Multiply issues with new 6HC
@droftarts Good Evening, Here are my current config and homing files. I am using StepperOnline motors. I have these on my other printer and they work great. They are Bipolar 2.0 A. I added the line in my config for the WiFi, I just don't think the server is starting up automatically like it should, If I do a M552 I1 S1 and look on the Machine_ specific page it shows the firmware number. I still never get any lights on the wifi module itself.
Thanks,
Justin; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:37 GMT-0600 (Central Standard Time) ; General M550 P"Duet 3" ; set hostname ; Network M552 P0.0.0.0 S1 ; configure Ethernet adapter M586 P0 S1 ; configure HTTP M552 I1 S1 ; Smart Drivers M569 P0.0 S1 D3 V2000 ; driver 0.0 goes forwards (X axis) M569 P0.1 S0 D3 V2000 ; driver 0.1 goes backwards (Y axis) M569 P0.2 S1 D3 V2000 ; driver 0.2 goes forwards (Z axis) M569 P0.3 S1 D3 V2000 ; driver 0.3 goes forwards (Z2 axis) M569 P0.4 S1 D3 V2000 ; driver 0.4 goes forwards (Y2 axis) M569 P0.5 S0 D3 V2000 ; driver 0.5 goes backwards (extruder 0) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0.0 Y0.1:0.3 Z0.2:0.3 ; set axis mapping M350 X16 Y16 Z16 U16 V16 I1 ; configure microstepping with interpolation M906 X1000 Y1000 Z1000 ; set axis driver currents M92 X80 Y80 Z400 ; configure steps per mm M208 X0:300 Y0:300 Z0:300 ; set minimum and maximum axis limits M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 ; set accelerations (mm/s^2) ; Extruders M584 E0.5 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E1000 ; set extruder driver currents M92 E420 ; configure steps per mm M566 E120 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E250 ; set accelerations (mm/s^2) ; Kinematics M669 K0 ; configure Cartesian kinematics ; Probes M558 K0 P9 C"""io2.in""" H5 F120 T6000 ; configure BLTouch probe via slot #0 G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height M950 S0 Cio2.out ; create servo #0 for BLtouch ; Endstops M574 X1 P"io0.in" S1 ; configure X axis endstop M574 Y1 P"io1.in" S1 ; configure Y axis endstop M574 Z1 S2 ; configure Z axis endstop ; Mesh Bed Compensation M557 X25:275 Y25:275 S40:40 ; define grid for mesh bed compensation ; Sensors M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0 M308 S1 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1 ; Heaters M950 H0 C"out0" T0 ; create heater #0 M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0 M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0 M950 H1 C"out1" T1 ; create heater #1 M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1 M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 ; Heated beds M140 P0 H0 ; configure heated bed #0 ; Fans M950 F0 C"out3" ; create fan #0 M106 P0 S0 L0 X1 B0.1 ; configure fan #0 M950 F1 C"out4" ; create fan #1 M106 P1 S0 B0.1 H1 T45 ; configure fan #1 ; Tools M563 P0 D0 H1 F1 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:41 GMT-0600 (Central Standard Time) ; lift Z G91 ; relative positioning G1 H2 Z5 F6000 ; move Z relative to current position to avoid dragging nozzle over the bed G90 ; absolute positioning ; home XY var xTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm var yTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm G91 ; relative positioning G1 H1 X{-var.xTravel} Y{-var.yTravel} F600 ; coarse home in the -X and -Y directions G1 H2 X5 Y5 F6000 ; move back 5mm G1 H1 X{-var.xTravel} Y{-var.yTravel} F300 ; fine home in the -X and -Y directions G90 ; absolute positioning ; home Z var xCenter = move.compensation.probeGrid.mins[0] + (move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0]) / 2 - sensors.probes[0].offsets[0] var yCenter = move.compensation.probeGrid.mins[1] + (move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1]) / 2 - sensors.probes[0].offsets[1] G1 X{var.xCenter} Y{var.yCenter} F6000 ; go to bed centre G30 ; probe the bed M98 P"homeU.g" ; home U axis M98 P"homeV.g" ; home V axis
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:42 GMT-0600 (Central Standard Time) ; lift Z G91 ; relative positioning G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed G90 ; absolute positioning ; home X var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm G1 H1 X{-var.maxTravel} F600 ; coarse home in the -X direction G1 H2 X5 F6000 ; move back 5mm G1 H1 X{-var.maxTravel} F300 ; fine home in the -X direction G1 H2 Z-5 F6000 ; lower Z again
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:42 GMT-0600 (Central Standard Time) ; lift Z G91 ; relative positioning G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed G90 ; absolute positioning ; home Y var maxTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm G1 H1 Y{-var.maxTravel} F600 ; coarse home in the -Y direction G1 H2 Y5 F6000 ; move back 5mm G1 H1 Y{-var.maxTravel} F300 ; fine home in the -Y direction G1 H2 Z-5 F6000 ; lower Z again
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:42 GMT-0600 (Central Standard Time) ; lift Z G91 ; relative positioning G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed G90 ; absolute positioning ; home Z var xCenter = move.compensation.probeGrid.mins[0] + (move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0]) / 2 - sensors.probes[0].offsets[0] var yCenter = move.compensation.probeGrid.mins[1] + (move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1]) / 2 - sensors.probes[0].offsets[1] G1 X{var.xCenter} Y{var.yCenter} F6000 ; go to bed centre G30 ; probe the bed
@yagodajm Good evening, Ok I got all the motors wired up and double-checked everything. I still can't get anything to home correctly with the home files above. When I do home all or home each one, it acts like it will home and just stops and the axis turns blue like it has been homed. I can move that axis, but only in one direction.
