[3.5.0-rc.3+5] [bug] nested while job Illegal para letter '.'
Hi @chrishamm today I had the following bug while porting a jobfile with meta commands from duet2 in standalone to an duet3 in sbc mode.
the following will work in standalone mode
if !inputs[state.thisInput].active M99 var x = 0 var y = 1 var N = 5 while var.x < var.y var i = 0 while var.i < var.N echo "var.i = " ^ var.i echo "var.N = " ^ var.N if var.i > 2 set var.N = var.i if var.i > 5 break set var.i = var.i + 1 set var.x = var.x + 1
and will fail in sbc mode
Feb 29 21:11:01 Meltingplot-MBL-480-vaswsq DuetControlServer[405]: [info] var.i = 0 Feb 29 21:11:01 Meltingplot-MBL-480-vaswsq DuetControlServer[405]: [info] var.N = 5 Feb 29 21:11:02 Meltingplot-MBL-480-vaswsq DuetControlServer[405]: [error] in job file (channel File) line : Illegal parameter letter '.' Feb 29 21:11:02 Meltingplot-MBL-480-vaswsq DuetControlServer[405]: [error] DuetAPI.CodeParserException: Illegal parameter letter '.' Feb 29 21:11:02 Meltingplot-MBL-480-vaswsq DuetControlServer[405]: DuetAPI.CodeParserException: Illegal parameter letter '.' Feb 29 21:11:02 Meltingplot-MBL-480-vaswsq DuetControlServer[405]: at DuetAPI.Commands.Code.AddParameter(Code code, Char letter, String value, Boolean isQuoted, Boolean isSingleParameter) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetAPI/Commands/Code/Parser.cs:line 746 Feb 29 21:11:02 Meltingplot-MBL-480-vaswsq DuetControlServer[405]: at DuetAPI.Commands.Code.ParseAsync(Stream stream, Code result, CodeParserBuffer buffer, CancellationToken cancellationToken) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetAPI/Commands/Code/ParserAsync.cs:line 725 Feb 29 21:11:02 Meltingplot-MBL-480-vaswsq DuetControlServer[405]: at DuetControlServer.Files.CodeFile.ReadCodeAsync(Code sharedCode) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Files/CodeFile.cs:line 221 Feb 29 21:11:02 Meltingplot-MBL-480-vaswsq DuetControlServer[405]: at DuetControlServer.Files.JobProcessor.DoFilePrint(CodeFile file) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Files/JobProcessor.cs:line 344 Feb 29 21:12:07 Meltingplot-MBL-480-vaswsq systemd[1]: Stopping Duet Control Server...
with a small modifikation of the code {...}
if !inputs[state.thisInput].active M99 var x = 0 var y = 1 var N = 5 while {var.x < var.y} var i = 0 while {var.i < var.N} echo "var.i = " ^ var.i echo "var.N = " ^ var.N if {var.i > 2} set var.N = var.i if var.i > 5 break set var.i = var.i + 1 set var.x = var.x + 1
the output is the following:
M122
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+5 (2024-02-21 14:58:54) running on Duet 3 MB6HC v1.02 or later (SBC mode) Board ID: 08DJM-9P63L-DJ3T8-6JKD4-3SJ6K-9A77A Used output buffers: 1 of 40 (17 max) === RTOS === Static ram: 155208 Dynamic ram: 88620 of which 4112 recycled Never used RAM 94788, free system stack 125 words Tasks: SBC(2,ready,0.9%,406) HEAT(3,nWait 1,0.0%,327) Move(4,nWait 6,0.0%,235) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,8.8%,56) MAIN(2,running,90.0%,103) IDLE(0,ready,0.2%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:09:43 ago, cause: power up Last software reset at 2024-02-29 20:53, reason: User, Gcodes spinning, available RAM 94812, slot 0 Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 MCU temperature: min 25.8, current 34.0, max 34.2 Supply voltage: min 0.4, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 0.1, current 12.3, max 12.8, under voltage events: 0 Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/536/432, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 40, reads 60308, writes 27 timeouts 0 Driver 1: standstill, SG min 0, mspos 360, reads 60309, writes 27 timeouts 0 Driver 2: standstill, SG min 0, mspos 8, reads 60315, writes 21 timeouts 0 Driver 3: standstill, SG min 0, mspos 8, reads 60315, writes 21 timeouts 0 Driver 4: standstill, SG min 0, mspos 8, reads 60315, writes 21 timeouts 0 Driver 5: standstill, SG min 0, mspos 4, reads 60317, writes 19 timeouts 0 Date/time: 2024-02-29 21:19:04 Slowest loop: 64.73ms; fastest: 0.06ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 17, maxWait 498358ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 4, on retry 0, too short 0, wrong shape 34, maybepossible 0 === DDARing 0 === Scheduled moves 40, completed 40, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC* is idle in state(s) 0 Daemon* is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2* is idle in state(s) 0, sync state 2 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000003 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 633993 clear 4462564 Extruder 0: pos 2160.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === CAN === Messages queued 5175, received 0, lost 0, errs 2753656, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 2916/0/0 Tx timeouts 0,0,2915,0,0,2258 last cancelled message type 30 dest 127 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 15981/15981 SPI underruns 0, overruns 0 State: 5, disconnects: 1, timeouts: 1 total, 1 by SBC, IAP RAM available 0x255b4 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server version 3.5.0-rc.3+5 (2024-02-21 14:42:00, 32-bit) Failed to deserialize the following properties: - MoveSegmentation -> Int32 from 2.0 Daemon: >> Doing macro daemon.g, started by system Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 38.68, max time between full transfers: 47.4ms, max pin wait times: 38.1ms/3.3ms Codes per second: 0.97 Maximum length of RX/TX data transfers: 4445/296
@timschneider Thanks, fixed. This bug only showed up if meta G-code with while loops was used in job files.
