6XD I/O >> Issue solved
@tecno Can you post your whole config.g as it currently is, please. Also run
M98 P"config.g"
from the console and post the response.Ian
@tecno You've set out2 as a fan!
M950 F2 C"out2" ; Q500 ;Drag PIN Actuator
Changle "F2" to "P2".
Corrected
;***Outputs
M950 P0 C"out0" ; Q500 ;#1 Nozzle Vacuum
M950 P1 C"out1" ; Q500 ;#2 Nozzle Vacuum
M950 P2 C"out2" ; Q500 ;Drag PIN Actuator
M950 P3 C"out3" ; Q500 ;ENA Nozzle 1/2 Up
M950 P4 C"out4" ; Q500 ;Xross cursor
M950 P5 C"out5" ; Q500 ;LED light
M950 P6 C"out6" ; Q500 ;Vacuum power -
@tecno Did you reset or run config.g before running the macro again?
@tecno Please post the macro.
M42 P2 S1
echo state.gpOut[1].pwmM42 P2 S0.5
echo state.gpOut[1].pwm -
@tecno said in 6XD I/O >> Faulty Driver 5:
Wrong pin. Use:
echo state.gpOut[2].pwm
Now suddenly the OUT2 works, so go figure what is going on. Cold soldering seems far away but could be.
Been take out plugs and inserted them testing.Whole day yesterday I did not see the LED light up but OUT1 and OUT0 was working.
So DRIVER5 is still an issue here.
@tecno Can you post a good picture of both sides of the board, please. There's so very little to go wrong with these ports, I feel like it's something obvious. Did you check it with a multimeter, like I asked you to?
out2 is still working correctly? Does the LED come on when active?
Also, please send M586 and post the response, to see what network protocols are enabled, because your config doesn't have any set.
@droftarts
Hi Ian,
Re multimeter = no as you can see it is not so accessible in the video. Later on today.
https://photos.app.goo.gl/L56Zn79kaww26Q4U6out2 is OK
2024-09-25 09:26:27 m586
CORS disabled
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Multicast Discovery is disabled
MQTT is disabledCheers
Bengt -
Pictures of 6XD board https://photos.app.goo.gl/6ME2iY7CesXBjeKPA
@tecno Were you able to do any tests with a multimeter? I can't see anything obvious from the pictures.
@droftarts
Pls repeate exactly what you want me to measure now that the board is in the open. -
@tecno From the video I can see that you're using 3 of the pins of each driver connector: 5V_EXT, D#_STEP- and D#_DIR-. I can't clearly see Driver 5, but I assume it is the same as the others.
With the multimeter, and the Duet powered, and being careful not to touch probe to the wrong pins (especially not to touch across 5V pins to 3.3V pins):
- Test for 5V between 5V_EXT and GND on the driver 5 connector. This should read 5V.
- Test for 5V between 5V_EXT and D5_DIR-. Send a command that moves the axis one way, then the other. You should get 5V in one direction, and 0V in the other direction.
- It may be difficult to see a signal if you put the multimeter between 5V_EXT and D5_STEP-, because the step pulses happen faster than the multimeter can register them. You could try doing a fast move, which might register.
- You could also do the tests on Driver 4, so you can see what the expected response is.
Let me know how that goes.
Hi Ian,
Looks like the 3 wires original cable is not to par, brittle so crimps go bad. Will make new wireing to all motors.
This el cheapo chinese cable, found also twisted wire splices with only shrink tubing loosely fitted.DMM test shows driver to be OK
I hope I have enough crimpconnectors
Cheers
BEngt
