My custom Cartesian
@witchdoctr said in My custom Cartesian:
The Duet was a bit of a pain to configure after using Marlin but the first test benches turned out like a dream with your settings.
I'm glad that this helped you.
@OBELIKS Can you measure the length of your Anet stock steppers? I just measured the length of the newer 0.9A steppers and they are not 40mm but only 37.3mm long.
So compared to the 48mm long Wantai steppers (would you be so kind to measure their length as well?) that is an extra of over 10mm and I have a feeling that I will not be able to fit them everywhere.
@wilriker sure, tomorrow. I wrapped up for today.
Eh, I needed to fetch a beer from the storage. So I hopped in to the "workshop"
Anet steppers are 37,8mm long and Wantai real length is 46,8mm.
And the beer is imperial IPA with 10% alcohol. And it is brilliant. -
@obeliks said in My custom Cartesian:
Anet steppers are 37,8mm long and Wantai real length is 46,8mm.Thanks for that!
Will measure on the weekend of I can fit them. Biggest issue might be Y axis as my heat bed holder has only a certain width cutout for the motor.
I am all but a beer type but happy that you have something you enjoy.
If it's aluminum bed holder, just chop it.
@obeliks It is aluminium. Though, I have some concerns of messing with the statics of it if I chop it. But first I need to find out if it will be an issue after all.
OK, I looked into the dxf file that is used to cut the bed holder and it has a clearance of 58mm for the Y motor. 46.8mm motor + 6mm damper leaves 5.2mm for the thickness of the motor holder (which I am not absolutely sure but I think is 3mm) and some clearance to compensate any amount of mounting skew... this will be tight... And as you can see on the image of the seller below there is not much room for removing further material without coming really close to some existing holes
Damper? I think those will not be needed.
As I said these are a lot quieter.
You should measure on the printer itself. Any other theoretical calculations will be off, by my experience. -
@obeliks For the current motors the dampers make a huge difference especially for the Y motor. I feel a little hesitant to assume that the "long" silent motors are even more silent without the damper - and they would at least have to be equal in noise to the current setup. But still it is tempting.
And 5dB are nearly 4-times louder/quieter (depending on reference).
I never measured the actual difference when adding the damper, though, except for listening at them.And of course I will have to also measure on the printer itself to be sure about the cutout.
@wilriker A question regarding the dampers. Are they stiff enough not to introduce backlash?
@obeliks Actually I don't even know that. I guess so because they feel very stiff. But of course it introduces another elastic element besides the belt into the system. So it will at least add a very minimal amount of backlash.
Now that I think of it my ghosting problems with infill visible on the outside of a Benchy might be backlash issues...
Do you have a picture of that Benchy?
@obeliks This is the best one I could find (and not a good one to be honest):
Given this is actually printed on the original acrylic frame but sadly the aluminium frame did not improve in this very issue in any way.
And this is not just visible because the filament is a tiny amount transparent but also you can feel it.
EDIT: There already was belt tensioner in use and I used glass-fibre reinforced belts from the start - I never used the steel-reinforced belts that came with the A8.
This is not really ghosting, what value do you have for the perimeter/infill overlap?
@obeliks I knew that this would come up. It's at 10%. And I am using 2 perimeters with 0.4mm each so a total wall thickness of 0.8mm.
Haha
IDK, usually these kind of issues are down to slicer, temperature, filament errors. But you probably checked those before.
Just one more, is this PETG? I have seen something like that with it. -
@obeliks No it is PLA actually. But I see the same with PETG. That is one thing I have yet to get rid of - but maybe I need to try harder instead of all the time tinkering on the printer.
Regarding the filament I checked its width and AFAIR it had a little over-diameter but not enough to adjust anything. And temperature was determined by temperature tower.
You know what. Send me sliced file, I'll try it here. We will be able to definitely rule out slicers if it is all OK on my front.
@obeliks Uploaded it to my Dropbox 3DBenchy_75mm.gcode.
Of course you have to adjust start and end codes as for me this simply calls two files in
/sys
viaM98
and temperatures are set at the beginning of the file as well.
