Duet3 Mini 5+ Eth + 1HCL Drifting position during probing
Continuing with my project to control a tubing cutter with the Duet I have come across an interesting issue.
The issue is, over multiple probes the Z position seems to drift upwards (positive Z) in opposition to the raw encoder values in the 1HCL.
My blade is on an electrically isolated spindle, I have a simple probe setup between the blade and the tube. (essentially a microswitch probe)
My Z axis is run by a 1HCL board, with a quadrature encoder on the z axis, and a magnetic encoder on the motor.
The probe is on the Mini 5+ mainboard.Quadrature encoder ticks per motor revolution is 189,
1 motor revolution is 0.318 mmOperation is, probe to tubing, calculate depth required, feed z to depth required, then back out of the cut and feed/rotate the tubing to the next planned cut.
for testing I have a probing macro I call before each cut.
The script calls G30 S-1 Then calls M122 B50.0 immediately, then passes back to the previous script to calculate the cut depth.I have parsed the M122 results with the "Stopped at height" results from the G30 and graphed them.
note: Quadrature encoder ticks per motor revolution is 189, 1 motor revolution is 0.318 mm
2nd Note: Encoder ticks should trend upwards slightly, as blade wear causes more movement before tube contact
In Closed Loop Mode
Note in purple the encoder ticks are very consistent only varying by ~43 individual ticks over the range, Logically the Z value should only vary by 0.072mm as opposed to it's ~0.35mm variation
Note in red, the ticks seem more noisy, it's due to my ineptitude in excel and setting ranges on the graph. Overall min/max is only 50 ticks, meaning 0.084mm variance as opposed to the shown 0.18mm variance.The skew is worrying to me, but what is more concerning is the difference in closed vs open loop operation while probing.
Why would open loop be 2x more skew to the Z value compared to closed loop?I'm very new to the Duet, so if anyone has any suggestions on what may be happening, or have easier ways to do the probing/evaluation than the parsing, I'm all ears.
@ironhydroxide Please can you post your full config.g, the response to M122, and the probing macro you're using for testing.
A couple of observations/suggestions:
- have you tuned the closed loop motor?
- in the macro, when it "calculate depth required", is Z0 reset? Maybe there is a rounding in this calculation that causes drift.
- @dc42 has said before (https://forum.duet3d.com/post/353805) it's best to home an axis in open loop mode. I don't know if this applies to probing as well, but may also explain the difference between the two.
@droftarts
I have tuned the Closed Loop parameters, though my system has backlash that requires me to have a lower Proportional value than most say is ideal for closed loop tuning setup (belt reduction to screw movement to linear movement, inherently there will be some backlash)I do not reset the Z when probing, thus the s-1 on the G30, just report value.
I do however reset the Z at the start of the run from the average of 4 points on my tube (probe, save value, spin 90, probe, save value, spin 90, probe, save value, spin 90, probe, average values, set Z 0=average of values)
I was wondering if having the probe on the mainboard, not the 1HCL may be causing some of this, as inherently the motor controller will have to wait for the can message to stop movement, as opposed to potentially having an interrupt stopping movement immediately if it were on the 1HCL (i don't actually know how the 1HCL is coded with probing etc).
I did try the probe on the 1HCL at a previous time, but this tended in a "sticky" probe, where the probe would lock to 1000 or 0 and not change until I rebooted the board. This was on a previous firmware (3.6.0 beta2, vs 3.6.0-rc2+4), so may have been that causing the sticky probe, IDK.I home in Open loop before moving to closed loop.
Another thought I had was maybe I'm so far into the decimals here that floating point math is causing issues. as my system only has 3mm overall Z travel maybe it'd be better to configure it as mm=um to cheat that up by a few orders of magnitude.
Config.g here.
config(3).gI call this at the start of the Run to set Z 0
setZeroDepth.gthen this is called at each start of a cut
findContact.ghere's some raw logs I have parsed to get graphs from
eventlog4-24ClosedLoop.txt eventlog4-24OpenLoop.txt -
Also, searching around the forum, it seems like this post might be the same issue, just with a delta printer instead of a simple z axis.
https://forum.duet3d.com/topic/36572/v2-0-consistently-increasing-probe-heights
