Duet 3 Tool Distribution Board
Do I need a Duet 3 Tool Distribution board to run two Duet 3 Roto Toolboards from a Duet 3 Mini 5+? For an IDEX using two Rotos for example.
@SonnyD1 you do not, you an daisy chain them without the tool distribution board. or, if the stubs are short enough (~1m) then connect them both as stubs.
@T3P3Tony Ok outstanding. Thank you!