@chrishamm thank you for working on the bug that fast!
I've just installed rc.3+6 and tried to retest the above code, but now something else went wrong.
but the initial problem is solved.
and now to the new problem
Mar 01 14:04:34 Meltingplot-MBL-480-vaswsq DuetControlServer[2500]: [debug] Evaluation result: (true) = True Mar 01 14:04:34 Meltingplot-MBL-480-vaswsq DuetControlServer[2500]: [error] in file daemon.g line 2: Illegal parameter letter '=' Mar 01 14:04:34 Meltingplot-MBL-480-vaswsq DuetControlServer[2500]: [error] DuetAPI.CodeParserException: Illegal parameter letter '=' Mar 01 14:04:34 Meltingplot-MBL-480-vaswsq DuetControlServer[2500]: DuetAPI.CodeParserException: Illegal parameter letter '=' Mar 01 14:04:34 Meltingplot-MBL-480-vaswsq DuetControlServer[2500]: at DuetAPI.Commands.Code.AddParameter(Code code, Char letter, String value, Boolean isQuoted, Boolean isSingleParameter) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetAPI/Commands/Code/Parser.cs:line 726 Mar 01 14:04:34 Meltingplot-MBL-480-vaswsq DuetControlServer[2500]: at DuetAPI.Commands.Code.ParseAsync(Stream stream, Code result, CodeParserBuffer buffer, CancellationToken cancellationToken) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetAPI/Commands/Code/ParserAsync.cs:line 725 Mar 01 14:04:34 Meltingplot-MBL-480-vaswsq DuetControlServer[2500]: at DuetControlServer.Files.CodeFile.ReadCodeAsync(Code sharedCode) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Files/CodeFile.cs:line 232 Mar 01 14:04:34 Meltingplot-MBL-480-vaswsq DuetControlServer[2500]: at DuetControlServer.Files.MacroFile.ReadCodeAsync() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Files/MacroFile.cs:line 260 Mar 01 14:04:34 Meltingplot-MBL-480-vaswsq DuetControlServer[2500]: at DuetControlServer.Files.MacroFile.Run() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Files/MacroFile.cs:line 311
part of daemon.g
while true if exists(global.initial_temp) == false global initial_temp = 0
this will also fail
part of daemon.g
while true if !exists(global.initial_temp) global initial_temp = 0
the above error is in the daemon.g, but it can be recreated in a macro.
echo "0" if !exists(global.initial_temp) echo "1" else echo "2" echo "3"
The output in the console
1.3.2024, 15:09:53 M98 P"0:/macros/test-sbc-4" 1.3.2024, 15:09:52 0
and the same in the job processor
content of print_end
G10 ; Retract the filament G10 P0 R0 S0 ; disable hotend M140 S0 R0 ; set bed heater to 0° M140 P0 S-273.1 ; disable bed heater T-1 ; deselect all tools if exists(global.clearanceHeight) && move.axes[2].homed G90 ; absolute positioning G1 Z{max(20,global.clearanceHeight)} ; lift z to clearance height G28 X Y ; home x and y if (sensors.gpIn[2].value == 1 && sensors.gpIn[3].value == 1 ) G91 ; relative if move.axes[2].homed G1 Z100 F1250 ; lift z ; move only if both doors are closed G90 ;G1 Z{move.axes[2].max-5} F1250 ; lift z G1 X{move.axes[0].max} ; move gantry away from camera ;M84 ; turn off motors M107 ; Turn off fans
@timschneider I just wanted to edit my post and say that I've discovered something else. I'm looking into it.
@timschneider I've got another bug fix ready in case you want to try it.
@chrishamm
thank you for the fix !the main problem is fixed now, but idk if there is another one.
If started as a job file it will never terminate, even with an explicit M0 at the end of the .gcode file.Mar 06 11:38:42 X: [debug] HTTP: Finished code M23 "0:/macros/test-sbc-3.gcode" => File 0:/macros/test-sbc-3.gcode selected for printing Mar 06 11:38:42 X: [debug] IPC#14: Connection closed Mar 06 11:38:42 X: [debug] Requesting update of key job, seq 1 -> 3 Mar 06 11:38:42 X: [debug] Updated key job Mar 06 11:38:44 X: [debug] Requesting update of key inputs, seq 30 -> 31 Mar 06 11:38:44 X: [debug] Updated key inputs Mar 06 11:38:44 X: [debug] Requesting update of key inputs, seq 31 -> 32 Mar 06 11:38:44 X: [debug] Updated key inputs Mar 06 11:38:52 X: [debug] Got new UNIX connection via IPC#15, checking permissions... Mar 06 11:38:52 X: [debug] IPC#15: Granting full DSF permissions to external plugin Mar 06 11:38:52 X: [debug] Command processor added for IPC#15 Mar 06 11:38:52 X: [debug] IPC#15: Received command SimpleCode Mar 06 11:38:52 X: [debug] HTTP: Starting code M24 Mar 06 11:38:52 X: [debug] Processing M24 Mar 06 11:38:52 X: [debug] HTTP: Sent M24, remaining space 1512, needed 24 Mar 06 11:38:52 X: [info] Starting macro file start.g on channel File Mar 06 11:38:52 X: [debug] File: Starting code ; start.g (macro