Wifi 2.1beta6 from 3.5.0-rc.2/3 still disconnecting
@Chriss do you have docker running on your host by chance? Depending on how that's set up traffic may be routed into the docker network and then you won't be able to get to the wifi connected printer.
@Chriss Thanks for the reply.
I'm not 100% sure, so please do not nail me down to it. But I think that it is 3.5.0RC2 I had before on it. But I saw that behaviour with the reconnects in 3.4 something already. It never bother me because the printer did always reconnect.
That's ok. So you suspect it was 3.5.0RC2 previously, do you happen to remember also the WiFi firmware version?
My two other printers and my "on my desk test board" are on 3.4.6. And I have found a other printer which I did not upgraded to RC2, it is still 3.5.0rc2 and this one does not have the problem. And this is very much in use at the moment.
In the second sentence, do you mean to say "not upgraded to RC3, it is still 3.5.0rc2" or "not upgraded to RC2, it is still 3.5.0rc1 (or maybe 3.4.x)". Also, can you also confirm the WiFi firmware version of these boards?
Just to be clear here about the status and for unblocking my confusion:
1: RC3 with that problem, with PanelDue and printing (My Voron 2.4)
2: RC3 without problem, without PenalDue and not printing (VCast)
3: RC2 without problem, without PenalDue and printing (V0)
4: 3.4.7 without problem, without PenalDue and not printing (Workbench, VCore, Creality)Can you also confirm the wifi firmware version for these boards?
You'll notice that I'm constantly asking for the WiFi firmware version, since flashing a certain RRF version does not guarantee a certain WiFi firmware version. That is, you might have upgraded the RRF to 3.5.0rc2 or rc3, but the wifi firmware version can still be on an older version (or the opposite can also be true - you might have new WiFi firmware + old RRF).
@oliof said in Wifi 2.1beta6 from 3.5.0-rc.2/3 still disconnecting:
For god sake... no Docker in my household. Seriously: I have a bridge device for other reasons. (And other hosts can not reach the board too)
Cheers, Chriss
The cable just arrived, here is the status of my Voron 2.4 with 3.5.0rc3 and the corresponding Wifi version:
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.3 (2024-01-24 17:56:48) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: V9NWJ-R296U-D65J0-40KM6-4113Z-HM83B Used output buffers: 1 of 40 (40 max) Error in macro line 21 while starting up: in file macro line 21 column 33: M558: unknown variable 'probe_settingsH' === RTOS === Static ram: 103200 Dynamic ram: 126032 of which 12 recycled Never used RAM 8500, free system stack 122 words Tasks: NETWORK(1,ready,103.0%,156) HEAT(3,nWait 6,0.9%,326) Move(4,nWait 6,29.9%,243) CanReceiv(6,nWait 1,1.5%,771) CanSender(5,nWait 7,0.8%,328) CanClock(7,delaying,0.2%,349) TMC(4,nWait 6,42.2%,102) MAIN(1,running,44.2%,500) IDLE(0,ready,6.2%,30) AIN(4,delaying,25.1%,260), total 254.2% Owned mutexes: USB(MAIN) === Platform === Last reset 29:39:53 ago, cause: power up Last software reset at 2024-02-04 02:34, reason: User, Gcodes spinning, available RAM 8420, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 106795063, completed 106795063, timed out 0, errs 0 MCU temperature: min 31.3, current 42.6, max 50.6 Supply voltage: min 24.2, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/48, heap memory allocated/used/recyclable 2048/868/104, gc cycles 471 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 83, reads 7572, writes 83, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 66, reads 7589, writes 66, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 64, reads 7591, writes 64, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 7644, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 79, reads 7576, writes 79, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 79, reads 7576, writes 79, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 78, reads 7577, writes 78, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2024-02-06 12:38:38 Cache data hit count 4294967295 Slowest loop: 527.32ms; fastest: 0.10ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 11.5ms, write time 122.4ms, max retries 0 === Move === DMs created 83, segments created 34, maxWait 4268975ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 913360, completed 913360, hiccups 0, stepErrors 0, LaErrors 0, Underruns [438, 0, 8], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 1964276, received 2196723, lost 0, errs 0, boc 0 Longest wait 7ms for reply type 6029, peak Tx sync delay 441, free buffers 26 (min 24), ts 533967/533966/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 522.93ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 0 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta6 MAC address f0:08:d1:02:e6:75 Module reset reason: Power up, Vcc 3.40, flash size 2097152, free heap 33592 WiFi IP address 192.168.1.69 Signal strength -64dBm, channel 6, mode 802.11n, reconnections 1 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
(The IP is correct, the MAC has a reservation in my DHCP server for that IP)
More to come soon....
