3.5.0-rc.1 LED Issuse
@gloomyandy Certainly
M950 E0 C"connlcd.5" U3 T2
@danzaywer Can you try running M950 E0 in the console and post the output here.
M950 E0 NeoPixel_RGBW strip on port "(connlcd.np,connlcd.db7,connlcd.5)" uses bit-banging, frequency 2500000Hz, max strip length 3
@danzaywer default frequency should be 3000000Hz ?
@danzaywer I'd try different frequencies from 2000000 up to say 3200000. I've found that different pixels sometimes need the frequency to be adjusted a little. You should be able to change the settings (and set the pixels) from the console to try out different configurations.
@danzaywer Are you definitely getting a 5V signal on the data line to the first LED? I've been playing around with LEDs for the last couple of days on a variety of Duet boards, and have a similar effect when controlling them from 3.3V pins.
@gloomyandy Nope
I try from 3200000 to 2000000, also 1600000 and 8000, 800 500 just to try, green is always on everytime i send an M150. Maybe an hardware foult of my duet? onM950 E1 C"duex.pwm5" T2
is same same .
@danzaywer And it worked okay in older firmware? What version? If so, I doubt it's a hardware fault. Maybe, just maybe ... a ... firmware ... bug!?
@droftarts On duex.pwm5 I should have 5v from external source, I have atx 5v rail connected on "EXT 5v" and "5v AUX" jumper is on "5v ext", while the strip on CONN_LCD have signal on a 74HCT08.
@droftarts Yes, it worked fine. BTW no a great issue, if set blue I have cyan....
@danzaywer If you go back to an older version of the firmware (which version did you have?), does it work?
@gloomyandy It worked on 3.4.6, could not try downgrade at the moment, too many changes to do
@danzaywer I’ll test later. The LEDs I have all work on 5V and 3.3V signalling on Duet 3 (except if I use them on an io.in pin), but the first LED (of 7) doesn’t respond correctly on Duet 2, and the string goes full on on Maestro whatever I send (which hasn’t supported Neopixels before 3.5). So it does feel like something is not quite right.
@danzaywer @gloomyandy Okay, I just tried my LEDs on 3.4.6, and sure enough, they all work. So there is definitely a difference between 3.4.6 and 3.5.0-rc.1. I'll report it to @dc42.
@droftarts Ok, thanks for checking
@droftarts Was the setup you used using bit-banging or hardware output?
@gloomyandy I’m not sure. This was using CONNLCD pin 5 on a Duet 2 WiFi (board is actually a pre production white PCB, but I don’t think that matters). In 3.4.6 I tried to set M150 X1 (the default) but I got a message about ‘unsupported LED type’, I didn’t set any other LED type, but then it worked anyway. I think frequency was set at 2500000Hz.
On 3.5.0-rc.1 I set M950 E0 T1 Q3000000. I don’t know if that means they are bit-banged.
The LEDs are a string of 7 SK6812 4020 RGB sidelight LEDs, from https://coolcomponents.co.uk/products/led-side-light-strip-white-1m-adafruit-neopixel-compatible?_pos=1&_sid=e9f065ecd&_ss=r
I can retest later, and I’ll post the code and responses. Let me know if there’s anything else you need.
@droftarts A good way to check is to run M950 E0, that should report if it is using bit-bang or not (on 3.5 at least). It is probably best not to set a frequency with the Q option and just use the default (at least to begin with). I think that way you will be testing like with like between the two versions.
@gloomyandy Managed a quick test. Looks like bit-banging is used in both RRF versions. Also, it seems the default for Duet 2 is 2.5MHz.
3.5.0-rc.1:M950 E0 C"connlcd.5" T1 M950 E0 NeoPixel_RGB strip on port "(connlcd.np,connlcd.db7,connlcd.5)" uses bit-banging, frequency 2500000Hz, max strip length 60 M150 R1 S7 ; first LED turns on green 255, the rest dimly red M150 r255 S7 ; first LED turns yellow (green 255 red 255), the rest red M150 r0 S7 ; first LED stays green 255, the rest off
Whatever I send, the first LED stays green 255, with other colours mixed in if set, while the other LEDs respond correctly. Changing frequency made no difference.
3.4.6:
M150 Led type is NeoPixel RGB bit-banged, frequency 2.50MHz M150 R1 S7 ; All LEDs turn on dimly red M150 R255 S7 ; All LEDs turn on full red M150 R0 S7 ; All LEDs turn off
All subsequent commands, whatever the colour mix, also respond correctly. Changing frequency made no difference. If I tried to set M150 X1 or M150 X3 in RRF 3.4.6, I'd get
Error: M150: Unsupported LED strip type
.I also tried a short string of 3x 5050 SK6812 RGBW LEDs. Once I'd remembered to switch from RGB to RGBW (M950 T2 in RRF 3.5.0-rc.1, and M150 X4 in RRF 3.4.6), I had exactly the same behaviour; in 3.5.0-rc.1 the first LED always had green 255 once any value was set, whereas in 3.4.6 it behaved correctly.
Let me know if you want me to do any more test.
@droftarts I have the same behavior, I have RGBW LEDs, set with M950 E1 C"duex.pwm5" T2