code) Mar 06 11:38:52 X: [debug] File: Starting code ; is run when you start a print from SD card. Runs immediately before any slicer created gcode (macro code) Mar 06 11:38:52 X: [debug] Processing ; start.g Mar 06 11:38:52 X: [debug] File: Starting code M98 P"0:/sys/meltingplot/check_doors_closed" (macro code) Mar 06 11:38:52 X: [debug] Processing ; is run when you start a print from SD card. Runs immediately before any slicer created gcode Mar 06 11:38:52 X: [debug] Processing M98 P"0:/sys/meltingplot/check_doors_closed" Mar 06 11:38:52 X: [debug] File: Finished code ; start.g Mar 06 11:38:52 X: [debug] File: Finished code ; is run when you start a print from SD card. Runs immediately before any slicer created gcode Mar 06 11:38:52 X: [debug] File: Sent M98 P"0:/sys/meltingplot/check_doors_closed", remaining space 1464, needed 72 Mar 06 11:38:52 X: [info] Starting macro file start.g on channel File2 Mar 06 11:38:52 X: [debug] File2: Starting code ; start.g (macro code) Mar 06 11:38:52 X: [debug] File2: Starting code ; is run when you start a print from SD card. Runs immediately before any slicer created gcode (macro code) Mar 06 11:38:52 X: [debug] Processing ; start.g Mar 06 11:38:52 X: [debug] Processing ; is run when you start a print from SD card. Runs immediately before any slicer created gcode Mar 06 11:38:52 X: [debug] File2: Finished code ; start.g Mar 06 11:38:52 X: [debug] File2: Finished code ; is run when you start a print from SD card. Runs immediately before any slicer created gcode Mar 06 11:38:52 X: [debug] File2: Starting code M98 P"0:/sys/meltingplot/check_doors_closed" (macro code) Mar 06 11:38:52 X: [debug] Processing M98 P"0:/sys/meltingplot/check_doors_closed" Mar 06 11:38:52 X: [debug] File2: Sent M98 P"0:/sys/meltingplot/check_doors_closed", remaining space 1464, needed 72 Mar 06 11:38:52 X: [info] Starting macro file 0:/sys/meltingplot/check_doors_closed on channel File Mar 06 11:38:52 X: [debug] File: ==> Starting code M98 P"0:/sys/meltingplot/check_doors_closed" Mar 06 11:38:52 X: [debug] HTTP: Finished code M24 => Mar 06 11:38:52 X: [info] Starting file print Mar 06 11:38:52 X: [debug] IPC#15: Connection closed Mar 06 11:38:52 X: [info] Starting macro file 0:/sys/meltingplot/check_doors_closed on channel File2 Mar 06 11:38:52 X: [debug] File2: ==> Starting code M98 P"0:/sys/meltingplot/check_doors_closed" Mar 06 11:38:52 X: [debug] Evaluating While block Mar 06 11:38:52 X: [debug] Evaluating While block Mar 06 11:38:52 X: [debug] Evaluating (sensors.gpIn[2].value == 0 || sensors.gpIn[3].value == 0 ) on channel File Mar 06 11:38:52 X: [debug] Evaluating (sensors.gpIn[2].value == 0 || sensors.gpIn[3].value == 0 ) on channel File2 Mar 06 11:38:52 X: [debug] Evaluation result: ((sensors.gpIn[2].value == 0 || sensors.gpIn[3].value == 0 )) = False Mar 06 11:38:52 X: [debug] Evaluation result: ((sensors.gpIn[2].value == 0 || sensors.gpIn[3].value == 0 )) = False Mar 06 11:38:52 X: [debug] End of While block Mar 06 11:38:52 X: [debug] End of While block Mar 06 11:38:52 X: [debug] Finished codes from macro file 0:/sys/meltingplot/check_doors_closed Mar 06 11:38:52 X: [info] Finished macro file 0:/sys/meltingplot/check_doors_closed Mar 06 11:38:52 X: [debug] Finished codes from macro file 0:/sys/meltingplot/check_doors_closed Mar 06 11:38:52 X: [info] Finished macro file 0:/sys/meltingplot/check_doors_closed Mar 06 11:38:52 X: [debug] File: ==> Unfinished starting code: M98 P"0:/sys/meltingplot/check_doors_closed" Mar 06 11:38:52 X: [debug] File: Finished code M98 P"0:/sys/meltingplot/check_doors_closed" Mar 06 11:38:52 X: [debug] Requesting update of key inputs, seq 32 -> 36 Mar 06 11:38:52 X: [debug] Finished codes from macro file start.g Mar 06 11:38:52 X: [info] Finished macro file start.g Mar 06 11:38:52 X: [debug] File: Disposing macro file 0:/sys/meltingplot/check_doors_closed Mar 06 11:38:52 X: [debug] File2: ==> Unfinished starting code: M98 P"0:/sys/meltingplot/check_doors_closed" Mar 06 11:38:52 X: [debug] File2: Disposing macro file 0:/sys/meltingplot/check_doors_closed Mar 06 11:38:52 X: [debug] File2: Finished code M98 P"0:/sys/meltingplot/check_doors_closed" Mar 06 11:38:52 X: [debug] Finished codes from macro file start.g Mar 06 11:38:52 X: [info] Finished macro file start.g Mar 06 11:38:52 X: [debug] File: Disposing macro file start.g Mar 06 11:38:52 X: [debug] Evaluating If block Mar 06 11:38:52 X: [debug] Evaluating !inputs[state.thisInput].active on channel File Mar 06 11:38:52 X: [debug] Updated key