Cheers, Chriss
@rechrtb said in Wifi 2.1beta6 from 3.5.0-rc.2/3 still disconnecting:
I suspect that it was the version which comes with 3.5.0RC2. I'm a lazy dude here. I download all files from the releases page and upload all of them to the printer. I have the confidence that the board does picks the correct files.
I just saw a typo... sorry, my bad! No4 is not 3.4.7 they are on 3.4.6, is think that there is no 3.4.7 as far as I know. Sorry, typo.
The RC[2|3] have the versions from the releases in github. So RC2 and RC3 are on 2.1beta6.
Got you point. Well, the situation is a bit strange, isn't it? We see rc RC2 board with 2.1beta6 working, but the RC3 board is failing. At least the one who was printing.
Correct me if I'm wrong but the DuetFW seams to work fine. The printer was printing, the PanelDue worked so that is cool. We see from my last post that the Formware sees a connected Wifi module etc, so the WiFi module reported (or is reporting) the current connection status.My Access told me that the WiFi module is connected. But the module itself does not react on any IP traffic anymore.
Is there any M-Command to ping a ip from the Mini5+? (Like M4711 T192.168.1.1) I have a feature request if not.
If would be nice to see if it would help send some traffic from the WiFi to module too the AP and the wired network behind the AP.
I will walk the dogs for about an hour and will restart the disconnecting printer than. I hope that I bring him back to the failing mode than. Let me know if you need more info from the board in its current (disconnected) state.
Cheers, Chriss
@moth4017 It seems like your problem is different to that being seen by @Chriss and he is also running Duet hardware, so perhaps we should continue looking into your problem on another thread. I've created one here: https://forum.duet3d.com/topic/34897/wifi-disconnects-but-connects-after-refresh
@Chriss Ok, I may finally have hit the same issue you're experiencing after running my setup for a few days.
The logs you would have should tell if it's the same issue. Please turn on debug outputs for network and wifi via
M111 P1 S1
andM111 P14 S1
and also messages loggingM929 P"eventlog.txt" S3
Keep the serial terminal open and also log serial terminal to a file - I think most serial terminals support this while waiting for disconnect.Once in the disconnected state:
- See wifi module if LED is on.
- Send
M122
command and take note of the output (if the serial terminal is logging to file, the output should be in the file automatically). - Verify from access point if module is connected (the reason I ask is that you mentioned previously that the access point reports the module is connected, however in my case it's not - I was wondering if you perhaps mistook the DHCP lease list as the connected stations list?).
After the above, you can try reviving the module with
M552 S-1
andM552 S1
. Please post the serial terminal log and theeventlog.txt
here afterwards. -
@rechrtb Thanks god, I'm not the only one! I was a bit scared that it is a race condition with my home AP.
Anyway, I executed the commands you mentioned. I was about to perform 3 "tiny" prints in a row since I have the usb cable. I need to leave now, more updates tomorrow.
Nope that is not the case, the DHCP server and my AP are two different devices.
(Still waiting for the disconnect)
Cheers, Chriss
Hi @gloomyandy Hi @rechrtb
The board was again in the failed state when I came back to my office. The printer was not printing and not pingable anymore. So I went to the terminal session and did the requested "M122", and here is the outcome:
That is strange, I was able to send the M122 to the board yesterday when it was in the failed state before I connected the USB. Could the power via the USB have any influence here?
The board is still not reachable via the network. I have the feeling that the reset did not perform a "reset" on the wifi module. That would match my obeservations from the past. I had to power cycle the printer to bring it back online.
Cheers, Chriss
Here are the requested log files. I was unable to upload them as txt or as bz2. So here is a tar file which I names .bin. Extract the tar file and you will find a bz2 which is the output from the serial since yesterday. And the eventlog.txt from yesterday till the it failed.
The :
M552 s-1
M552 s1Brought back the Wifi access if this is what you want to read.
And one more word about my console logfile. You will see there at the end that the board did the reset when I did the M122. The 2nd M122 was successfully. (See my other post)
I hope that this help you guys to find the issue.
Do you want me to downgrade the board to RC2 and the older WiFI firmware now? Or Should I keep RC3 and downgrade WiFi only?
