Solved Duet2Wifi always connecting error
I believe the problem started when I removed the SD Card from the board while it was powered on. Don't know if that matters though but afterwards it always says "connecting" and never establishes a wifi connection.
I re-flashed the current firmware to the board and still same issue.
I know the SD card is not corrupt and using Bossa the wire of the firmware update to the board was verified as successful.
When I use panel due to read the SD Card it says 0 files present.
Any idea what would cause this issue?
Did I. fry the Duet Board by removing the SD Card while the board had power to it? -
Can you go through this guide to see how far you get and report back with what you find.
https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
Particularly want to know if the board still reponds to USB terminal commands, and if so what is the response to sending M552 S1.
@Phaedrux After connecting as you mention and issuing M552 S1 it says Printer is not online.
I now have it working after refreshing the firmware a second time.
Thanks for reaching out.
All good for now! -
