ReleaseMgr DWC Plugin v1.3.3 (20-09-24)
New update published v0.01.13
Changelog :
v0.01.13:
Repackaged for 3.4 full release, minor bug fixes and layout changes.Note: If you install the DWC 3.3 compatible version of this plugin, and then update DWC to 3.4, you will need to update the plugin to the 3.4 compatible version for it to operate correctly.
New update published v0.01.14
Changes:
Fixed issue with RC release notes displaying the correct info for DWC & DSF -
Release 0.01.15 available on GitHUb
Added an auto check for firmware updates feature, which checks GitHub for an updated firmware version when DWC loads, and pushes an alert to the user. The feature can be enabled in settings. Users can also choose to stop duplicate alerts for the same update if desired.
Team Gloomy users can now access the RRF files panel if they choose to dismiss the warning.
Released v0.01.16 for DWC 3.5+
Released v1.1.17 for DWC 3.5+
Change Log:
- Updated to include support for new github version numbering syntax for DWC & DSF coming in 3.5.0-Beta.2
- Added link to RRF update instructions
- Switch plugin version number syntax to be semver 2 compliant
Released v1.1.18 for DWC 3.5+
Change Log:
- Updated to include support for new github version numbering syntax for RRF in 3.5.0-Beta.3
- removed release versions older than 3.5 as they are redundant
- Fixed issue with toggle button groups
Released V1.1.19 - For DWC 3.5.0-beta.4 Only
Change log :
-Updated to support new Object Model Keys for SBC in beta 4 -
Released V1.1.20 - For DWC 3.5.0-rc.1 Only
Change log :
-Updated to support DWC 3.5.0-rc.1 -
Released V1.1.20 - For DWC 3.5.1
Change log :
V1.2.0 - For DWC 3.5.1
-Updated to support DWC 3.5.1 and the updated Duet release numbering approach -
Released v1.3.0 - For DWC 3.5.1
Change log :
V1.3.0 - For DWC 3.5.1
-Updated to support the new Team Gloomy release approach
-Updated UI -
Released 1.3.2
Re-Packaged for DWC 3.5.2 -
Updated to V1.3.3 for DWC 3.5.3
