Manually updating resurrect.g without having to pause the print?
I'm curious if there is a way to update the resurrect.g without pausing the print or hoping the M911 is able to update it during power loss. Could I save the location every layer so that in the event of a power failure it will restart the layer, printing some of it twice, but for the most part picking up where it left off?
@qman3399 said in Manually updating resurrect.g without having to pause the print?:
If you're having unreliable power loss saving maybe look into adding some capacitance to your PSU to give it a bit more time.
@Phaedrux I ordered some caps to see if that helps the issue. I'd like to be able to manually save the position too though, in the off chance that the power loss doesn't work or something other than low voltage causes the board to reset. Maybe something like G60? But it doesn't seem like the restore position from G60 saves after a reset.