inputs Mar 06 11:38:52 X: [debug] Requesting update of key job, seq 3 -> 4 Mar 06 11:38:52 X: [debug] File2: Disposing macro file start.g Mar 06 11:38:52 X: [debug] Evaluating If block Mar 06 11:38:52 X: [debug] Evaluating !inputs[state.thisInput].active on channel File2 Mar 06 11:38:52 X: [debug] Evaluation result: (!inputs[state.thisInput].active) = False Mar 06 11:38:52 X: [debug] Updated key job Mar 06 11:38:52 X: [debug] End of If block Mar 06 11:38:52 X: [debug] File: Starting code var x = 0 Mar 06 11:38:52 X: [debug] File: Starting code var y = 1 Mar 06 11:38:52 X: [debug] File: Starting code var N = 5 Mar 06 11:38:52 X: [debug] Processing var x = 0 Mar 06 11:38:52 X: [debug] Setting variable var.x to 0 on channel File Mar 06 11:38:52 X: [debug] Evaluation result: (!inputs[state.thisInput].active) = True Mar 06 11:38:52 X: [debug] File2: Starting code M0 Mar 06 11:38:52 X: [debug] Processing M0 Mar 06 11:38:52 X: [debug] End of If block Mar 06 11:38:52 X: [debug] File2: Starting code var x = 0 Mar 06 11:38:52 X: [debug] File2: Starting code var y = 1 Mar 06 11:38:52 X: [debug] File2: Starting code var N = 5 Mar 06 11:38:52 X: [debug] Set variable var.x to 0 Mar 06 11:38:52 X: [debug] Processing var y = 1 Mar 06 11:38:52 X: [debug] Setting variable var.y to 1 on channel File Mar 06 11:38:52 X: [debug] File: Finished code var x = 0 => Mar 06 11:38:52 X: [debug] Set variable var.y to 1 Mar 06 11:38:52 X: [debug] Processing var N = 5 Mar 06 11:38:52 X: [debug] File: Finished code var y = 1 => Mar 06 11:38:52 X: [debug] Setting variable var.N to 5 on channel File Mar 06 11:38:52 X: [debug] Set variable var.N to 5 Mar 06 11:38:52 X: [debug] Evaluating While block Mar 06 11:38:52 X: [debug] Evaluating var.x < var.y on channel File Mar 06 11:38:52 X: [debug] File: Finished code var N = 5 => Mar 06 11:38:52 X: [debug] Evaluation result: (var.x < var.y) = True Mar 06 11:38:52 X: [debug] File: Starting code var i = 0 Mar 06 11:38:52 X: [debug] Processing var i = 0 Mar 06 11:38:52 X: [debug] Setting variable var.i to 0 on channel File Mar 06 11:38:52 X: [debug] Set variable var.i to 0 Mar 06 11:38:52 X: [debug] Evaluating While block Mar 06 11:38:52 X: [debug] File: Finished code var i = 0 => Mar 06 11:38:52 X: [debug] Evaluating var.i < var.N on channel File Mar 06 11:38:52 X: [debug] Requesting update of key inputs, seq 36 -> 44 Mar 06 11:38:52 X: [debug] Evaluation result: (var.i < var.N) = True Mar 06 11:38:52 X: [debug] File: Starting code echo "var.i = " ^ var.i Mar 06 11:38:52 X: [debug] Processing echo "var.i = " ^ var.i Mar 06 11:38:52 X: [debug] Evaluating "var.i = " ^ var.i on channel File Mar 06 11:38:52 X: [debug] File: Starting code echo "var.N = " ^ var.N Mar 06 11:38:52 X: [debug] Updated key inputs Mar 06 11:38:52 X: [debug] Processing echo "var.N = " ^ var.N Mar 06 11:38:52 X: [debug] Evaluating "var.N = " ^ var.N on channel File Mar 06 11:38:52 X: [info] var.i = 0 Mar 06 11:38:52 X: [debug] File: Finished code echo "var.i = " ^ var.i => var.i = 0 Mar 06 11:38:52 X: [info] var.N = 5 Mar 06 11:38:52 X: [debug] Evaluating If block Mar 06 11:38:52 X: [debug] Evaluating var.i > 2 on channel File Mar 06 11:38:52 X: [debug] File: Finished code echo "var.N = " ^ var.N => var.N = 5 Mar 06 11:38:52 X: [debug] Evaluation result: (var.i > 2) = False Mar 06 11:38:52 X: [debug] End of If block Mar 06 11:38:52 X: [debug] Evaluating If block Mar 06 11:38:52 X: [debug] Evaluating var.i > 5 on channel File Mar 06 11:38:53 X: [debug] Evaluation result: (var.i > 5) = False Mar 06 11:38:53 X: [debug] End of If block Mar 06 11:38:53 X: [debug] File: Starting code set var.i = var.i + 1 Mar 06 11:38:53 X: [debug] Processing set var.i = var.i + 1 Mar 06 11:38:53 X: [debug] Setting variable var.i to var.i + 1 on channel File Mar 06 11:38:53 X: [debug] Set variable var.i to 1 Mar 06 11:38:53 X: [debug] File: Finished code set var.i = var.i + 1 => Mar 06 11:38:53 X: [debug] Restarting While block, iterations = 1 Mar 06 11:38:53 X: [debug] Evaluating While block Mar 06 11:38:53 X: [debug] Evaluating var.i < var.N on channel File Mar 06 11:38:53 X: [debug] Evaluation result: (var.i < var.N) = True Mar 06 11:38:53 X: [debug] File: Starting code echo "var.i = " ^ var.i Mar 06 11:38:53 X: [debug] File: Starting code echo "var.N = " ^ var.N Mar 06 11:38:53 X: [debug] Processing echo "var.i = " ^ var.i Mar 06 11:38:53 X: [debug] Evaluating "var.i = " ^ var.i on channel File Mar 06 11:38:53 X: [debug] Processing echo "var.N = " ^ var.N Mar 06 11:38:53 X: [info] var.i = 