filament-error#.g usage help? Avoid pausing on sensorerror?
In 3.4 there have been numerous changes.
You'll need to read the change logs.
You no longer use the numbered files and the file names have changed. -
@owend Huh, I read the current documentation and it talks about them still... I guess I didn't realize the changelog meant it wouldn't talk to the numbered ones as the documentation says.
I'll move the code into the general filament-error.g and see how it goes
Thanks for the clarification.
*Upgrade notes:
The handling of filament errors have changed. When a filament error occurs, an event is created. To handle the event, RRF runs macro file filament-error.g without appending the extruder number to the file name and without pausing the print first. The extruder number is passed as param.D along with some other parameters. If filament-error.g is not found then the print is paused (running pause.g) and the error is reported.*
I ended up with this being my config for filament-error.g. Since a rotating magnet filament sensor, "tooLittleMovement" doesnt seem to be a "status" of the sensor, so I just made a config to filter out transient issues (sensorError and noDataRecieved) and only stop the printer if those 2 status conditions are not present.
if {param.D ^ ""} = "0" if sensors.filamentMonitors[0].status = "sensorError" echo "SensorError-0 Continuing to Print" M99 if sensors.filamentMonitors[0].status = "noDataReceived" echo "noDataReceived-0 Continuing to Print" M99 echo "Too Little Movement-0-Paused" M291 p"Filament Sensor 0 - Too Little Movement" S1 M25 ;pause the print if {param.D ^ ""} = "1" if sensors.filamentMonitors[1].status = "sensorError" echo "SensorError-1 Continuing to Print" M99 if sensors.filamentMonitors[1].status = "noDataReceived" echo "noDataReceived-1 Continuing to Print" M99 echo "Too Little Movement?-Paused" M291 p"Filament Sensor 1 - Too Little Movement" S1 M25 ;pause the print M99
@clegg78
Glad you got it working.
There's no real need to duplicate the code for each sensor as you can use the D parameter to show which is in error state.if sensors.filamentMonitors[param.D].status = "sensorError" echo "SensorError- sensor : " ^ param.D ^ " Continuing to Print" M99 if sensors.filamentMonitors[0].status = "noDataReceived" echo "noDataReceived -sensor " ^ param.D ^ "Continuing to Print" M99 ; catch all for any other error type echo "Filament error on sensor " ^ param.D ^ " - Paused" echo param.S ; echo the entire error for clarity M291 P{"Filament Sensor" " ^ param.D ^ " - Paused"} S1 M25 ; pause the print
@owend ahh yeah! thanks I'll clean that up
@clegg78
You might also want to do a check at the start to see if there is an active tool so that if you remove the filament at any time from a second (inactive) tool it doesn't pause.
Likewise you could check to see if the sensor that is raising the error belongs to the active tool, but I can't see a way to see which tool(s) each sensor is associated with in the object model. -
I too get a sensor error every 20h or so and I did just put this into filament-error.g:
if sensors.filamentMonitors[0]status != "sensorError" M25
undefined Phaedrux referenced this topic
I tried to monitor the sensor status, but I suppose I made an error somewhere.
I always get "OK" status when reading the sensor status after an error.
var StatusTest = sensors.filamentMonitors[0].status if {var.StatusTest} = "sensorError" M291 P{var.StatusTest} S1 ;M291 P"Filament Sensor - Sensor Error" S1 M24 M99 if {var.StatusTest} = "noDataReceived" M291 P{var.StatusTest} S1 ;M291 P"Filament Sensor - No data received" S1 M24 M99 if {var.StatusTest} = "tooMuchMovement" M291 P{var.StatusTest} S1 ;M291 P"Filament Sensor - tooLittleMovement" S1 M24 M99 if {var.StatusTest} = "tooLittleMovement" M291 P{var.StatusTest} S1 ;M291 P"Filament Sensor - tooLittleMovement" S1 M25 else M291 P{var.StatusTest} S1
This look like I don't read the right value or it's refreshed since the event was raised and called the filament-error.g
Any help will be appreciated
@Argo said in filament-error#.g usage help? Avoid pausing on sensorerror?:
I also needed to use this workaround because meanwhile all values, from agc to calibration and what ever is needed to get this magnetic filament monitor to work, are fine i still get this filament error which i cant debug because i dont get any information what the error is actually about...
this whole filament monitor is not a finished product as duet is selling it - its at best experimental!!! The time i spend to get it working was crazy and i think as consumer you should know this befor buy!!!
also this what should this min -710% and max 468% tell me... also didnt stop the print and didnt trigger any alarm ...
@juanito16k Have you started a thread for your issue? It would be easier to troubleshoot if we discuss it there instead of in a 3 year old thread.
