. Here are a few pictures of the mount. I have only done one print with it, and everything seemed to work fine. I will get a spreadsheet going with my results. I will also upload the mount STLs to Thingiverse and drop a link here.
One thing that I realized after my first print, was that my mount doesn't have an enclosed side on the opposite side of the filament from the laser. On David's Thingy file it has a small extruded box there, but I didn't even think about that when modeling.
Well, there are photos there I think. I can't figure out how to do them I guess?!
Thingiverse Link: https://www.thingiverse.com/thing:3111798
@guyaros That looks great. actually during test on the filament we used etc we got the best readings at 9mm gap but that is not conclusive. worth trying a variety of gaps.
I'll print the first with 9mm then
I am designing my casing. Please, what is the recommended aperture angle for the sensor window/channel?
I remember reading it somewhere at this category but could not find it anymore.... Thanks!
