ender 5
@Rob-Holierhoek you probably have your firmware type set to something other than reprapfirmware in the slicer you're using.
And for pauses it could be that your z jerk is too low and you're using a bed mesh -
@jay_s_uk i have it set for rep rap in the slicer
@jay_s_uk i will try changing those thanks ill let you know
@Rob-Holierhoek what slicer are you using? Most likely the slicer is overriding the speeds and acceleration limits you have set. It’s also possible you have some setting like ‘adaptive pressure advance’ or ‘adaptive jerk’, which RRF doesn’t support. Post a small Gcode file that exhibits the problem, and your config.g,
For suggested slicer settings see https://docs.duet3d.com/en/How_to_guides/Calibration#h-7-suggested-slicer-settings
The ‘two upvotes’ stops the spammers. I’ve added an upvote.
@jay_s_uk ; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.4.1 on Tue Jan 21 2025 16:44:34 GMT-0500 (Eastern Standard Time); General preferences
M550 P"*****" ; set printer name; Network
M551 P"********" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X400.00 Y400.00 Z400.00 E420.00 ; set steps per mm
M203 X500.00 Y500.00 Z10.00 E5000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X950 Y950 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X220 Y220 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-5 Y-10 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:200 Y15:200 S50 ; define mesh grid; Heaters
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@Rob-Holierhoek now the issue is the home x and y are correct but when it homes to z it goes to the center of the bed and when it does its leveling it seems it isnt happy at the home position frustrating to say the least
@Rob-Holierhoek 10mm/min max speed for z is super low
we'd also need to see your homing files -
@jay_s_uk ; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.4.1 on Tue Jan 21 2025 16:44:35 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-225 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X20 Y25 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
@jay_s_uk ; homex.g
; called to home the X axis
G1 H1 X-225 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-225 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
@jay_s_uk ; homey.g
; called to home the Y axis
G1 H1 Y-225 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F6000 ; go back a few mm
G1 H1 Y-225 F360 ; move slowly to Y axis endstop once more (second pass)
@jay_s_uk ; homez.g
; called to home the Z axis
G1 X20 Y25 F6000 ; go to first probe point
managed to get things printing at a decent speed it was issue with the slicer not set same as the config for the duet...running pretty good speed and nice and quiet thanks for all the advice