I will be off for 6 days from Friday onwards and can not test anything during this period.
Cheers, Chriss
@Chriss From your log file, you sent M112 (which is emergency stop), not M122! After M112, you need to send M999 to reset. Did you notice if the WiFi LED was still on?
I changed the file ending of the log file from .bin to .txt to look at it. Usually the log files are in text format - did you change the ending to .bin? There's a lot of garbage text at the end of the log file. I don't know what that is, or if it is useful; one for @rechrtb to have a look at.
You are right.... I did a 2nd typo... bloody hell... I think that we need to do the drill again, don't we?
Not sure what you mean, the file I uploaded is a tar file which I renamed to .bin. There is one bz2 file in it (the logfile from the serial) and a .txt which is the enventlog from the sd card. You should not need to open any .bin file.
Just to be on the save site here: You call the "LED ESP" on the WiFi module "WiFi LED", don't you? Yes, that one was still on.
Cheers, Chriss
@Chriss Sorry, didn't read your instructions about it being a tar file. I can read them now! Can't see anything immediately obvious, but hopefully there's something there for @rechrtb
Yes, by "WiFi LED" I mean the green (when on) LED next to the WiFi module, labelled "ESP" on the board silkscreen. The WiFi module itself doesn't have an LED on it.
Good that it is clear now... I did not see any unexpected too. The module looks good, the AP thinks that there is a connection with the module etc. The only thing is that the module does not react anymore.
Thanks for the confirmation, we spoke about the same LED than. And it was on.. I was a bit confused by the wiring diagram it looks slightly as the LED is on the module but it is next to it and there is "ESP" printed next to it.
Please let me I will reboot the board now and will wait for the next disconnect to do the same drill, this time without the typo, hopefully. Let me know if I can stop that drill if you think that you have enough information.
Btw: The disconnect happened while the printer was not printing. Just fyi
Cheers, Chriss
@droftarts @gloomyandy @rechrtb
Good morning... The printer is again in the failed state.... Before I forget it: The WiFi LED is blinking
It was off after "M552 s-1" (not a surprise) and turned back on after "M552 s1" which is not a surprise too. My apologies, I was not precise enough in the past about the LED, I wrote about "on or off" only. Bot about the blinking.
Do you guys want to have the log files again? (I can tell you so far that they do not look different.)
Please let me know, I will be off for 6 days from tomorrow early morning.
Cheers, Chriss
@Chriss Yes, please post the logs, as this is different from what I have experienced (WiFi LED stays lit) and what others have experienced (lots of 'ResponseBusy' messages in the serial console). So any information would be useful. Hopefully you did a M122 from the serial console while it was in the failed state?
You will find the file attached, same drill as last time.
no3.binI'm not so convinced anymore that the WiFi LED was permanently on last time. It could be that it was blinking... My apologies but is was early in the morning before my first cup of tee and I wrote the message a bit later.
And one more thing: I have not seen that before... I the M552 drill, and the board is pingable since than. But I did not tried to reach a higher layer. I tried to download the enventlog for you the FTP server did not reacted really:
The port is obviously open but the application seams not to react anymore. Telnet has very much the same behaviour:
And the webui is very much the same, I can curl it, I get an connection but the daemon behind the port is not responding. I had to cut the power to solve that.
I have here a other mini 5+ on my work bench which does literally nothing. There is the stepper extension board attached but no sensor, no stepper. What do you think? Would it make sense to push RC3 to that board and copy the config, just to see whether the problem will pup up there too? Just to remove the dependency from my physical printer.
And I may be able to connect that board to a other wifi to remove that variable too.Or we test with a very simple config file to strike that out. But I think that I should do all of that test with my test rick than with my main printer.
Cheers, Chriss
@Chriss I haven't seen your config.g in a while, perhaps you can post that too? I assume FTP and telnet are turned on in that? That would use up a couple more sockets, though they are supposed to be released when not in use, for other connections. I'll pass on all the info to @rechrtb for him to look at.
@droftarts Sure, the services are enabled, you will get a "connection refused" if not. And they work after the reboot. I wanted to indicate that it seems that the WiFi modules get stuck when this failed state happens. And the "turn in off and on again" drill did not brought it back to normal operations. It is better (back bingable) but not fully working. I have seen that behaviour often on Un*x aor Linux systems when the OS had not enough resources for the demon behind to port. So the TCP handshake worked but the process behind it was unable to respond.