I finally got the WiFi to connect. I was in the DWC and ran a M552 I1 S0, M552 I1 S1, and a M587 with the WiFi network and password. I got a green LED and it connected. Do I just have to add the M552 I1 S1 to the config file for it to connect every time?
I will continue to got through Home files to see what I am missing. One not, this printer is one where the bed raises up and down and the Y and X move back and forth. Do I have to do a different config? I also have two motors on Z on two separate axis, two motors on Y on two separate axis, and X by itself. Would it just be better to tie the two Z and two Y to one driver?
Thanks for all of you help so far.
Justin
@yagodajm Ok, I got X and Y to home correctly, I had to set the endstops to Low. Those now home properly. I am still having an issue with Z and the BL touch probe.
This is what the configurator tool created.
I get this error on start-up Error in start-up file macro line 49: Unknown pin name '"io2.in"'
My question is what are there 3 sets of " around the io2.in pin? And why are there now around io2.out?
If I remove the " from the io2.in and add a set to io2.out, then the on homing after x and Y home, the hotend will move to the center of the bed and I get this error. Error: line 12 column 135: meta command: array index out of bounds
Error: Failed to home axes ZI looked through the documentation, but Can't find any answers.
Thanks,
Justin -
@yagodajm you should have 1 set of " around the io pin
@jay_s_uk I tried that I still get this error, Error: line 12 column 135: meta command: array index out of bounds
Error: Failed to home axes Z. I have tried every combination so far. I also noticed that when I try and test my BLTouch nothing happens. When I first turn on my printer it does a double click and it is red, so I know it works. -
@yagodajm said in Multiply issues with new 6HC:
Error: Failed to home axes Z. I have tried every combination so far. I also noticed that when I try and test my BLTouch nothing happens. When I first turn on my printer it does a double click and it is red, so I know it works.Why are you trying to find xCenter, etc using move.compensation.probeGrid.mins[0] and so forth?
@fcwilt This is the file that the RRF Config tool made. I think everything is different with the 3.5 config tool now. My other printer is running on 3.4.6 so the files are all different. I can't use those files for a comparison.
The error you mentioned suggests that the lines that are setting xCenter and yCenter are attempting to index into values that do not exist.
As a test set xCenter and yCenter directly to values that you compute by hand and see if the error goes away.
@fcwilt Good afternoon, Ok I finally got a chance to make changes to the home file. I just set X150 Y150. That worked, the error went away and the z axis homed. I am not sure why the RRF is making the home files like that now, it is very confusing.
One last question, my hotend fan comes right on when I start up my printer. I changed that line every which way and can't get it to shut off. It should only come on when the hotend gets to 45c. It is just a regular 2 wire fan.
I have it wired on out4 GND and V_outLC1.
Any ideas?
Thanks,
Justin -
It's a very bad idea because it relies on values that may not be set when homing Z, as you have found.One last question, my hotend fan comes right on when I start up my printer. I changed that line every which way and can't get it to shut off. It should only come on when the hotend gets to 45c. It is just a regular 2 wire fan.
It should be wired to OUT4 instead of OUT4 GND.
@fcwilt thank you, that worked. The part fan should be wired the same way, correct.
Thanks,
Justin
