Fly-SHT36 Max V3 RP2040 Based CAN-FD Toolboard
Today I finally got back to my printer
and have a little bit of work ahead of me for tomorrow.
I would like to connect a GL-8FN1 sensor as an X-Endstop to the SHT36.
Unfortunately, I've only found these two options:
And now I'm not sure if the "HVIN" input corresponds to my sensor.I'm already using the same sensor as a Y-Endstop. It's connected to the MB6HC, of ​​course:
M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g., microswitch) endstop for low end on Y via pin io2.in
Unfortunately, I'm currently a bit unsure about which pins I should use on the SHT36.
@CrazyCreator looks like it runs on 12-24v so same has the HVIN
@jay_s_uk
It's this sensor: https://s.click.aliexpress.com/e/_oo1zqJ5And it's connected like this:
@CrazyCreator then just a normal end stop then
@jay_s_uk Hello ... Ready now
MicroProbe and Proximity Sensor connected and working (in Testconfig).
Only if you interested, there the part from config.g
; Endstops M574 X1 S1 P"!124.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 124.io1.in on Fly-SHT36 Max V3 M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in on MB6HC M574 Z1 S2 ; configure Z-probe endstop for low end on Z on Fly-SHT36 Max V3 ; Z-Probes ; Configuration for Z-Probe - BTT BiQu MicroProbe V1 M558 P9 H6 F250:30 T8000 C"^124.io0.in" ; set Z probe type to microprobe and the dive height + speeds M950 P0 C"124.io0.out" ; Setup 124.io0.out as on/off port on Fly-SHT36 Max V3 G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Configuration for Scanning Probe from SHT36 M558 K1 P11 C"124.i2c.ldc1612" H5 F120 T6000 ; configure scanning probe via slot #1 G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Define Mesh Grid and Probing Points distance M557 X30:360 Y15:330 P5 ; define mesh grid
I think this is normal, because the Scanning Probe is not connected?
@CrazyCreator yes, if it's not connected it'll read like that. It'll also read like that if it's not calibrated
@jay_s_uk
That will be the next project. Calibrating the scanner... Yeaaaaah -
@jay_s_uk
Can you help me again?When I send the MicroProbe to probe the bed, it moves to the planned point and the pin pops out briefly but then goes back in immediately
and the bed stops.
The DWC Show: Z-Probe 0
Then the error message appears:
The config.g for this:; Endstops M574 X1 S1 P"!124.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 124.io1.in on Fly-SHT36 Max V3 M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in on MB6HC M574 Z1 S2 ; configure Z-probe endstop for low end on Z on Fly-SHT36 Max V3 ; Z-Probes ; Configuration for Z-Probe - BTT BiQu MicroProbe V2 M558 P9 H6 F250:30 T8000 C"^124.io0.in" ; set Z probe type to microprobe and the dive height + speeds M950 P0 C"124.io0.out" ; Setup io0.out as on/off port on Fly-SHT36 Max V3 G31 P500 X30.01 Y48.6 Z0.7 ; set Z probe trigger value, offset and trigger height ; Configuration for Scanning Probe from SHT36 ;M558 K1 P11 C"124.i2c.ldc1612" H5 F120 T6000 ; configure scanning probe via slot #1 ;G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Define Mesh Grid and Probing Points distance M557 X30:300 Y15:250 P5 ; define mesh grid
When i try the other way in config.g with !
; Endstops M574 X1 S1 P"!124.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 124.io1.in on Fly-SHT36 Max V3 M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in on MB6HC M574 Z1 S2 ; configure Z-probe endstop for low end on Z on Fly-SHT36 Max V3 ; Z-Probes ; Configuration for Z-Probe - BTT BiQu MicroProbe V2 M558 P9 H6 F250:30 T8000 C"^!124.io0.in" ; set Z probe type to microprobe and the dive height + speeds M950 P0 C"124.io0.out" ; Setup io0.out as on/off port on Fly-SHT36 Max V3 G31 P500 X30.01 Y48.6 Z0.7 ; set Z probe trigger value, offset and trigger height ; Configuration for Scanning Probe from SHT36 ;M558 K1 P11 C"124.i2c.ldc1612" H5 F120 T6000 ; configure scanning probe via slot #1 ;G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height ; Define Mesh Grid and Probing Points distance M557 X30:300 Y15:250 P5 ; define mesh grid
If I connect it like this, the MicroProbe works. The pin pops out and is triggered by the bed, and the bed stops.
BUT then I see a red 1000 on the display.
But the homing works perfectly fine, even though it says 1000 in red. That's kind of surprising, because that's not how it's supposed to be, is it?
Maybe you can take a look at my configuration?
Attached are config.g and the homing files:
config.g
homeall.g
homex.g
homey.g
homez.gMaybe
@CrazyCreator the V2 is inverted so your second config is correct
@jay_s_uk
And this
is ok? -
@jay_s_uk and maybe @jumpedwithbothfeet said in Fly-SHT36 Max V3 RP2040 Based CAN-FD Toolboard:
... , watch out for the ribbon connectors I found them quite tricky!
I managed to get the ribbon cable in on the side of the probe, but on the board itself... No chance. It doesn't slide in deep enough to stay in place. It keeps falling out.
Do you have any tips that might make this easier or even possible?
Is there nothing on the socket itself that you need to unlock or open before inserting the ribbon cable?
@CrazyCreator
For anyone who has the same problem after me, here's how to connect or insert the ribbon cable.
You have to flip the small black bracket upwards, then insert the cable, and then flip the bracket back down. This secures the cable.
Of course, you should have known beforehand that there is a bracket on these mini jacks.