Here is the current config.g. (Kindly ignore the typos, I'm German)
; Hardware: Duet Mini 5+ ; Toolboard 1.1 LC ; Stepper XY = LDO 0,9° 2Amax LDO-42STH40-2004MAC ; Stepper Z = LDO 1,8° 2Amax LDO-42STH48-2004AC ; Stepper E = LDO 1,8 1Amax LDO-42STH20-1004ASH ; Enable network if {network.interfaces[0].type = "ethernet"} M552 P0.0.0.0 S1 else M552 S1 ; Network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"v2" ; set printer name M669 K1 ; 1=select CoreXY mode 0=Cadasian ;; Helpful Toolboards commands ; M115 B121 ; Show board 121 ; M997 B121 ; Update tool 121 ; M122 B121 ; Detailed status of toolboard G4 S1 ; wait 1s for expansion boards to start ;;; Drives ;X M569 P0.2 S1 D3 ; physical drive 0.2 goes forward M584 X0.2 ; Map the stepper to X ;Y M569 P0.1 S0 D3 ; physical drive 0.1 goes backward M584 Y0.1 ; Map the stepper to Y ;; Z ; - front left M569 P0.5 S1 D3 ; physical drive 0.5 goes forward ; - front right M569 P0.6 S0 D3 ; physical drive 0.6 goes backward ; - back right M569 P0.0 S1 D3 ; physical drive 0.0 goes forward ; - back left M569 P0.4 S0 D3 ; physical drive 0.4 goes backward M584 Z0.5:0.4:0.0:0.6 ; Mapping ;; E M569 P121.0 S0 D3 ; Extruder stepper goes backward M584 E121.0 ; Map the E stepper to E ; Stepper settings M350 X16 Y16 Z16 E32 I1 ; configure microstepping with interpolation M92 X160 Y160 Z400 E823 ; set steps per mm (800 from manuall, measured 823 M98 P"/macros/print_scripts/speed_printing.g" ; Accelerations and speed M906 X1400 Y1400 Z1000 E700 I30 ; set motor currents (mA) and motor idle factor in per cent (E stepper max 1A) M84 S120 ; Idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X250 Y258 Z210 S0 ; set axis maxima ;; Endstops -- Display status with: M119 M574 Y2 S1 P"0.io5.in" ; Y M574 X2 S1 P"!0.io6.in" ; X M574 Z0 P"nil" ; No endstop we have the switch and a probe M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z probe M98 P"/macros/print_scripts/activate_z_probe.g" ; Z-level settings ;M671 X-75:-75:288:289 Y0:320:320:0 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) ;M671 X-75:-75:288:289 Y0:328:328:0 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) M671 X-75:-75:288:289 Y0:358:358:0 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) ;; Define the mesh ;M557 X5:245 Y22:245 S35 ; spacing ;M557 X5:245 Y22:245 P9 ; grid (points per axis) M557 X5:245 Y22:220 P9 ; grid (points per axis) ;; Heaters :: Tune with: M303 H0 S110 ; Bed M308 S0 P"0.temp0" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out5+out6" T0 Q10 ; create bed heater outputs for both SSRs on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ;; Bed Corner temp sensor (2=Orange, 3=Brown, 4=Green, 5=Yellow, 6=Purple 7=Black, ) ; Configure Bed corner temp sensor as thermistor on pin temp2 M308 S5 P"0.temp2" Y"thermistor" A"Bed-Corner" T100000 B4138 ; Hotend ; Tune in with: M303 H1 S270 (270=Temp) (M500 to save) ; Show current settings M307 H1 ;M308 S1 P"121.temp0" Y"thermistor" A"Hotend" T500000 B4702 C1.171057e-7 ; configure sensor 1 as thermistor on pin temp1 Mosquito ;M308 S1 P"121.temp0" A"Hotend" Y"thermistor" T100000 B4725 C7.06e-8 ; define E0 temperature sensor Rapido Argo M308 S1 P"121.temp0" A"Hotend" Y"thermistor" T100000 B4725 C7.060000e-8 ; define E0 temperature sensor e3d revo M950 H1 C"121.out0" T1 ; create nozzle heater output on 0.out3 and map it to sensor 