Need help setting up a Mellow Fly-RRF36 v1.0 board
Yes, the standard CANFD1 connector is working!
Thank you both for your support.@gloomyandy said in Need help setting up a Mellow Fly-RRF36 v1.0 board:
That looks like you are connecting to CANFD0 on the Duet board, you need to connect to CANFD1 (which is the connector next to the one you are using). CANFD0 is not normally used for the connection of Duet expansion boards (and normally runs a different CAN protocol for talking to ODrives I think, not even sure if it is enabled)
May I suggest adding this detail to the insturctions? Since the toolboard comes without a RJ11 connector, I assumed that it is supposed to be connected to CANFD0 on the mainboard...
@MaxGyver https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6HC_Hardware_Overview#can-fd-bus-expansion states that you should use the RJ11 connector, but does not discuss CAN0 at all, so I guess you are right, this could be clarified.
One for @droftarts
@MaxGyver CAN0 was integrated into the RJ11 socket on earlier 1HC board versions, and was split out to a separate header on the v1.02 board revision, but this change is not actually mentioned in the Revision History, and I'm not sure why. I've asked @T3P3Tony.
But the others are correct; currently only CAN1 is used in the current releases. I understand CAN0 can be activated, and the Hangprinter fork uses it to initialise their motor drivers. It's there on all boards for the time it is needed, I guess that's forwards-compatibility?!
I'll update the documentation when I hear back from Tony.
@droftarts said in Need help setting up a Mellow Fly-RRF36 v1.0 board:
If you can inquire how to activate the CAN0 that would be helpful. My quick searching came up empty, as it is easier to wire up the CAN0 to Mellow products than chop an RJ11 connector in half and wire it up that way
@droftarts You would need to edit and rebuild the firmware to use the other can-fd channel, but I very much doubt if running things in that configuration has been tested.
That's what I meant by 'easy' for @Notepad! He's quite au fait with the firmware.
@droftarts Well the code is here: https://github.com/Duet3D/RepRapFirmware/blob/3.5-dev/src/CAN/CanInterface.cpp good luck!
@gloomyandy
@droftarts
@Notepad
@dc42From my perspective, there is no need to switch to CAN0 from CAN1. Since it was not specified in the team gloomy documentaion that only CAN1 will work with the toolboard, I assumed both would do it.
In my case it would have simplified the wiring of the toolboard a bit because my 24V PSU is mounted close to the Duet 6HC. I have four 1HCL expansion boards mounted inside the build chamber. But they are all running on 48V. So I split the toolboard cable in CAN and power. CAN goes to to ne of the toolboards and power goes all the way down to the underside of my printer to the 24V PSU. Not as tidy, but works.
