Will Duet support Raspberry Pi 5?
The Raspberry Pi 5 will be released in October. With a more powerful GPU can we expect any speed improvements, such as a faster Duet Web Control interface, and will the current image support it, or are there plans to?
Thanks
@p8blr DSF/DWC is built on top of raspberry Pi OS (the official OS distribution), so theres no reason why it won't be supported. It'll just be a case of a new image release when the sources are available
As I bought a PI5 for interfacing with my 6XD, I wonder, is there some support planned for PI5? DSF, I mean...
I am sure that many are hungry... yammm!
Thanks for quick sharing! -
@p8blr I am working on an upgrade to the latest Raspberry Pi OS, but unfortunately Chromium has issues starting in fullscreen mode in that version. I still need to fix that before I can publish a first preview.
@chrishamm how us the raspberrypi 5 fix coming?
@WOPR73 We're testing the RC in-house and we will publish the first version quite soon.
@chrishamm I found this thread while trying to get a new RPI 5 working with my duet board using this guide: https://docs.duet3d.com/User_manual/Machine_configuration/DSF_Other
I am getting an SPI buffer size error. I am not sure if I am doing something wrong or if this is a known issue that you are working on, but I thought I would drop it here and see if it helps.
@kiendeleo have you tried the new bookworm image? https://forum.duet3d.com/topic/34825/new-experimental-duetpi-bookworm-builds-available?_=1708348558309
@jay_s_uk I didn't know that existed; I will try that...
