Panel due suspended mode?
Use the newest paneldue version (1.20). It will dim the display after 60 seconds of not being touched. It can be configured on the setup page to always dim like that, never dim, or only dim when the printer is "idle."
Thanks
hi,
Where can find info for update Panel Due Firmware?
I have downloaded de last file from Github
https://github.com/dc42/PanelDueFirmware/releases/tag/1.20
and them dowload the version for my PanelDue and LCD–-
https://github.com/dc42/PanelDueFirmware/releases/download/1.20/PanelDue-v3-5.0.bin
after, by DWI, i have uploaded firmware….but the version that show LCD, its the same 1.17....
Can someone explain what its the process for update firmware? or pass a link where explain it, please
Thanks
thanks
next… dude or problem....
i have follow the instructions on webpage.... and the process seems correct.... but when i press restart button on Panel Due, can see in the screen a calibration, that say me "Touch the spot"... and i have try to touch the spot with finger and stilus (from tablet), and nothing.... the screen dont detect the touch... watever i push, with finger or styus....
i have try reset the screen..... but nothig.
Ideas?
forget it….
i have unplug panel due from Duet, and works
Dimming is nice, but would it also be possible to integrate a "total off"- mode after for example 30 Minutes? Thinking about a print that lasts for a couple of hours, the display doesn't has to stay on all time?
A simple switch to cut the 5 volt power to the board can be used to turn it on and off.
If your normal "brightness" is low enough, the dimmed value will actually have the backlight as close of "off" as is possible while still powering it. I don't think it would be feasible to completely turn off the LCD without also powering down the entire PanelDue. (..and if only the LCD power was cut, I think it would also cut power to the electronics providing touch sensitivity, so you'd have no way to turn the LCD back on without rebooting the paneldue.)
