Why don't you use Cura slicer?
I really, really, really, like the Cura > Octopi plugin. So much that I'm attempting to code a Cura > Duet3D plugin.
Have a look here:
https://github.com/Kriechi/Cura-DuetRRFPluginA Cura plugin for controlling a Duet with RepRapFirmware.
Thanks to resam for this, thread is here:
https://www.duet3d.com/forum/thread.php?pid=27676#p27676 -
Have a look here:
https://www.duet3d.com/forum/thread.php?pid=27676#p27676FANTASTIC! I will take a look.
Got that plugin, downloaded and installed, and played a bit.
That is EXACTLY what I wanted. Thanks, thanks, thanks. Saves me a ton of work.
I seem to be in the minority - but I prefer Cura. It just seems to produce a nicer end product. It's not perfect, as sometimes it doesn't provide support where i'd expect it to, but generally it's my preferred slicer.
One of these days I'll go mad and pay for a slicer… but I haven't felt the need yet.
https://www.duet3d.com/forum/thread.php?pid=27676#p27676I tried installing that, but I couldn't get it to appear in the plugins/extensions list. I recently updated Cura to 3.1.0, so maybe this hasn't caught up?
Danal:
Glad you liked it! Saves me a ton of time and clicks every day!DavidJ:
I haven't played with Cura 3.1 yet - because their issue tracker is just filled with bugs in the latest release cycle…
Maybe I find some time in the next days to test & maybe update it.
Feel free to open a bug report on the github repo page: https://github.com/Kriechi/Cura-DuetRRFPlugin -
And now 3.2beta is available so the issue tracker is going to get more work.
It's great to get new features but if it comes at the expense of stability and compatibility with older versions then something is wrong. I have had my little rant over on the Cura forum suggesting they use a different release strategy with support for long term releases but it made no difference.
I've only used Cura 3.1, (appimage on Linux) and it's a relatively sane UI, for importing, scaling, positioning etc.
But the interlocking mess of Options, visible options, hidden options, Options that come and go according to other options (but only if you have also made them visible in a pop up modal dialog that hides the options list you are manipulating). There are options changed by changing printer, Options changed by filament settings, lists of proprietary filaments that I will never use but are forced into the UI. Then add in little icons to show which setting you have changed, which are shared. Throw in some help popups that dont always explain things well to a novice,and the somewhat confusing 'keep/drop' settings dialogs as you change profiles, and it's a a bit of a 'mare.
I live on tenderhooks when slicing in Cura and moving between printers and materials, I waste lots of time simply going through the slicing options making sure everything is what I expect it to be and nothing has accidentally changed. I have found myself making whole long lists of options visible just to check that Cura has made sane choices.
For my new printer I have started working by taking my standard calibration model and refining it in Cura till it printed perfectly in PLA+, then saving that as a .3mf, I then repeated for PLA, some high printing temp PLA and PETG.
- I load the CaliCat project for the material, clear the buildplate, import whatever I want to print, then maybe adjust layer height and speed. I find this much more predictable than hoping my profile selections will magically generate the right settings.
There are still some frustrations with my 4K'ish screen; scaling is good, but selection boxes on screen elements are tiny, it is particularly hard to select the layer view slider, for instance. The GUI also bogs down on the layer view for big models, further complicating navigation, but that's not too surprising given my gpu/screen combo, this is no gaming rig.
Finally; I was having wall holes appear in some 0% infill (low poly) models when sliced, clearly visible in the layer view. None of the mesh options, or any others would resolve it; and with my enthusiasm for mesh editing at an all-time low I simply resorted to Slic3r as a workaround. It sliced the same (mildly defective, I'm sure) STL's fine, and gave me the gcode I needed.
- Slic3r's options might be another dogs-dinner of tabs, dropdowns and scrollbars, but at least I can see them all at a glance.
- That was a couple of weeks ago, and since then I've found myself using slic3r more; the advantage Cura has over it for me seems to be 'undo', speed for some models, and the Vase mode (which Slic3r doesn't really understand how to do properly)
I seem to have rambled there.. sorry for that.
… because my personal version of Cura has separate speeds for the first layer walls and everything else.
There is an option to slow down the whole first layer, I use it a lot, are you talking about just slowing down the first walls, but leaving the fill of the base printing fast?
I have noticed that slightly different versions of Cura seem to put the plugins in slightly different places. I don't have a good map. If you install any plugin and it does not appear, check if there are plugins in the "local" vs "roaming" user\appdata directories. Or vice versa.
