WIFI Disconnect Issue
Hello! I'm facing an issue with the duet board. It was working fine and got connected to the wifi. Suddenly it got disconnected and if I run the command
M552 S-1
M552 S0
M552 S1 ;It does not start the wifi module. Only one message is shown on the console window - "connected". I tried using the M587 but the screen is still blank. I attached a picture of the screen. Is there anything wrong with my board? -
Can you connect to the board via USB terminal and send the same commands?
Does it give an M122 report?
What firmware version are you running?
Which Duet board?Try working through this guide and see what you find works and doesn't work.
https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
This post is deleted!
