SFS V2.0 to Duet 3 Mini
@SonnyD1 I believe it's been fixed in the source and will be working in 3.5.2
@Phaedrux I removed the apostrophe and I still get the same error. This is really weird. I have the same line (M591 D0 P1 C"" S1) on my another printer with the same filament runout switch and I don't have this issue. Only difference is the other one is a Duet 2 running 3.4.
Creativity 3D Printer Filament Detection Sensor Module Filament Run-Out Pause Detecting Monitor for 3D Printer Lerdge Board 1.75mm Filament (Black) https://a.co/d/dzyfMmf -
@jay_s_uk I've since switched to another Filament Runout sensor. Now I'm using :
Guys I really need to get this resolved. I know it's kind of a weird issue. Right now,I have a printer that's unusable. I've done everything that I know how to do.
Have you tried 3.5.2 that was just released?
@Phaedrux Ok I just updated to 3.5.2. It eliminated the error but the switch still isn't working. I need to verify the wiring and I'll get back with you. Thank you for your help thus far. Almost there...
@Phaedrux I verified the wiring. It matches another machine that works perfectly. I'm at a loss yet again. Clearly I'm not as smart as I think I am. I verified that its not a bad switch by swapping it out with another. I verified the wiring matches a known functional setup and I swapped the signal and the volt wire to be sure. I'm out of ideas. If its a config issue, I can't imagine what it is. Thoughts? Do I have to run a simple switch off the same toolboard that the extruder is on?
@SonnyD1 With version 3.5.2, it works perfectly. I mean my filament sensors on the Duet3 Mini and use two tool boards. Before version 3.5.2, I also got an error message unknown pin name.
@Proschi78 3.5.2 fixed that error on mine as well. Now the sensor still wont work and I can't seem to get any help. I'll keep trying to fix it though. TY for the reply.
Can you show us exactly what switch it is, and how it's wired?
@SonnyD1 said in SFS V2.0 to Duet 3 Mini:
And you've said you've swapped in another board and it's not working either? That would seem to indicate wiring or a crimp maybe.
@Phaedrux Yea you nailed it. I went and ran another jumper wire and it worked. So I ran all new wiring. Musta been a bad crimp like you said. The LED on the switch lights up and I get a filament error when I remove filament just like it should. I know I'm a pain and this was a headache but I really appreciate you hangin in there with me. Sometimes the most obvious solution eludes me. TYVM!!!
@Phaedrux The filament runout error doesn't pop up on my paneldue like it does on my other printers. Only pops up on the DWC....any idea why?