1 M143 H1 S300 ; set temperature limit for heater 1 to 300C ;; Fans ; Fan for the printed part: M950 F0 C"121.out1" Q500 ; create fan 0 on pin 0.out9 and set its frequency M106 P0 S0 H-1 C"Part" ; set fan 0 value. Thermostatic control is turned off ; Fan for the Hotend: M950 F1 C"121.out2" Q500 ; create fan 1 on pin 0.out9 and set its frequency M106 P1 S1 H1 T45 C"Hotend" ; P="set fan 1" S="value" H="Thermostatic control Heater No." T=" is turned on at 45°C" ;; Tool M563 P0 S"Tool" D0 H1 F0 ; define tool G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Filament sensor : Status M591 D0 ;M591 D0 P7 C"io4.in" L7 R50:150 E5 S0 ;pulse, disabled, 7 mm/pulse, measure every 22 sec, minimum 50 maximum 250, S1 = Enabled S0 = Disabled ;M591 D0 P1 C"io4.in" S1 M950 J3 C"!io4.in" ; Create a trigger on io4.in (NC) M581 P3 T3 S0 R1 ; R1=Trigger only while printing ;; Chamber temp sensor M308 S4 P"0.temp1" Y"thermistor" A"Chamber" T100000 B4138 ; configure Chamber temp sensor as thermistor on pin temp1 ;; Input Shaping ; Accelerometer https://duet3d.dozuki.com/Wiki/Input_shaping M955 P121.0 I05 ; specify orientation of accelerometer on Toolboard 1LC with CAN address 121 ; Input Shaping ;M593 P"zvd" F40.5 ; use ZVD input shaping to cancel ringing at 40.5Hz ;M593 P"none" ; disable input shaping ;M593 P"custom" H0.4:0.7 T0.0135:0.0135 ; use custom input shaping ; PA https://duet3d.dozuki.com/Wiki/Pressure_advance M572 D0 S0.025 ;;;;;;;;;;;; Setup Only ;M564 S0 H0 ; Allow movement over the endstops ;M302 P1 ; allow cold extrusion ;M302 S1 ; deny cold extrusion ;;;;;;;;;;;; Setup Only END ;; Case Cooling ; Temps M308 S9 P"mcu-temp" Y"mcu-temp" A"Mainboard" ; define sensor 9 to be mcu temperature ; Case Fans M950 F3 C"!0.out3" Q50 ; Fan on out3 ground on top pin, plus on 3rd pin from top (V_OUTLC1) M106 P3 C"Base" S120 ; Setup the FAN and slow it down ; Nevermore m950 F4 C"0.out0" Q50 m106 P4 C"Nevermore" S0 ; Define the LED stripe and turn it off M950 F5 C"0.out1" Q100 ; LED on out1 M106 P5 C"LED" S0 ; Make sure that the LEDs are off ; Trigger on the toolboard ;#M950 J5 C"^121.button0" ;#M581 P4 T5 S0 ;######################################## M950 J1 C"^0.io1.in" M581 P1 T2 S0 ;M572 D0 S0.037 ; Set preasure Advance Gemessen M501 ; Load config-override.g ;; Serial interface ; Duet M575 P1 S1 B57600 ;;;;;; Old Display ;M575 P1 B115200 S1 ;; Mini 12864 ;M918 P2 ;M918 P2 E4 R3 C100 ;M150 X2 R255 U255 B255 S3 ; set all 3 LEDs to white ;M150 X2 R0 U255 B0 S3 ; set all 3 LEDs to red T0 ; Select the tool 0 as default ; Make sure that all heaters are off M104 S0 ; Extruder temp to 0 M568 P0 A0 ; Extruder heater off M140 S0 ; Set the bed temp to 0 M140 S-276 ; Bed heater off ; Some variables for later global tool_temp_initial=0 global bed_temp_initial=0 global debug=false ; AutoZ global klicky_home=true global qgl_done=false global nozzle_cleaned=false global Zswitch_homed=false global probetype="euclid" global clickystatus = "none" global probe_settingsH=10 global probe_settingsA=1 global autoz_temp2=20 # Stealthburner LEDs: global sb_leds="n-off" M98 P"/macros/sb_leds/sb_leds.g" set global.sb_leds="hot" set global.sb_leds="n-off" ;set global.sb_logo="red" ;set global.sb_leds="n-off" ;global sb_nozzle="off" ; M307 H0 R0.327 C227.635:227.635 D5.48 S1.00 V24.4 B0 I0 ; R altered for a firmware bug ; EOF[chriss@leela sys]$
