RRF Config Tool update von 3.3.2 auf aktuell
Hello Duet 3D family
I wanted to update from 3.3.2 after 3 years using the RRF Config Tool and I also read in the JSON - but a lot has changed and I've forgotten a lot. And I just don't understand it anymore! Can someone please help me so that I can at least do an update on the RRF Config Tool. I've attached my config file and the JSON. I'm very grateful for your help. I only save the data using an SD card. Thanks and regards, Alex
config.g
config.json -
@Alex maybe make a backup of that SD card, and then create a new configuration from scratch using the configuration tool and the existing config as a backup.
I do believe the config.g would not require a lot of adjustments except new PID tuning since the parameters changed, but starting over may be a good idea nonetheless. It might be worth re-reading the commissioning guide to re-acquaint yourself with the basics https://docs.duet3d.com/en/How_to_guides/Commissioning