1 Mar 06 11:38:53 X: [debug] Evaluating "var.N = " ^ var.N on channel File Mar 06 11:38:53 X: [debug] File: Finished code echo "var.i = " ^ var.i => var.i = 1 Mar 06 11:38:53 X: [info] var.N = 5 Mar 06 11:38:53 X: [debug] Evaluating If block Mar 06 11:38:53 X: [debug] File: Finished code echo "var.N = " ^ var.N => var.N = 5 Mar 06 11:38:53 X: [debug] Evaluating var.i > 2 on channel File Mar 06 11:38:53 X: [debug] Evaluation result: (var.i > 2) = False Mar 06 11:38:53 X: [debug] End of If block Mar 06 11:38:53 X: [debug] Evaluating If block Mar 06 11:38:53 X: [debug] Evaluating var.i > 5 on channel File Mar 06 11:38:53 X: [debug] Evaluation result: (var.i > 5) = False Mar 06 11:38:53 X: [debug] End of If block Mar 06 11:38:53 X: [debug] File: Starting code set var.i = var.i + 1 Mar 06 11:38:53 X: [debug] Processing set var.i = var.i + 1 Mar 06 11:38:53 X: [debug] Setting variable var.i to var.i + 1 on channel File Mar 06 11:38:53 X: [debug] Set variable var.i to 2 Mar 06 11:38:53 X: [debug] File: Finished code set var.i = var.i + 1 => Mar 06 11:38:53 X: [debug] Restarting While block, iterations = 2 Mar 06 11:38:53 X: [debug] Evaluating While block Mar 06 11:38:53 X: [debug] Evaluating var.i < var.N on channel File Mar 06 11:38:53 X: [debug] Evaluation result: (var.i < var.N) = True Mar 06 11:38:53 X: [debug] File: Starting code echo "var.i = " ^ var.i Mar 06 11:38:53 X: [debug] File: Starting code echo "var.N = " ^ var.N Mar 06 11:38:53 X: [debug] Processing echo "var.i = " ^ var.i Mar 06 11:38:53 X: [debug] Evaluating "var.i = " ^ var.i on channel File Mar 06 11:38:53 X: [debug] Processing echo "var.N = " ^ var.N Mar 06 11:38:53 X: [debug] Evaluating "var.N = " ^ var.N on channel File Mar 06 11:38:53 X: [info] var.i = 2 Mar 06 11:38:53 X: [debug] File: Finished code echo "var.i = " ^ var.i => var.i = 2 Mar 06 11:38:53 X: [info] var.N = 5 Mar 06 11:38:53 X: [debug] File: Finished code echo "var.N = " ^ var.N => var.N = 5 Mar 06 11:38:53 X: [debug] Evaluating If block Mar 06 11:38:53 X: [debug] Evaluating var.i > 2 on channel File Mar 06 11:38:53 X: [debug] Evaluation result: (var.i > 2) = False Mar 06 11:38:53 X: [debug] End of If block Mar 06 11:38:53 X: [debug] Evaluating If block Mar 06 11:38:53 X: [debug] Evaluating var.i > 5 on channel File Mar 06 11:38:53 X: [debug] Evaluation result: (var.i > 5) = False Mar 06 11:38:53 X: [debug] End of If block Mar 06 11:38:53 X: [debug] File: Starting code set var.i = var.i + 1 Mar 06 11:38:53 X: [debug] Processing set var.i = var.i + 1 Mar 06 11:38:53 X: [debug] Setting variable var.i to var.i + 1 on channel File Mar 06 11:38:53 X: [debug] Set variable var.i to 3 Mar 06 11:38:53 X: [debug] File: Finished code set var.i = var.i + 1 => Mar 06 11:38:53 X: [debug] Restarting While block, iterations = 3 Mar 06 11:38:53 X: [debug] Evaluating While block Mar 06 11:38:53 X: [debug] Evaluating var.i < var.N on channel File Mar 06 11:38:53 X: [debug] Evaluation result: (var.i < var.N) = True Mar 06 11:38:53 X: [debug] File: Starting code echo "var.i = " ^ var.i Mar 06 11:38:53 X: [debug] Processing echo "var.i = " ^ var.i Mar 06 11:38:53 X: [debug] Evaluating "var.i = " ^ var.i on channel File Mar 06 11:38:53 X: [debug] File: Starting code echo "var.N = " ^ var.N Mar 06 11:38:54 X: [info] var.i = 3 Mar 06 11:38:54 X: [debug] File: Finished code echo "var.i = " ^ var.i => var.i = 3 Mar 06 11:38:54 X: [debug] Processing echo "var.N = " ^ var.N Mar 06 11:38:54 X: [debug] Evaluating "var.N = " ^ var.N on channel File Mar 06 11:38:54 X: [info] var.N = 5 Mar 06 11:38:54 X: [debug] Evaluating If block Mar 06 11:38:54 X: [debug] File: Finished code echo "var.N = " ^ var.N => var.N = 5 Mar 06 11:38:54 X: [debug] Evaluating var.i > 2 on channel File Mar 06 11:38:54 X: [debug] Evaluation result: (var.i > 2) = True Mar 06 11:38:54 X: [debug] File: Starting code set var.N = var.i Mar 06 11:38:54 X: [debug] Processing set var.N = var.i Mar 06 11:38:54 X: [debug] Setting variable var.N to var.i on channel File Mar 06 11:38:54 X: [debug] End of If block Mar 06 11:38:54 X: [debug] Set variable var.N to 3 Mar 06 11:38:54 X: [debug] Evaluating If block Mar 06 11:38:54 X: [debug] Evaluating var.i > 5 on channel File Mar 06 11:38:54 X: [debug] File: Finished code set var.N = var.i => Mar 06 11:38:54 X: [debug] Evaluation result: (var.i > 5) = False Mar 06 11:38:54 X: [debug] End of If block Mar 06 11:38:54 X: [debug] File: Starting code set var.i = var.i + 1 Mar 06 11:38:54 X: [debug] Processing set var.i = var.i + 1 Mar 06 11:38:54 