After installing new FW 1.21 wrong finishing gcode
after installing new FW 1.21. I got trouble with my prints.
If my print is ending my extruder is running endless in reverse direction.Is anything changed with FW doing?
Here my End Script:
[[language]] G91 ;relative positioning G1 E-1 F300 ;retract the filament a bit before lifting the nozzle G90 ;absolute positioning M104 S0 ;extruder heater off M140 S0 ;heated bed heater off (if you have it) G1 Y0 F9600 G1 X0 M84 ;steppers off M106 S0 ;Fan off
are you using absolute extrusion (M82)? that would explain the issue you are having.
Yes I have set M82 in my starting script. But I never changed it. Bevor I´ve installed FW1.21 everything was working well.
Do I have to remove M82? -
no just put M83 at the start of your end script.
Not sure, maybe before 1.21 the firmware did this for you.
I don't see anything related in 1.21 release notes, maybe David can answer this one… -
ok thank you. I will try it out