Also look for 3.0, 3.1, etc. as directory names. You get the idea…
Love to use Cura but there are too many settings or the useful ones are hidden away
Yes, exactly that. For example, my standard PLA profile with hot bed and blue tape uses 20mm/S for walls and 40mm/S for the skin and I get perfect adhesion no matter how detailed the walls are.
I would like to use Cura, but it crashes under linux. The python gui seems to have had this issue on early versions too.
I tried the latest last night. Tried to add my printer in the wizard (very pleased to see it listed!), and boom! Just core dumps on me. This is on the LTS 16.04 Ubuntu. But I had a lot of crashes on earlier versions to, eventually couldn't start it. Had to keep reinstalling it. It sometimes removed my profiles. There are a lot of issues with it in terms of usability.
That said, I stick with it when I can because the print quality is still better for me than Slic3r. Obviously I can't use the most recent versions, which is annoying, but that seems to be the way with cura. I just wish they had used something else for their gui to let it run ok on platforms such as linux.
But really, I'd like Ultimaker to offer cloud slicing. I'd probably pay a small monthly fee to have that via a really good web interface. You should take a look at OnShape to see how 3D modelling works great under html 5. Totally the way forward.
I build Cura on Linux and it runs just fine (except when new features break it but that's what you get when you live on the leading edge). Why don't you open an issue at https://github.com/Ultimaker/Cura/issues and provide useful info like cura.log and any console messages (if you run it from a terminal) so that there's a chance it can get fixed?
Well I gave it a try on my coreXYUV machine using PETG filament.
It seems to pause at the end of every layer then retract and un-retract the filament before starting the next layer. This causes the nozzle to sit in one place and the filament to leak, causing blobs. I have tried to eliminate this behavior but have been unsuccessful. A second issue is that at the end of a print, the nozzle stays in contact with the printed part and unloads the filament. I can not find any setting that tells cura to unload the filament. It is ignoring my end gcode:-
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M106 S0 ; turn off part fan
G91
G1 Z5 E-1
G90
G1 X30 Y190 F3000Any suggestions before I go back to S3D?
G91
G1 Z5 E-1
G90
How up-to-date is your linux kernel? My installation of Cura used to crash regularly until a kernel update fixed a bug in Mono - which was something that the Cura author couldn't work around.
The Mono bug went away about a year ago, so if your kernel is older…
I'm using the appimage; works Ok on Ubuntu 17.10, Fedora 25 and 26. A couple of very random segfaults during normal use, and consistent coring out if I try to do a API connection to octoprint via a proxy, which is not part of my workflow so unimportant to me. I'd be curious to know if you use the appimage, or an an apt install?
One of my goals with 3d printing is to free myself from downstream suppliers who dictate to me what I have, what shape and color it is, when I can have it etc. Becoming reliant on a cloud slicer seems like a step in the reverse direction. I am fearful that the very ability to slice and generate prints will eventually become a service, with patents used to reserve decent slicing facilities only for those with the bandwidth and money to afford them.
That said; as a complementary service It's a great idea; I work for a company making cloud service software; the list of potential drawbacks is countered nicely by a list of real advantages in terms of functionality, feature rollout, central storage, transposable UI's etc. It has a real place in the ecosystem.
TL;DR
It's easy to have an apparently up to date machine who's python install is horrible; Python has it's own package management (pip et al) which sits on top of the OS's package management system; and can get out of step. Especially if you are not familiar with it but start following 'joe-random-stackexchange's' 'guide how to fix python for X' online; since that big list of 'sudo -y pip install XXXX' commands may be really storing up issues for programs expecting the vanilla OS versions. Python pro's know to use virtualenvs etc at these moments, but joe-random doesn't have time to explain that.I believe the appimage supplies it own python libs; which is why I'm curious about your mileage with it.
Regarding Appimages; I simply wouldn't bother with either compiling locally, or installing a port/package. I'm a DevOps engineer and uber-familiar with installing and building apps (I generate over 100 rpm packages when we do a release, for instance..) ; and when I looked at the Cura build instructions I rapidly decided I have better uses for my personal time. The appimage worked first time, and every time. For context: My current 50% project at work is repackaging our Cloud platform into a appimage/binary blob/some other container instead of the 107 rpm's, plus 353 dependencies from CentOS upstream we currently churn through for our daily builds. (as of last night..)
One other reason for me using Cura is that I find slic3r very flaky - it sometimes crashes when I add a STL file, for example. I also find the whole structure of slic3r inconvenient - I have to have 10 or 12 different setup files simply to accommodate the different diameters of filament I use. In Cura I just find the relevant line and change the number. The same goes for infill, etc.