X: [debug] Setting variable var.i to var.i + 1 on channel File Mar 06 11:38:54 X: [debug] Set variable var.i to 4 Mar 06 11:38:54 X: [debug] File: Finished code set var.i = var.i + 1 => Mar 06 11:38:54 X: [debug] Restarting While block, iterations = 4 Mar 06 11:38:54 X: [debug] Evaluating While block Mar 06 11:38:54 X: [debug] Evaluating var.i < var.N on channel File Mar 06 11:38:54 X: [debug] Evaluation result: (var.i < var.N) = False Mar 06 11:38:54 X: [debug] End of While block Mar 06 11:38:54 X: [debug] File: Starting code set var.x = var.x + 1 Mar 06 11:38:54 X: [debug] Processing set var.x = var.x + 1 Mar 06 11:38:54 X: [debug] Setting variable var.x to var.x + 1 on channel File Mar 06 11:38:54 X: [debug] Set variable var.x to 1 Mar 06 11:38:54 X: [debug] End of generic block Mar 06 11:38:54 X: [debug] File: Finished code set var.x = var.x + 1 => Mar 06 11:38:54 X: [debug] Deleting local variable i on channel File Mar 06 11:38:54 X: [debug] Restarting While block, iterations = 1 Mar 06 11:38:54 X: [debug] Evaluating While block Mar 06 11:38:54 X: [debug] Evaluating var.x < var.y on channel File Mar 06 11:38:54 X: [debug] Evaluation result: (var.x < var.y) = False Mar 06 11:38:54 X: [debug] End of While block Mar 06 11:38:54 X: [debug] File: Starting code M0 Mar 06 11:38:54 X: [debug] Processing M0 Mar 06 11:38:54 X: [debug] Requesting update of key inputs, seq 44 -> 46 Mar 06 11:38:54 X: [debug] Updated key inputs Mar 06 11:39:00 X: [debug] Requesting update of key boards, seq 166 -> 167 Mar 06 11:39:00 X: [debug] Updated key boards Mar 06 11:39:04 X: [debug] Requesting update of key inputs, seq 46 -> 48 Mar 06 11:39:04 X: [debug] Updated key inputs Mar 06 11:39:14 X: [debug] Requesting update of key inputs, seq 48 -> 50 Mar 06 11:39:14 X: [debug] Updated key inputs
@timschneider
and when I pause and cancle the printjob, it appears that the printjob is not cancled - I'm not able to re-run a printjob without a restart of DCS.Mar 06 11:44:45 X: [debug] HTTP: Starting code M25 Mar 06 11:44:45 X: [debug] Processing M25 Mar 06 11:44:45 X: [debug] HTTP: Sent M25, remaining space 1512, needed 24 Mar 06 11:44:45 X: [debug] Opening 0:/sys/resurrect.g for writing (not appending), prealloc 0 Mar 06 11:44:45 X: [debug] File 0:/sys/resurrect.g opened with handle #2 Mar 06 11:44:45 X: [debug] Closing file #2 Mar 06 11:44:45 X: [info] Resume state saved Mar 06 11:44:45 X: [debug] HTTP: Finished code M25 => Printing paused at X0.0 Y0.0 Z0.0 Mar 06 11:44:45 X: [debug] IPC#16: Connection closed Mar 06 11:44:45 X: [debug] Received print pause notification for file position 0, reason User Mar 06 11:44:45 X: [debug] Requesting update of key inputs, seq 114 -> 115 Mar 06 11:44:46 X: [debug] Updated key inputs Mar 06 11:44:46 X: [debug] Requesting update of key state, seq 5 -> 6 Mar 06 11:44:46 X: [debug] Updated key state Mar 06 11:44:46 X: [debug] Requesting update of key volumes, seq 1 -> 2 Mar 06 11:44:46 X: [debug] Updated key volumes Mar 06 11:44:46 X: [debug] Requesting update of key inputs, seq 115 -> 116 Mar 06 11:44:46 X: [debug] Updated key inputs Mar 06 11:44:49 X: [debug] Got new UNIX connection via IPC#17, checking permissions... Mar 06 11:44:49 X: [debug] IPC#17: Granting full DSF permissions to external plugin Mar 06 11:44:49 X: [debug] Command processor added for IPC#17 Mar 06 11:44:49 X: [debug] IPC#17: Received command SimpleCode Mar 06 11:44:49 X: [debug] HTTP: Starting code M0 Mar 06 11:44:49 X: [debug] Processing M0 Mar 06 11:44:49 X: [debug] HTTP: Sent M0, remaining space 1512, needed 24 Mar 06 11:44:49 X: [info] Cancelled printing file 0:/macros/test-sbc-3.gcode, print time was 0h 5m Mar 06 11:44:49 X: [info] Starting macro file cancel.g on channel HTTP Mar 06 11:44:49 X: [debug] HTTP: ==> Starting code M0 Mar 06 11:44:49 X: [debug] HTTP: Starting code ; cancel.g (macro code) Mar 06 11:44:49 X: [debug] HTTP: Starting code ; called when a print is cancelled after a pause. (macro code) Mar 06 11:44:49 X: [debug] Processing ; cancel.g Mar 06 11:44:49 X: [debug] HTTP: Finished code ; cancel.g Mar 06 11:44:49 X: [debug] Processing ; called when a print is cancelled after a pause. Mar 06 11:44:49 X: [debug] HTTP: Finished code ; called when a print is cancelled after a pause. Mar 06 11:44:49 X: [debug] HTTP: Starting code ;if move.axes[2].homed (macro code) Mar 06 11:44:49 X: [debug] HTTP: Starting code G10 ; retract filament (macro code) Mar 06 11:44:49 X: [debug] HTTP: Starting code G10 P0 R0 S0 ; disable heater (macro code) Mar 06 11:44:49 X: [debug] HTTP: Starting code M140 P0 S0 ; disable bed heater (macro code) Mar 06 11:44:49 X: [debug] HTTP: Starting code M107 ; disable fan (macro code) Mar 06 11:44:49 X: [debug] HTTP: Starting code G90 ; absolute position (macro code) Mar 06 11:44:49 X: [debug] Processing ;if move.axes[2].homed Mar 06 11:44:49 X: [debug] HTTP: Finished code ;if move.axes[2].homed Mar 06 11:44:49 X: [debug] Processing G10 ; retract filament Mar 06 11:44:49 X: [debug] Processing G10 P0 R0 S0 ; disable heater Mar 06 11:44:49 X: [debug] Processing M140 P0 S0 ; disable bed heater Mar 06 11:44:49 X: [debug] Processing M107 ; disable fan Mar 06 11:44:49 X: [debug] Processing G90 ; absolute position Mar 06 11:44:49 X: [debug] HTTP: Sent G10 ; retract filament, remaining space 1512, needed 24 Mar 06 11:44:49 X: [debug] HTTP: Sent G10 P0 R0 S0 ; disable heater, remaining space 1464, needed 48 Mar 06 11:44:49 X: [debug] HTTP: Sent M140 P0 S0 ; disable bed heater, remaining space 1424, needed 40 Mar 06 11:44:49 X: [debug] HTTP: Sent M107 ; disable fan, remaining space 1400, needed 24 Mar 06 11:44:49 X: [debug] HTTP: Sent G90 ; absolute position, remaining space 1376, needed 24 Mar 06 11:44:49 X: [debug] HTTP: Finished code G10 ; retract filament Mar 06 11:44:49 X: [debug] HTTP: Finished code G10 P0 R0 S0 ; disable heater Mar 06 11:44:49 X: [debug] HTTP: Finished code M140 P0 S0 ; disable bed heater Mar 06 11:44:49 X: [debug] HTTP: Finished code M107 ; disable fan Mar 06 11:44:50 X: [debug] Evaluating If block Mar 06 11:44:50 X: [debug] Evaluating (sensors.gpIn[2].value == 1 && sensors.gpIn[3].value == 1 ) on channel HTTP Mar 06 11:44:50 X: [debug] HTTP: Finished code G90 ; absolute position Mar 06 11:44:50 X: [debug] Evaluation result: ((sensors.gpIn[2].value == 1 && sensors.gpIn[3].value == 1 )) = True Mar 06 11:44:50 X: [debug] HTTP: Starting code G91 ; relative (macro code) Mar 06 11:44:50 X: [debug] Processing G91 ; relative Mar 06 11:44:50 X: [debug] HTTP: Sent G91 ; relative, remaining space 1512, needed 24 Mar 06 11:44:50 X: [debug] HTTP: Finished code G91 ; relative Mar 06 11:44:50 X: [debug] Evaluating If block Mar 06 11:44:50 X: [debug] Evaluating move.axes[2].homed on channel HTTP Mar 06 11:44:50 X: [debug] Evaluation result: (move.axes[2].homed) = False Mar 06 11:44:50 X: [debug] End of If block Mar 06 11:44:50 X: [debug] End of If block Mar 06 11:44:50 X: [debug] Finished codes from macro file cancel.g Mar 06 11:44:50 X: [info] Finished macro file cancel.g Mar 06 11:44:50 X: [debug] Requesting update of key inputs, seq 116 -> 119 Mar 06 11:44:50 X: [debug] HTTP: ==> Unfinished starting code: M0 Mar 06 11:44:50 X: [debug] HTTP: Disposing macro file cancel.g Mar 06 11:44:50 X: [debug] HTTP: Finished code M0 => Mar 06 11:44:50 X: [debug] IPC#17: Connection closed Mar 06 11:44:50 X: [debug] Updated key inputs Mar 06 11:44:50 X: [debug] Requesting update of key job, seq 4 -> 5
Mar 06 12:05:28 Meltingplot-MBL-480-vaswsq DuetControlServer[16205]: [debug] HTTP: Starting code M23 "0:/macros/test-sbc-3.gcode" Mar 06 12:05:28 Meltingplot-MBL-480-vaswsq DuetControlServer[16205]: [debug] Processing M23 "0:/macros/test-sbc-3.gcode" Mar 06 12:05:28 Meltingplot-MBL-480-vaswsq DuetControlServer[16205]: [debug] HTTP: Finished code M23 "0:/macros/test-sbc-3.gcode" => Error: M23: Cannot set file to print, because a file is already being printed
@timschneider I'm sorry but I cannot reproduce it here, print jobs complete/pause/cancel just as expected on my machine. Is it possible that you call
M0
from channelFile
but notFile2
e.g. from a macro file or other conditionals? That could indeed lead to problems. If not, please share the output ofM122
when the machine appears to have finished but it doesn't let you start another print. -
@chrishamm
ok double checked it.the following will not work / will just stuck
if !inputs[state.thisInput].active M0 var x = 0 var y = 1 var N = 5 while var.x < var.y var i = 0 while var.i < var.N echo "var.i = " ^ var.i echo "var.N = " ^ var.N if var.i > 2 set var.N = var.i if var.i > 5 break set var.i = var.i + 1 set var.x = var.x + 1 G90 G1 X100 F6000 G1 Y100 G1 X200 Y200 M0
and the following will work
if !inputs[state.thisInput].active M99 var x = 0 var y = 1 var N = 5 while var.x < var.y var i = 0 while var.i < var.N echo "var.i = " ^ var.i echo "var.N = " ^ var.N if var.i > 2 set var.N = var.i if var.i > 5 break set var.i = var.i + 1 set var.x = var.x + 1 G90 G1 X100 F6000 G1 Y100 G1 X200 Y200 M0
see the M0 at the beginning for the inactive channel.
