Is DuetPrintFarm still in development?
I'm not sure if this is the right section to raise this, but is the DuetPrintFarm (https://github.com/Duet3D/DuetPrintFarm) project still in active development? I set out this morning to start whipping up something to queue prints, and then came across this in the Duet3D Github, but it looks like the last update was a couple years ago so I'm not sure if anyone is still working on it. @dc42 @chrishamm @T3P3Tony
If it's still being worked on, and there's a feature request list somewhere, it'd be great to get a Docker image option for deployment, instead of having to download and run manually.
@webdes03 we have not had the resources to devote to it recently. You can add a feature request on the github page however i do not have a timeline for us to start working on it again.
@T3P3Tony Thanks for following up. I may work on my own solution, and will share if it comes to anything!
@webdes03 Would be happy to have you extend the existing print farm software if you prefer
@T3P3Tony I did look through the code. Unfortunately, .NET is where I'm least proficient... I can somewhat interpret what's going on, but I'd probably need to do it in React/TS/Node if I was going to be remotely productive. If I do something I'll open source it though so maybe I can try and fill that void if you guys aren't sure if you'll further mature the existing solution. I can't imagine the demand is that high--I actually wanted it less for full blown farm management and more for queuing for a single printer.