ok another test revealed that is has something to do with the while code block, which is preventing it from cleaning the print job.
if !inputs[state.thisInput].active M99 M18 X G90 G1 X10 ; not possible due to unhomed x axis M0
and the following is not working / you will be unable to restart the print (it sometimes works / then just repeat)
caution: even the E-Stop via DWC will stuck - be delayed!if !inputs[state.thisInput].active M99 var x = 0 var y = 1 var N = 5 while var.x < var.y var i = 0 while var.i < var.N echo "var.i = " ^ var.i echo "var.N = " ^ var.N if var.i > 2 set var.N = var.i if var.i > 5 break set var.i = var.i + 1 set var.x = var.x + 1 M18 X G90 G1 X10 ; not possible due to unhomed x axis M0
sorry but I'm unable to get an M122 of the above code, due to the fact, that DCS is stuck.Error: Failed to connect to Duet, please check your connection (DCS is not started)
Mar 06 14:14:56 Meltingplot-MBL-480-vaswsq DuetControlServer[26336]: [warn] Received SIGTERM, shutting down... Mar 06 14:15:00 Meltingplot-MBL-480-vaswsq DuetControlServer[26336]: [fatal] Regular shutdown failed, proceeding with unconditional program termination Mar 06 14:15:01 Meltingplot-MBL-480-vaswsq systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+6 (2024-03-01 12:32:32) running on Duet 3 MB6HC v1.02 or later (SBC mode) Board ID: 08DJM-9P63L-DJ3T8-6JKD4-3SJ6K-9A77A Used output buffers: 1 of 40 (17 max) === RTOS === Static ram: 155208 Dynamic ram: 88404 of which 4328 recycled Never used RAM 95196, free system stack 204 words Tasks: SBC(2,ready,0.4%,414) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,0.0%,336) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,336) TMC(4,nWait 6,8.4%,56) MAIN(2,running,91.0%,103) IDLE(0,ready,0.2%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:08:06 ago, cause: software Last software reset at 2024-03-06 14:00, reason: User, Gcodes spinning, available RAM 94716, slot 1 Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 MCU temperature: min 32.6, current 32.9, max 34.8 Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 11.8, current 12.3, max 12.8, under voltage events: 0 Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/440/440, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a, mspos 296, reads 10168, writes 22 timeouts 0 Driver 1: standstill, SG min n/a, mspos 248, reads 10168, writes 22 timeouts 0 Driver 2: standstill, SG min n/a, mspos 168, reads 10169, writes 21 timeouts 0 Driver 3: standstill, SG min n/a, mspos 936, reads 10169, writes 21 timeouts 0 Driver 4: standstill, SG min n/a, mspos 680, reads 10169, writes 21 timeouts 0 Driver 5: standstill, SG min n/a, mspos 804, reads 10171, writes 19 timeouts 0 Date/time: 2024-03-06 14:08:31 Slowest loop: 66.36ms; fastest: 0.06ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC* is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2* is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000001 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 31279 clear 4266391 Extruder 0: pos 2160.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === CAN === Messages queued 4333, received 0, lost 0, errs 2298737, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 2435/0/0 Tx timeouts 0,0,2434,0,0,1897 last cancelled message type 4514 dest 127 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 4628/4628 SPI underruns 0, overruns 0 State: 5, disconnects: 1, timeouts: 1 total, 1 by SBC, IAP RAM available 0x255b4 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server version 3.5.0-rc.3+7 (2024-03-06 11:22:55, 32-bit) Failed to deserialize the following properties: - MoveSegmentation -> Int32 from 2.0 Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 40.79, max time between full transfers: 54.2ms, max pin wait times: 37.8ms/3.0ms Codes per second: 0.02 Maximum length of RX/TX data transfers: 4349/48
@timschneider said in [3.5.0-rc.3+5] [bug] nested while job Illegal para letter '.':
Hence my question from the previous post. M0 attempts to synchronize both file streams but since File2 never reaches it due to your check, it leads to a deadlock. I'm going to investigate why it might delay E-STOP, though.
You should never call M0/M1/M2/M24/M25/M32 from a single file channel only.
Even without your condition at the top the file should behave like a macro.
@chrishamm
ok, I missunderstood the concept of the two channels at all I guess - I thought if if tell channel File2 to leave/stop the file, it will just stop working as I do not utilize multiple motion systems, but in fact it turned out to do the opposit.Anyhow the second example from above which will also fail is not using the conditional M0 as shown above.
Unfortunately, I cannot provide any further information from the journal this time, as there is no information / exceptions - it is just sitting in a dead lock -
@timschneider If you do not use two motion systems you should not worry about File2 at all.
There was a recent bug which could lead to
abort
being executed even on an inactive file channel (aka File2) and the if-statement at the start of your files above (at least followed only by M99) was meant to work-around this particular case. But it won't be needed in the next versions either.I could reproduce the deadlock that you managed to provoke and I am working on a fix. I'll keep you posted.
@timschneider This is now fixed as well.
@chrishamm
Thanks for the great patch! Your work is outstanding! It's impressive to see the passion and dedication you and the duet3d team put into the software and hardware!Now that all the show-stoppers are out of the way, we are going to switch completely to duet3 in the sbc setup. Starting with 4 closed loop steppers with 4 1HCL and 4 open loop steppers directly on the 6HC. Also two filament monitors and two IR probes per machine. This will be followed at a later stage by two tool boards and a distribution board per machine. I am excited to see the results.
